Dash76 Samba Member
Joined: November 09, 2016 Posts: 23 Location: Denmark
Posted: Sat May 06, 2017 1:35 pm Post subject: Newbie Clutch/Gear Issue |
The weather was good yesterday so I decided to drive my '69 Karmann to work, but came home with the help of a tow truck.
The problem is that taking off from the traffic lights, I went from 1st gear but couldn't get in to 2nd (or any other gear for a matter of fact). The only gear I could remotely find was reverse but it would just grind and not engage, so I didn't push it further. Strangely, after getting home, with the engine not running, I could locate the gears. As and added kick while I am down, after being towed about 1 mile, Karmann wouldn't start so I don't know if it would engage when running.
I checked the clutch cable and it is not broken. Somewhere mentioned the gear shift coupler too. I looked at that and the 'pin' seems to move depress the clutch and move the gear stick. The reality is though, i don't know what I am supposed to be looking for.
Any smart ideas? Am I simply up for a new clutch? Any insight a source to why the car won't fire up after a very short tow? It turns over but just doesn't quite get started. |
rcooled Samba Member
Joined: September 20, 2008 Posts: 2507 Location: Santa Cruz, CA
Posted: Sat May 06, 2017 2:36 pm Post subject: Re: Newbie Clutch/Gear Issue |
Sounds like the clutch isn't fully disengaging when you try to shift gears. How much free play (amount of travel before you start to feel resistance) do you have at the clutch pedal? There should be about 1/2"-3/4" (12-19mm) if everything is adjusted correctly. Even though you said that the clutch cable isn't broken, a couple of the cable strands might've snapped and allowed the cable to stretch a bit. Another issue could be that the clutch cable guide tube in the tunnel might've come loose from one of it's mounting points. Either one of these conditions will result in much more free play at the clutch pedal and could cause the shifting problem you described. _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Sun May 07, 2017 8:25 am Post subject: Re: Newbie Clutch/Gear Issue |
I know that ADJUSTING THE SHIFTER PLATE ...
... can often cure the problem of grinding into a specific gear, but I'm not certain if it can help when there is grinding into most of the gears.
As you can see from the video linked above, adjusting the shifter plate is pretty simple and straight forward so it may be worth giving it try. |
xzener Samba Member
Posted: Sun May 07, 2017 11:01 am Post subject: Re: Newbie Clutch/Gear Issue |
Yes, after installing the shifter, many times there will be shifting issues. It's usually as easy as adjusting the plate as KGCoupe stated above. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Dash76 Samba Member
Posted: Mon May 08, 2017 12:55 am Post subject: Re: Newbie Clutch/Gear Issue |
Thanks. The is a bit over an inch of free play in the clutch, so the easiest maybe to tighten that up either via the cable or plate. I'll try to find time to look this.
It is not that it grinds getting into gear, it is more that it simply won't go in to gear when the motor in running. It did feel like it 'popped' out of gear before the last gear change then simply not re-engage.
It seems the consensus is though, it doesn't seem to be the clutch is completely gone? |
CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Mon May 08, 2017 2:41 am Post subject: Re: Newbie Clutch/Gear Issue |
Dash76 wrote: |
If your shifter is popping out of gear, I strongly suggest you try what was already suggested by xzener and check the shift plate. It just may be the cause of most of your problems. _________________ ----------------------
Cars Currently Owned:
1970 Karmann Ghia Coupe
1973 Karmann Ghia Coupe - Project car for sale
1970 Karmann Ghia Convertible (Body off restoration)
Timing is everything |
Dash76 Samba Member
Posted: Wed May 17, 2017 11:47 am Post subject: Re: Newbie Clutch/Gear Issue |
So this all sounds promising and not like the whole gearbox like I feared.
I'll keep you updated as I move along but are having other issues with the car (subject of another thread) and also struggling to find time to tinker. |
