Don66bus Samba Member
Posted: Fri May 05, 2017 10:04 am Post subject: Problems with bleeding on Wagenswest Rabbit dual master cylinder |
More brake questions ...
I bought the dual master cylinder for a Rabbit from Nate to upgrade the original single MC on my '66 bus. It fit fine but my mechanic could not get the air out of the front lines. He has 40-50 years of experience and all the tools one could need, and he spent 2 hours trying pressure and vacuum and good old pumping the pedal bleeding operations. The front lines always kept some air. He put the original single MC back in and got a firm pedal in 5 minutes.
It is possible that it the dual circuit MC I received is defective and Nate will return my money or replace it with no problem. However, the one thing my mechanic did not check is changing around the brake lines to different ports on the dual MC. My question are: has anyone successfully installed this unit in their '64 to '66 bus and, if so, what brake lines did you connect to what ports?
Thanks. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24757 Location: Olympia Wash Rinse & Repeat
Posted: Fri May 05, 2017 10:51 am Post subject: Re: Problems with bleeding on Wagenswest Rabbit dual master cylinder |
Even if you connect up the wrong brake lines to the wrong ports it will pressure bleed the system and function. You just want the front lines to be nearest the brake pedal and the rear line farthest away from the pedal end of the MC. Real easy to mix up the rear line with the LF line since they do run back several feet side by side. _________________ In Stereo, Where Available! |
vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1357 Location: Richmond, VA
Posted: Fri May 05, 2017 10:53 am Post subject: Re: Problems with bleeding on Wagenswest Rabbit dual master cylinder |
Sounds like what was happening with the brakes on my dad's 59 bug when he went to front disks. I think he ended up having to use a different master cylinder to fix it, but I don't know what one he used and if it'd be the same on a bus.
Also, if the Rabbit MC is in fact doable on a bus, would it work on my 67? _________________ 1973 Superbeetle: 1st car, owned since age 12. Update thread --> https://www.thesamba.com/vw/forum/viewtopic.php?p=9919140#9919140
1966 Beetle: My new project. (SOLD) Build thread--> https://www.thesamba.com/vw/forum/viewtopic.php?t=678040 |
Posted: Fri May 05, 2017 11:07 am Post subject: Re: Problems with bleeding on Wagenswest Rabbit dual master cylinder |
Personally never heard of using a Rabbit MC. Maybe you mean it is a Bus MC with Rabbit reservoir? _________________ In Stereo, Where Available! |
Posted: Fri May 05, 2017 2:39 pm Post subject: Re: Problems with bleeding on Wagenswest Rabbit dual master cylinder |
It is apparently a Rabbit master cylinder. Here is the listing. It is the smaller of the two offered:
http://www.wagenswest.com/partstore/index.php/1955-67-dual-circuit-bus-master-cylinder-kit.html
There are four open ports: two for the front brakes, one for the combined rear brakes, and one for the brake light switch. It may be that some combination works better than what we already tried. That is why I am interested if anyone on the TheSamba has made this work. |
Posted: Fri May 05, 2017 2:58 pm Post subject: Re: Problems with bleeding on Wagenswest Rabbit dual master cylinder |
Interesting! Thanks for posting that. _________________ In Stereo, Where Available! |
David Raistrick Samba Member
Joined: January 26, 2004 Posts: 539 Location: Geneva, Florida
Posted: Sat May 06, 2017 3:20 pm Post subject: Re: Problems with bleeding on Wagenswest Rabbit dual master cylinder |
Don66bus wrote: |
It fit fine but my mechanic could not get the air out of the front lines. He has 40-50 years of experience and all the tools one could need, and he spent 2 hours trying pressure and vacuum and good old pumping the pedal bleeding operations. The front lines always kept some air. He put the original single MC back in and got a firm pedal in 5 minutes. |
Stupid question - did he make sure the rod had free play? if the MC can't return to neutral (the pedal rod doesn't have a gap) then it can't draw fluid in, and can't pump the air out. Alternatively the gap might be too large, so the MC can't bottom out...
it could, of course, be a bad one as well. but if he didn't adjust the rod to suite the new MC+spacer that could definitely cause what you're reporting. _________________ ...david - '66 SO-44 #231 |
Posted: Sun May 07, 2017 4:13 am Post subject: Re: Problems with bleeding on Wagenswest Rabbit dual master cylinder |
Yes, the rod had the right free play.
I'm hoping that someone here has installed this unit in their bus and it works. If that is you, tell me what lines were connected to what ports.
Thanks |
jehugarcia Samba Member
Joined: October 15, 2012 Posts: 315 Location: Rancho cucamonga
Posted: Fri Aug 17, 2018 11:27 pm Post subject: Re: Problems with bleeding on Wagenswest Rabbit dual master cylinder |
having the exact same problem with the exact same cylinder. but Ive yet to try the right amount of play. _________________ www.jag35.com
www.gabvwkey.com
www.youtube.com/jehugarcia |
motofly196 Samba Member
Joined: June 01, 2008 Posts: 1467 Location: Eastern WA
Posted: Sat Aug 18, 2018 7:57 pm Post subject: Re: Problems with bleeding on Wagenswest Rabbit dual master cylinder |
Just call Nate, he always treats his customers right. Wouldn't that be easier than getting all kinds of different opinions here?
I'm using a Bay Master with a Rabbit reservoir, so I'm no help either. |
nemobuscaptain Samba Member
