28 pci venturi change
vpn1965
vpn1965 is offline
PostPosted: Tue May 02, 2017 2:53 pm    Post subject: 28 pci venturi change Reply with quote
Hey folks, i need some help. I have a 28 pci carb, but the venturi was turned to 24mm, and i want to make it stock again. Someone have any advise of how do you change the venturi?
sgmalt46
sgmalt46 is offline
PostPosted: Thu May 11, 2017 11:22 am    Post subject: Re: 28 pci venturi change Reply with quote
take the top off the carb' there is a set screw in the front. left of the accelerator pump. take it out and it will come right out.
55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back
46 beetle
vpn1965
vpn1965 is offline
PostPosted: Sat May 13, 2017 7:39 pm    Post subject: Re: 28 pci venturi change Reply with quote
haha worked!!! thanks!!
