CV Axle angle
ALANSD
ALANSD is offline
PostPosted: Sun Apr 30, 2017 12:22 pm    Post subject: CV Axle angle Reply with quote
I noticed recently both sides need CV axle boots. I am wondering if the axle angle would cause these to fail. I have Monroe air shocks in the rear and when pumped there is a few inch raise in the angle of the cv axles.
A happy camper
ALANSD
ALANSD is offline
PostPosted: Fri May 05, 2017 2:42 pm    Post subject: Re: CV Axle angle Reply with quote
any ideas?
A happy camper
Wildthings
Wildthings is offline
PostPosted: Fri May 05, 2017 8:32 pm    Post subject: Re: CV Axle angle Reply with quote
At best buying CV boots is a toss up, I don't think any brand is good all the time.
ALANSD
ALANSD is offline
PostPosted: Sat May 06, 2017 5:24 am    Post subject: Re: CV Axle angle Reply with quote
are these correct for the rear with air shocks?
http://www.cbperformance.com/product-p/4690.htm
[/img]
A happy camper
Wildthings
PostPosted: Sat May 06, 2017 7:12 am    Post subject: Re: CV Axle angle Reply with quote
[/img]
That is a swing axle boot, Assuming you actually have CV joints you need a boot for use with an IRS CV style axle instead.
Go with a Rockford if you can afford it. The cheapest acceptable boot would be an Empi. The Thing boot is the same as a Transporter/Type 2 boot. There are other boots between these two extremes and a pile that aren't worth taking out of their box.
