Body rubber
4118thing
4118thing is offline
PostPosted: Fri May 05, 2017 6:25 pm    Post subject: Body rubber Reply with quote
I have the body off, replacing the pans, and am ready to place it back on. Since I did not take the body off, I don't know what rubber was there.
My questions are:
1. What rubber fits between the body, and the chassis? Where is it available? Any pictures appreciated.
2. Read in a search, that there is rubber between the body and pan. True? Where available? Pictures?
The pieces that were taken off, bolts, etc. did not have any rubber.
Thanks in advance for your help.
Ron Domeck
Ron Domeck is offline
PostPosted: Fri May 05, 2017 7:05 pm    Post subject: Re: Body rubber Reply with quote
From the factory was a sticky tape seal. The replacement part is a pan seal from a Beetle. you can also use topper tape from trucks. If you use the Beetle part be sure they list it to be long enough for a Thing or Ghia. The Thing Shop has a seal in their listing.
Ron Domeck
PostPosted: Fri May 05, 2017 7:18 pm    Post subject: Re: Body rubber Reply with quote
The Thing Shop $16.00.
4118thing
PostPosted: Fri May 05, 2017 7:28 pm    Post subject: Re: Body rubber Reply with quote
Is this between the body and pan, or the body and crossmembers, or both? By crossmembers, I mean the lateral section ahead, and behind the pan.
Wildthings
Wildthings is offline
PostPosted: Sat May 06, 2017 2:58 am    Post subject: Re: Body rubber Reply with quote
Are you talking about these?
http://www.cbperformance.com/product-p/6290.htm
4118thing
PostPosted: Sun May 07, 2017 11:21 am    Post subject: Re: Body rubber Reply with quote
Yes, that an any other help, I can get.
Ron Domeck
PostPosted: Sun May 07, 2017 5:09 pm    Post subject: Re: Body rubber Reply with quote
OK, body pads. Thing Shop has these for $2.25 ea. takes 6 and also at the front is 2 more under the metal plates for $2.30 ea.
