gunbab Samba Member
Joined: March 25, 2008 Posts: 121 Location: Less Wood Belgium
Posted: Sat Apr 29, 2017 4:21 am Post subject: BJ Engine |
I have a brazil splitbus from 1975.
The motor in the bus has a BJ code.
I think this is a 1300 cc engine.
Unfortunally i cant find anything info about this engine.
Whi can help me? |
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Sat Apr 29, 2017 4:24 am Post subject: Re: BJ Engine |
the only time I've ever really seen anything about Brazil engine codes was here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=495197 _________________ Andy T.
PEPPE Samba Member
Joined: August 24, 2003 Posts: 1068 Location: Roma Italy
Posted: Sat Apr 29, 2017 8:13 am Post subject: Re: BJ Engine |
you can find also infomations, but from what i have seen, brazil buses have a lot of miles, and also MANY engine rebuils. you can find inside the engine ANYTHING. better thing is to open them and inspect carefully. also because the quality standards of the machining and selection of useable parts is very different than european (or Usa) standards. |
gunbab Samba Member
Posted: Sat Apr 29, 2017 8:41 am Post subject: Re: BJ Engine |
The motor is a good running engine.
Only thing i wanna do for now is to adjust the ignition. Therefore i need to know the timing to adjust the ignition. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
PEPPE Samba Member
Posted: Sat Apr 29, 2017 9:33 am Post subject: Re: BJ Engine |
carburettor is the common solex 30 with manual choke? put a photo of the engine pls |
gunbab Samba Member
Posted: Mon May 01, 2017 8:20 am Post subject: Re: BJ Engine |
A photo of the egine as requested. I hope you can help me now. Thanks alot.
[img][/img] |
PumaVW79 Samba Member
Joined: January 31, 2012 Posts: 487 Location: WGS84: 22.9083° S, 43.1964° W
Posted: Mon May 01, 2017 11:52 am Post subject: Re: BJ Engine |
gunbab wrote: |
Whi can help me? |
Fusca (Beetle) 1300
1300 BJ
From 74 to set/79
1285 cc
6.8:1
1 carb
Gas
10°
Sources: here and here |
Singerdude Samba Member
Joined: March 07, 2015 Posts: 464 Location: Quebec, Canada
Posted: Mon May 01, 2017 6:21 pm Post subject: Re: BJ Engine |
Am I the only one idiot enough to hear Beavis and Butthead voices saying : hehehhe BJ engine heheheh! |
PEPPE Samba Member
Posted: Mon May 01, 2017 9:07 pm Post subject: Re: BJ Engine |
7,5 or 10 will work, but the engine is very tolerant due to the very low compression. |
modok Samba Member
Posted: Mon May 01, 2017 9:24 pm Post subject: Re: BJ Engine |
PumaVW79 wrote: |
gunbab wrote: |
Whi can help me? |
Fusca (Beetle) 1300
1300 BJ
From 74 to set/79
1285 cc
6.8:1
1 carb
Gas
10°
Thank you! I have never seen good info about Brazil engine codes before now! copy/paste
Códigos dos MOTORES
BD-1600 GAS FUSCA
BG - 1600 GAS KOMBI E KOMBI EXP
BJ - 1300 GAS FUSCA
BK - 1300 ALC FUSCA BRASILIA
BM - 1300 ALC GOL
BN - 1600 GAS BRASILIA
BP - 1600 ALC GOL SAVEIRO
BV - 1600 GAS VARIANT
BX - 1600 ALC KOMBI KOMBI EXP
BY - 1300 GAS GOL
BZ - 1600 GAS KOMBI
UF - 1600 GAS FUSCA
UG - 1600 GAS KOMBI
UJ - 1600 ALC FUSCA
UK - 1600 ALC KOMBI
Motores acima de 90
UFA - 1600 GAS FUSCA
UJA - 1600 ALC FUSCA
UGA - 1600 GAS KOMBI CARAT
MAIS ANTIGOS ( 68 a 77 )
B-1200
BJ-1300
BF-1300
BH-1500
BB, BA, BD, BV,BZ, BG, BN -1600
BL-1700 ( SP 2 ) |
gunbab Samba Member
Posted: Tue May 02, 2017 1:14 am Post subject: Re: BJ Engine |
thank you all. Great help. |
