AS350driver Samba Member
Posted: Sun Apr 30, 2017 2:55 pm Post subject: Road Trip! Tucson, to Laredo, TX |
This is probably a bad idea, but I can't resist a good adventure. I'm going to see if my recently revived 65 Westy can do an 1,800 mile road trip without a tow truck being involved somewhere. Plans are to utilize I-10 to around Ft Stockton, Texas, then hit 2 lane roads along the border/Rio Grande the rest of the way.
The motor was rebuilt in 2000, but sat 17 years. It runs and sounds nice though, never smokes, and doesn't seem to be consuming large amounts of oil. On a hot day, 90+, after being on the freeway, the green light flickers at idle. On a cool day it doesn't. According to the receipts, the motor has about 3,000 miles on it.
The tranny leaks here and there, but no gushers, and had some whininess in 3rd and especially 4th gear. I added some Lucas oil treatment, and to my surprise it quieted right down.
The tranny is my biggest concern, but of course there are a zillion other things that could flare up.
If you see a VG Westy broke down on the side, do stop and visit
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Sun Apr 30, 2017 6:51 pm Post subject: Re: Road Trip! Tucson, to Laredo, TX |
Have a fun trip. Post up anytime. The bus wants its legs stretched and you're the guy to do it. |
oakman Samba Member
Joined: February 05, 2014 Posts: 1715 Location: Edge of the Desert, Ca
Posted: Sun Apr 30, 2017 7:06 pm Post subject: Re: Road Trip! Tucson, to Laredo, TX |
Right on! Have a good trip! _________________ Brandon |
Z Samba Member
Joined: June 15, 2003 Posts: 2517 Location: galveston, tx
Posted: Sun Apr 30, 2017 8:07 pm Post subject: Re: Road Trip! Tucson, to Laredo, TX |
Cool trip! If you have trouble, you can find answers here.
Do you think the guys at Wolfsburg ever thought that the best tool in the VW maintenance tool box would be the internet? |
Posted: Sun Apr 30, 2017 9:24 pm Post subject: Re: Road Trip! Tucson, to Laredo, TX |
The guys from back at Wolfsburg would still be in shock theses buses are still going, not to mention the miracle of the internet.
Made to Las Cruces. Gonna crash here tonight. Bus scared me a little in Texas canyon back during the heat of the day. Climbing steeper grades, over 1/2 throttle the motor was pinging and making a sound out of the muffler like plastic straps flapping in the wind. It was also skipping Letting off the gas instantly smoothed it all out, but then you're even slower. It seemed like the vacuum distributor was advancing too much. I only statically timed it to 7.5 btdc when installing it. A quick roadside timing adjustment, backing off the timing helped a lot. Once the temperature started coming down the bus ran like a freight train.
pondoras box Samba Member
Joined: March 22, 2004 Posts: 1218 Location: Eerie PA
Posted: Mon May 01, 2017 5:16 am Post subject: Re: Road Trip! Tucson, to Laredo, TX |
These are my favorite threads! Keep the updates coming so we can all live vicariously through you while we are at work.
Remember to always keep safety in mind but we all love to see pictures like that last one. _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1961 23 Window (Bobo)
1965 11 Window (Zelda)
1965 13 Window (Lucas)
1957 Oval ragtop
1988 Cabriolet VR6 conversion
Plus a lot of other rusty junk |
Manfred58sc Samba Member
Posted: Mon May 01, 2017 7:31 am Post subject: Re: Road Trip! Tucson, to Laredo, TX |
Great picture, brings back many a road trip memory. Keep em' coming. "Franz and Klaus" on the assembly line would have never imagined their grand children still using these machines on the other side of the world. _________________ Fat chick owner/operator |
rennie Samba Member
Joined: October 06, 2016 Posts: 246 Location: Orange County, CA
Posted: Mon May 01, 2017 8:56 am Post subject: Re: Road Trip! Tucson, to Laredo, TX |
Exciting adventure - best of luck as you roll on. Are you running stock power with a FF or all stock and going 50-55mph? |
Posted: Mon May 01, 2017 11:11 am Post subject: Re: Road Trip! Tucson, to Laredo, TX |
57 mph seems to be its favorite speed. |
Posted: Mon May 01, 2017 11:08 pm Post subject: Re: Road Trip! Tucson, to Laredo, TX |
Del Rio TX 1:06 AM. Lots of bugs at night in Texas
Almost called tow truck about 200 miles back, but the gremlin went away after dark. This bus only travels good at night I've discovered.
Posted: Tue May 02, 2017 4:09 am Post subject: Re: Road Trip! Tucson, to Laredo, TX |
It made it. The brakes are acting up, the muffler blew out, and the motor is idling weird and rough. But smooth as glass at 55 If the temperature hits 80+ sometimes the engine cuts out on long steady grades. Sometimes not. Letting it cool a while seems to help. I have a laser thermometer I've been monitoring engine temps with. The motor isn't running super hot when these misfires under load are occurring. Highest temp I've found in the oil sump /block area is 225 at the oil pump. Rest of the sump is more like 195-200.
But driving at night or the cool of the morning , runs like a freight train. Hopefully there's a Vw shop here in laredo and I can get an electronic ignition and a new coil. My guess is something's getting hot in the ignition system or the vac advance is sticking. |
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
plane_ben Samba Member
Joined: February 27, 2005 Posts: 349 Location: Tucson, AZ
Posted: Tue May 02, 2017 6:57 am Post subject: Re: Road Trip! Tucson, to Laredo, TX |
Sounds like you are still a tad advanced on the timing Mitch. Get a cheap timing light and set it properly at full advance, ie, engine at cruise rpm's. Sometimes the advance curve is off and the timing at idle will be to advanced at cruise. _________________ I'm at the age were "fuck off", "fuck you", and "fuck it" answer most questions. |
rennie Samba Member
Posted: Tue May 02, 2017 7:40 am Post subject: Re: Road Trip! Tucson, to Laredo, TX |
SamboSamba22 wrote: |
Yourself and your adventure, solidifies that I'm a wimp and should just go for it!
I want to do some road tripping in the bus badly... |
Ditto! I worry about trips beyond an hour but am gearing up for Buses By the Bridge in January. The driving is fine, it's the engine mechanics that's not my strong point.
Glad you made it AS350driver and thanks for the updates and details. Neat bus, too! |
Cuñado Wear Samba Member
Joined: December 10, 2006 Posts: 1142 Location: The "O"
Posted: Tue May 02, 2017 8:12 am Post subject: Re: Road Trip! Tucson, to Laredo, TX |
Love these types of trips. please keep pictures coming. Have fun and be safe. _________________
Bulli Klinik wrote: |
I may be a little late to the party, but what the hell is Cunado Wear? |
Looking for front kick panels for late 63' Deluxe Basalt Gray
60' Double Cab
63' 15 Window Deluxe |
joefriday Samba Member
Joined: November 30, 2015 Posts: 179 Location: Richland WA
Posted: Tue May 02, 2017 9:08 am Post subject: Re: Road Trip! Tucson, to Laredo, TX |
Awesome. Cool bus and safe travels. It sounds like you are traveling at night. Riding with a rear reflector sign? |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Tue May 02, 2017 10:01 am Post subject: Re: Road Trip! Tucson, to Laredo, TX |
plane_ben wrote: |
Sounds like you are still a tad advanced on the timing Mitch. Get a cheap timing light and set it properly at full advance, ie, engine at cruise rpm's. Sometimes the advance curve is off and the timing at idle will be to advanced at cruise. |
On a used distributor it is common for the advance to be off a bit (2 degrees either side). The curve charts are typically for new distributors. Hopefully never enough to effect good performance. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Tue May 02, 2017 10:07 am Post subject: Re: Road Trip! Tucson, to Laredo, TX |
[quote="AS350driver"]The guys from back at Wolfsburg would still be in shock theses buses are still going, not to mention the miracle of the internet.
A vacuum only distributor will not over advance. If it's too far advanced the static timing is the culprit. It depends upon what vacuum canister you have installed. It's not unusual for the wrong canister to be in use.
I love road trippin too, best of luck on the journey/glad you made it with little more than lessons learned. _________________ Roads Scholar &
Posted: Tue May 02, 2017 10:09 am Post subject: Re: Road Trip! Tucson, to Laredo, TX |
Yep. That's what I'm saying. Two degrees is enough to cause hot running in hot weather. I always time my engines at full advance to the mark on the pulley. That way, I know I'm not over advanced timing wise. _________________ I'm at the age were "fuck off", "fuck you", and "fuck it" answer most questions. |
Posted: Tue May 02, 2017 10:25 am Post subject: Re: Road Trip! Tucson, to Laredo, TX |
Speaking of that mark on the pulley, I may spring for a degreed pulley!
I two weeks when I head back it will be even warmer. Being restricted to only driving at night down here is pretty hazardous as there are about an average of 3 suicidal deer per mile, waiting to jump out and ruin the nose of your bus. |
