Single vs. Dual Circuit Master Cylinder behavior.
matthew henricks
matthew henricks is offline
PostPosted: Mon May 01, 2017 4:57 pm    Post subject: Single vs. Dual Circuit Master Cylinder behavior. Reply with quote
Is it normal for a Dual MC set-up to feel different from a single MC system?
Installed a system in my 65 a few years back and noticed over time it just feels different. When i brake the peddle travels 80% to the floor and then engages. The brakes feel solid but alot of travel.
I am using a bay window MC with a volvo reservoir. The MC has a 1/2" mount spacer and the push rod has no play when engaging the MC. The front MC circuit goes to the rear brakes. The rear MC circuit goes to the front brakes.
Wheels are adjusted right and no air in line. All parts are in good shape
This does not seam normal.
In the below pictures the second one is at rest. Third is the initial stroke which does not apply any pressure to the breaks. The last one is where all the breaking takes place.
glideking
glideking is offline
PostPosted: Mon May 01, 2017 5:23 pm    Post subject: Re: Single vs. Dual Circuit Master Cylinder behavior. Reply with quote
You are right this is not normal. Brakes should feel the same as a single circuit if the piston diameter is the same. By "wheels adjusted right" do you mean all 8 star adjusters are adjusted correctly to compensate for wear? How does your parking brake feel? The pushrod must have SOME play to function properly.
Kurt
"The more I get done the less it looks like I did anything"
1959 Single Cab Restoration"Funky Truck"
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...highlight=
1965 21 Window Restoration Thread (From old photos)
http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
1963 Panelvan build "Tyvanosaurus Wrecks"
http://www.thesamba.com/vw/forum/viewtopic.php?p=8351639#8351639
glideking
PostPosted: Mon May 01, 2017 5:42 pm    Post subject: Re: Single vs. Dual Circuit Master Cylinder behavior. Reply with quote
Your brake pedal return spring may be in the wrong place. It needs to be wound tighter and attached to the rear of the arm. Perhaps your pedal is not returning all the way up combined with your lack of pushrod gap is not allowing reservoir fluid in.
Kurt
David Raistrick
David Raistrick is offline
PostPosted: Mon May 01, 2017 7:24 pm    Post subject: Re: Single vs. Dual Circuit Master Cylinder behavior. Reply with quote
No. There should be no feel difference.
80% travel means a PROBLEM. You've driven it for years like that? Scary.
80% travel means one of many things:
Very out of adjustment shoes. (gotta adjust all 4 corners, too).
Air in the system.
A leak in the system (on a single circuit the pedal will hit the floor with a leak - with a dual circuit you'll lose half+, so 80% travel might be about right).
A misconfigured master cyl with no free play and the "top" circuit isn't returning enough to recharge with fluid and reset the valve.
And there's one of your major problems. You need to either shim that MC further away, buy a correctly fitting MC (or MC/adapter combo), or adjust or cut your pushrod.
That free play is IMPORTANT.
...david - '66 SO-44 #231
matthew henricks
PostPosted: Mon May 01, 2017 9:12 pm    Post subject: Re: Single vs. Dual Circuit Master Cylinder behavior. Reply with quote
Thank you guys.
I am betting the problem then is no play in the pushrod and therefor no fluid is getting into the MC.
All four corners are adjusted. No leaks anywhere and the E-brake works fine. I do see that my brake spring is not in the right spot (Thanks Kurt) but the peddle does return all the way up easily.
The bus is rarely driven. She's a garage queen.
I will report back my findings.
60freak
60freak is offline
PostPosted: Tue May 02, 2017 5:02 am    Post subject: Re: Single vs. Dual Circuit Master Cylinder behavior. Reply with quote
Isn't there a possibility that certain bay MC's that will create several problems in a split (residual valves, piston bore & stroke?) I don't think you can just pop on a bay MC with the spacer and rock n roll. I know a friend did just that and had same issues as the OP plus the pedal was hard to push as well once the braking action occured. Using a '67 MC solved the issues he was having. Just a thought: is the correct MC installed?
easy e
easy e is offline
PostPosted: Tue May 02, 2017 5:21 am    Post subject: Re: Single vs. Dual Circuit Master Cylinder behavior. Reply with quote
He said it was Bay + spacer... so, "correct" isn't in the picture.
But, good point about residual or check valve(s).
aka: Evan
matthew henricks
PostPosted: Tue May 02, 2017 7:29 am    Post subject: Re: Single vs. Dual Circuit Master Cylinder behavior. Reply with quote
I cannot locate the original receipt for the MC but the part number was recommended on this forum. A 67 unit was out of reach.
Not sure how to tell after the fact which MC i have. Will look for a number tonight.
Eric&Barb
Eric&Barb is offline
PostPosted: Tue May 02, 2017 8:04 am    Post subject: Re: Single vs. Dual Circuit Master Cylinder behavior. Reply with quote
From the shape of the MC, it looks like it is a 1971-79 Bus type. It does sound like one of the two circuits in the MC has failed.
In Stereo, Where Available!
OB Bus
OB Bus is offline
PostPosted: Tue May 02, 2017 9:01 am    Post subject: Re: Single vs. Dual Circuit Master Cylinder behavior. Reply with quote
A number of vendors (EIS?) sell the Chinese built 67 dual circuit master. I have not heard of any problems with them. Price is quite reasonable.
Larry in OB
69 Westfalia and 2002 Eurovan Camper.
matthew henricks
PostPosted: Wed May 03, 2017 7:36 am    Post subject: Re: Single vs. Dual Circuit Master Cylinder behavior. Reply with quote
Last night i pulled the MC and shortened the push rod. I then re-installed it and properly adjusted it so there was a 1/32 gap at peddle rest.
I did not fix the spring yet but after pressing the peddle down about 20 times i feel a marginal improvement.
I am going to re-check the wheel adjustment again next.
I looked for a part number on the MC. It is an EIS unit but all i found were casting numbers on it. "PAS 85112" and a large sideways "25".
Is there anything else at the MC end that i should check out? Anything about how the brake lines connect to the MC?
Thank you for the guidance.
Eric&Barb
PostPosted: Wed May 03, 2017 7:42 am    Post subject: Re: Single vs. Dual Circuit Master Cylinder behavior. Reply with quote
Be smart to check everything. All too easy to mix up the LF brake line with the one line going to the rears.
matthew henricks
PostPosted: Wed May 03, 2017 8:46 am    Post subject: Re: Single vs. Dual Circuit Master Cylinder behavior. Reply with quote
Found the MC part number i used.
211 611 021 A
Oh. The bus is not for sure parked till this is fixed.
Matthew
Last edited by matthew henricks on Wed May 03, 2017 4:05 pm; edited 1 time in total
Nubby
Nubby is offline
PostPosted: Wed May 03, 2017 11:56 am    Post subject: Re: Single vs. Dual Circuit Master Cylinder behavior. Reply with quote
If I am replacing the brake system in my 62 with a 67 complete setup, do I still need the adapter?
60freak
60freak is offline
PostPosted: Wed May 03, 2017 12:07 pm    Post subject: Re: Single vs. Dual Circuit Master Cylinder behavior. Reply with quote
No you do not need the the adapter, however you will need a "T" fitting for the front brake line and one short section of brake line (approx 8" or so) to tee the L & R front brake lines together.
matthew henricks
PostPosted: Thu May 04, 2017 2:22 pm    Post subject: Re: Single vs. Dual Circuit Master Cylinder behavior. Reply with quote
Before i go any further can anyone confirm that MC part number
211 611 021 A is one that will work?
Thanks
Eric&Barb
PostPosted: Thu May 04, 2017 2:52 pm    Post subject: Re: Single vs. Dual Circuit Master Cylinder behavior. Reply with quote
Thanks
If is originally fitted to 1971-79 Bus, then yes.
Just did a WWW search for "VW 211 611 021 A" and it shows up being sold for such.
60freak
60freak is offline
PostPosted: Fri May 05, 2017 4:34 am    Post subject: Re: Single vs. Dual Circuit Master Cylinder behavior. Reply with quote
Thanks
I personally would not use that MC, it is designed to have a "booster" most likely you are gonna be stomping hard on the pedal to stop decent. I would only use a '67 master or possibly an early bay. I'm pretty sure the late model bay MC has some differences that can cause issues, like piston bore and stroke, as well as the residual valves. If you plan to swap the brake booster in the bus as well, then yeah I would say the late model MC is what to use. Just do it right, get a '67 MC, they repop them for reasonably good prices. I picked my last one up for $100 or so brand new.
Eric&Barb
PostPosted: Fri May 05, 2017 7:18 am    Post subject: Re: Single vs. Dual Circuit Master Cylinder behavior. Reply with quote
Well so far no problem for us with the 1971-79 Bus MC over about 150,000 miles. It should be a little harder to lock the brakes than the 1967 MC, but at same time that gives you a bit more control not to lock the brakes which is something you want to avoid.
Sure if you have a bad leg get the vacuum booster to help!
matthew henricks
PostPosted: Fri May 05, 2017 7:36 am    Post subject: Re: Single vs. Dual Circuit Master Cylinder behavior. Reply with quote
Thanks guys. I am looking at my options. I suspect i am going to find a problem in one of the rear wheels now that i am looking. One does not grab when using the E-brake so i will start there.
If i switch to the 67 MC, will i be able to mount my belly pan without chopping it? Sure would like to stick that back on.
Will report back but likely not for a few weeks as i do not see time in the near future to tackle this.
Matthew
