Paint for blue Bosch Screamer distributor?
IntrstlarOvrdrve
IntrstlarOvrdrve is offline
PostPosted: Mon May 01, 2017 5:40 pm    Post subject: Paint for blue Bosch Screamer distributor? Reply with quote
I dug up an old thread where Glenn said he gave up trying to find a match for the paint about 5 years back..but has anyone found a "close enough" match? It doesn't have to be dead nuts accurate, I just want to freshen mine up as most of the original paint has since flaked off.
Tennessee, Tennessee, ain't no place I'd rather be
txoval
txoval is offline
PostPosted: Mon May 01, 2017 6:29 pm    Post subject: Re: Paint for blue Bosch Screamer distributor? Reply with quote
PM Glenn
PostPosted: Mon May 01, 2017 9:59 pm    Post subject: Re: Paint for blue Bosch Screamer distributor? Reply with quote
As far as I know - No but I found this older post with one that looks nice but not 100% correct as it's plain paint and not a "hammer tone":
https://www.thesamba.com/vw/forum/viewtopic.php?p=4668834#4668834
IntrstlarOvrdrve
PostPosted: Tue May 02, 2017 5:54 am    Post subject: Re: Paint for blue Bosch Screamer distributor? Reply with quote
Thanks! I hadn't found that thread in my search. I did some more digging last night, I know this isn't really correct either (it's just as correct as the blue on the dist you posted!) but at least it's hammertone. I might give it a shot.
http://www.tcpglobal.com/HAM-41150.html?gclid=CKG60sic0dMCFRc9gQodXI8AUA#.WQh95Wd1vIU
And if all else fails, what black paint is everyone painting their distributors in? Laughing
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue May 02, 2017 6:05 am    Post subject: Re: Paint for blue Bosch Screamer distributor? Reply with quote
NOS
BTW, they were black 019s that were complete and then painted over including the hardware.
Glenn
Member #1009
#BlueSquare
IntrstlarOvrdrve
PostPosted: Tue May 02, 2017 6:54 am    Post subject: Re: Paint for blue Bosch Screamer distributor? Reply with quote
Thanks, Glenn! I'd known there were just painted over, in fact mine is about half black again. Laughing
Like I said, if all else fails I'll just paint it back to black. I just wanted to clean it up a little and thought it would be cool blue again. What are you using to paint them black?
Mr. 010
Glenn is offline
PostPosted: Tue May 02, 2017 6:58 am    Post subject: Re: Paint for blue Bosch Screamer distributor? Reply with quote
I use a satin black finish.
Left is NOS and right is restored.
Glenn
Member #1009
#BlueSquare
tasb
The Distributor Distributor
tasb is offline
PostPosted: Tue May 02, 2017 9:51 am    Post subject: Re: Paint for blue Bosch Screamer distributor? Reply with quote
The original black paint was notoriously thin.
Roads Scholar &
Lingwendil
Lingwendil is offline
PostPosted: Wed May 03, 2017 2:49 am    Post subject: Re: Paint for blue Bosch Screamer distributor? Reply with quote
To be perfectly honest, I don't all that much care for the original screamer blue paint, overspray and sloppy. The black looks good, but the "over restored" one in that thread linked looks great.
On most of the 019 distributors I've tore down, they were mostly the same tone, but one had a bit of a teal tint, more than the usual blue. I personally like the black, and use rustoleum 500 degree engine paint, since it holds up very well. If you use it, do the semi-gloss and throw it in the oven (or hotbox if you have one) for an hour or so at 250 degrees to knock down the shine and cure the paint, it will be stronger faster that way.
It looks less gloss in person, but works great if you go this route...
This is the paint I use-
73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087!
darynoval1
darynoval1 is offline
PostPosted: Thu May 04, 2017 4:46 am    Post subject: Re: Paint for blue Bosch Screamer distributor? Reply with quote
Thanks for posting this!
Shadd
Shadd is offline
PostPosted: Tue Jun 13, 2017 7:58 pm    Post subject: Re: Paint for blue Bosch Screamer distributor? Reply with quote
would this match the original screamer? Ive bought it at the local big box hardware store for another project.
Mr. 010
Glenn is offline
PostPosted: Tue Jun 13, 2017 8:09 pm    Post subject: Re: Paint for blue Bosch Screamer distributor? Reply with quote
No, it doesn't.
Glenn
Member #1009
#BlueSquare
