62ItalianRagtop Samba Member
Posted: Sat Apr 29, 2017 2:31 pm Post subject: Info on 51-52 |
Hi, what about this dash ?
Is clock missing ?
What about dash grab handle and glove boxes doors?
Are door panel and seat original?
Thank you _________________ LOOKING FOR 62 ENGINE WITH NUMBER FROM 6.904.xxx TO 6.915.xxx
http://tettodistraccio.blogspot.com/ |
Two Glove Boxes Samba Member
Posted: Sat Apr 29, 2017 4:59 pm Post subject: Re: Info on 51-52 |
Deluxe model right?
Need more photos of the seats. |
Mr. OGPaint Samba Member
Joined: September 24, 2010 Posts: 823 Location: Oregon
Posted: Sun Apr 30, 2017 8:13 am Post subject: Re: Info on 51-52 |
It is missing a clock pod on the passengers side. Perhaps someone had a radio installed in this area. Radios are expensive. I'm unfamiliar with the "skirting" installed inside the opening
Glove box doors were a common accessory in the era, I'm not familiar with the exact type this car has....but they are look era correct.
Does the grab handle have a cast aluminum handle with a vinyl insert? It is not a factory part, but was a period accessory. Happich perhaps. Hopefully more pictures, or someone more knowledgeable on this will chime in
A few other observations:
Correct: steering wheel, switches, and the rear view mirror appear correct
Incorrect: shift knob is newer style, the carpet is a kit for a newer car. I believe the upholstery is an approximation of stock, but not quite original style. _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
