vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1357 Location: Richmond, VA
Posted: Thu May 18, 2017 5:48 am Post subject: Re: Ruby Red 66 refresh. |
67ctbug wrote: |
If you want to get that blue and orange off, try acetone on a rag for a few minutes than scrub it off with the rag. |
Will that be safe on the original factory paint? I'd kind of like to strip it back to whatever is left of the original paint it left the factory with. _________________ 1973 Superbeetle: 1st car, owned since age 12. Update thread --> https://www.thesamba.com/vw/forum/viewtopic.php?p=9919140#9919140
1966 Beetle: My new project. (SOLD) Build thread--> https://www.thesamba.com/vw/forum/viewtopic.php?t=678040 |
cricketseed Samba Member
Joined: August 10, 2015 Posts: 115 Location: North Carolina
Posted: Thu May 18, 2017 9:04 am Post subject: Re: Ruby Red 66 refresh. |
vwuberalles wrote: |
Is that white on your rims a match to what they came with originally? I know the centers were originally black. |
Definitely not an exact match, just one that I determined was close enough. I don't think Wolfsburg West sells your original rim color -- which would be L87 Pearl White -- but they do have quite a few other original colors in spray cans. _________________ '66 Beetle |
pondoras box Samba Member
Joined: March 22, 2004 Posts: 1218 Location: Eerie PA
Posted: Thu May 18, 2017 12:27 pm Post subject: Re: Ruby Red 66 refresh. |
67ctbug wrote: |
Will that be safe on the original factory paint? I'd kind of like to strip it back to whatever is left of the original paint it left the factory with. |
Here you go another fun thread to read if you haven't seen it yet, there's a lot here so good for when you have a lot of time on your hands.
https://www.thesamba.com/vw/forum/viewtopic.php?t=76072 _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1961 23 Window (Bobo)
1965 11 Window (Zelda)
1965 13 Window (Lucas)
1957 Oval ragtop
1988 Cabriolet VR6 conversion
Plus a lot of other rusty junk |
Posted: Tue May 30, 2017 6:02 am Post subject: Re: Ruby Red 66 refresh. |
Fairly productive long weekend! Saturday morning I picked up the engine and interior parts and brought them home, just in time to take inventory of what I needed to look for at Bug Out on Sunday.
There's an engine in the back of my Dodge truck, so now it's basically the same as Little Red Wagon.
Engine on the stand! gonna go through it and hopefully get it back in the car soon.
Reunited with her seats! The covers are all shot but the frames are in good shape.
First time since buying it I've been able to sit in the seats and make "vroom vroom" noises!
I did a quickie rattlecan job on the wheels, it's amazing what a difference it made in the overall appearance! I've got another set I'm going to properly redo and have new tires mounted on eventually.
Rain hurt the swap meet turnout at Bug Out, but I did find a couple things. Most importantly I got my heater channels and pans! Time to make sparks fly.
my favorite part of the weekend, when you sit back and drink a beer and reflect on what you got done. _________________ 1973 Superbeetle: 1st car, owned since age 12. Update thread --> https://www.thesamba.com/vw/forum/viewtopic.php?p=9919140#9919140
Posted: Mon Jun 26, 2017 6:11 am Post subject: Re: Ruby Red 66 refresh. |
Finally got a couple things done this weekend!
I stripped my engine down to a longblock. I'm happy with the end play so I'm not going to split the case. I'll pull the heads for a thorough cleaning, then reassemble it with fresh gaskets and seals.
Degreased some parts and killed some weeds in the driveway. Multitasking!
The PO brought me the original owner's manual packet! It came from Ward Volkswagen, it's always been a Richmond car!
Sunday evening I discovered that Easy Off oven cleaner is perfect for removing the crappy respray! Sprayed it on, waited 5 minutes, rubbed it with a green scrubby pad, then rinsed with water. Back to OG Ruby red!! I wish I'd discovered this earlier in the weekend.
Posted: Mon Jun 26, 2017 12:29 pm Post subject: Re: Ruby Red 66 refresh. |
Most of the original paint on the tin looks in pretty good shape so I'm going to leave it be, but the heater boxes are rust colored. I'm debating leaving them as is or repainting them. What color would they have been painted from the factory? _________________ 1973 Superbeetle: 1st car, owned since age 12. Update thread --> https://www.thesamba.com/vw/forum/viewtopic.php?p=9919140#9919140
Posted: Wed Jul 05, 2017 7:26 am Post subject: Re: Ruby Red 66 refresh. |
Had Tuesday off, so Monday night I played in the shop. The rear apron had been replaced at some point in it's life with one from a white car that had been painted blue. It bugged me so I just hit it with some red primer for now. Looks much better, til I can find a suitable match to aged Ruby red.
Then I turned my attention to that ugly blue fender. It actually appears to be Ruby red underneath, but the blue is not budging despite all the various methods to remove it that I tried.
I've always loved the wild paintjob on the Empi Inch Pincher Too, so had the bright idea to turn my fender into a tribute to that car, If it doesn't match, might as well have some fun with it!
Then after it dried overnight I gave it a wet sanding and buffing to blend it better. Didn't come out too bad, and looks a lot better than that nasty blue!
Posted: Mon Nov 20, 2017 7:21 am Post subject: Re: Ruby Red 66 refresh. |
Haven't updated in awhile because I haven't had time to mess with it in awhile. I finally tore into the engine so I can give it a good lookover and retorque everything. I'm really glad I decided to pop the heads off to have a look inside, because I found a washer laying inside the #3 cylinder! I'm guessing it was from when the PO started tearing the engine down 20 years ago, no evidence that it ever ran with the washer there! Once I got everything torqued I started putting it back together with some fresh seals. My goal is to get it off the stand before I go visit my parents for Christmas, that way I can return the stand I borrowed from Dad.
Glad I caught this!
decapitated:
Starting to look like an engine again!
My shop assistant is thinking "You've been working on this damn thing all day, why aren't we going for a ride in it yet?"
Digger89L Samba Member
Joined: May 16, 2013 Posts: 1130 Location: Western Canada (SK)
Posted: Mon Nov 20, 2017 3:01 pm Post subject: Re: Ruby Red 66 refresh. |
Following your progress ....for pointers on my 66 project. You're fortunate to have more than half-decent bumpers front a back. Out here in mid-western Canada, most older bugs appear to have been towed by the center of the front and/or rear bumper at least once in their life!! _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Mon Nov 20, 2017 3:38 pm Post subject: Re: Ruby Red 66 refresh. |
400 bucks is quite a deal. A set of lowbacks and a set of used OG bumpers are worth more than that. Nice catch on that washer! That wouldn't have been good. Even if you don't bring this one back to perfect, it's better than it absorbing back into the earth as different forms of oxides! |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3841 Location: San Jose, CA
Posted: Tue Nov 21, 2017 12:21 am Post subject: Re: Ruby Red 66 refresh. |
Nice save, keep at it.
For what it's worth, I have a Bahama Blue '65 with all original paint in the trunk, and my defroster tubes are also completely sprayed over. Definitely factory. |
Posted: Tue Nov 21, 2017 10:06 am Post subject: Re: Ruby Red 66 refresh. |
Thanks! Yeah for the price I paid for it I figured I could easily make my money back on just a handful of parts. I can also learn on it and not feel too bad. The bumpers aren't originals unfortunately, I'm guessing they're repros from the 90s. They have the black grommets between the overrider tubes and blades. They've aged to match the rest of the car pretty well though! _________________ 1973 Superbeetle: 1st car, owned since age 12. Update thread --> https://www.thesamba.com/vw/forum/viewtopic.php?p=9919140#9919140
Posted: Tue Nov 21, 2017 7:53 pm Post subject: Re: Ruby Red 66 refresh. |
Ah hah! There goes my "Virginia is VW bumper friendly state" theory!! LOL _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
Posted: Mon Dec 04, 2017 7:50 am Post subject: Re: Ruby Red 66 refresh. |
Spent some time with the 66 this weekend. First of all I pushed it out into the yard for the obligatory Christmas photoshoot that comes with owning a red and green bug:
(the rest of the pics are in their own thread in Readers Rides; https://www.thesamba.com/vw/forum/viewtopic.php?t=690826 )
While it was out of the garage I took some new pics of it:
Then I pushed it back into the garage and got to work on buttoning up my engine!
Got it almost ready to come off the stand, but was in for an unfortunate surprise when I went to install the nice NOS German muffler that came with the car:
Turns out it's too short for my engine! I guess it must be for an earlier car or something, womp womp. I think there's an old header in Dad's shed that I can steal in a couple weeks when I'm there for Christmas at least.
Next on the agenda is to get the engine compartment cleaned up, replace the tin seal, and my axle boots while I have easy access. Then the motor can go back in! _________________ 1973 Superbeetle: 1st car, owned since age 12. Update thread --> https://www.thesamba.com/vw/forum/viewtopic.php?p=9919140#9919140
ADDA Samba Member
Joined: December 27, 2011 Posts: 19 Location: Geordieland UK
Posted: Mon Dec 04, 2017 10:00 am Post subject: Re: Ruby Red 66 refresh. |
You're a hero in my book saving another Beetle it breaks my heart seeing them lying neglected and unloved |
ADDA Samba Member
Rome Samba Member
Joined: June 02, 2004 Posts: 9640 Location: Pearl River, NY
Posted: Mon Dec 04, 2017 4:40 pm Post subject: Re: Ruby Red 66 refresh. |
Very clever idea with the Inch Pincher Too's paint graphics for your right rear fender paint scheme.
Nice work with your "quickie" 2-tone spray can wheel painting. IMO the original 2-tone scheme looks best.
Your new muffler would be a 40hp fresh air. It's narrower due to the crankshaft having 64mm stroke; 5mm shorter stroke than your 1300's 69mm on both sides of the engine = 10mm total =~ 1/3". Though in your shot the lost space looks a bit more than 1/3".
From the body/paint Forum on theSamba, a close color match to Ruby Red is Rust-o-leum Regal Red. You could buy a spray can to mist over some of your bare areas. https://www.thesamba.com/vw/forum/viewtopic.php?t=424324
Thinking about a quick freshening up of the rust on the bumpers using balled-up aluminum foil and Coke? 10 minutes each would make a big difference, then paint over with gloss clear for rust protection.
Do you or your family have a tie to the city of Viersen Germany, per the VIE lic. plate on the green Beetle? |
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2325 Location: Cleveland, OH
