New VC gasket, now a much bigger issue
rockerarm
rockerarm is offline
PostPosted: Tue May 09, 2017 2:19 pm    Post subject: Re: New VC gasket, now a much bigger issue Reply with quote
fl59bug wrote:
This makes me want to install a VDO oil pressure gauge. I'm thinking a good gauge would be cheap insurance and allow one to catch the issue much earlier.
Car manufacturers went to an idiot light warning because it was easier to view a bright lite on the dash vs a gauge that dropped from 40 to 0.
rockerarm
PostPosted: Tue May 09, 2017 2:24 pm    Post subject: Re: New VC gasket, now a much bigger issue Reply with quote
Hi. I don't use any sealants on VC gaskets for the type 1 engine since I'm still able to buy quality gaskets. As a dealer mechanic I rarely had issues with genuine gaskets. Working at independents was a different story as lower quality gaskets would be provided and having to avoid a come-back would necessitate some sort of sealant. Boy, I hated scrapping off that shit material as I was having to "work with" low quality gaskets so my boss maximized his profit.
KTPhil Premium Member
KTPhil is offline
PostPosted: Tue May 09, 2017 2:48 pm    Post subject: Re: New VC gasket, now a much bigger issue Reply with quote
Two more thoughts...
1) Any chance you used a box cutter to open the gasket package, making two parallel cuts that you didn't realize went through to the gasket? Or maybe the seller did this originally?
2) Some VC covers have the ridge to keep the gasket from sagging at the top, some don't. Those without the bump really need some glue, at least at that point, to keep it from dropping down when the bale is tightened.
Pruneman99
Pruneman99 is offline
PostPosted: Tue May 09, 2017 4:40 pm    Post subject: Re: New VC gasket, now a much bigger issue Reply with quote
I've been putting a very light coat of grease on mine for years. Not thick, just enough to discolor it I guess you can say. Only time I had a leak is when I used a valve cover out of the parts box that had a bent section I didn't notice. I've never seen one come out in chunks that didn't come out of an engine that was sitting for years. Are you sure that one wasn't damaged beforehand? It looks like it split lengthwise on the top and bottom section as well.
I don't like any kind of glue because it can be a pain to clean off, and damages the gaskets upon disassembly. Grease coated come off clean, and normally I reuse them unless they look "tired".
Sorry to see this happened to you. Hope you got it shut down before any major damage occurred.
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Tue May 09, 2017 5:17 pm    Post subject: Re: New VC gasket, now a much bigger issue Reply with quote
Man that really blows I'm sorry to hear that. I've seen an audible oil pressure warning, buzzer sounds at pressure loss this allows you to keep eyes on the road instead of watching a light. Water under the bridge I know. I started sticking the gasket to the cover using Gaskacinch Aka gorilla snot because it works and cleans up easy. My first thought was Mrs. Cusser driving with no oil and the engine lived several more years, these are tough little bastards and maybe you'll be ok. Refill pre oil and see what you've got. Also people used to weld tabs onto valve covers to keep the gasket from getting sucked in. Fel
Pro used to make a reusable gasket, I've seen them top quality.
67rustavenger Premium Member
67rustavenger is offline
PostPosted: Tue May 09, 2017 5:47 pm    Post subject: Re: New VC gasket, now a much bigger issue Reply with quote
Ok Thanks for all of the input guy's.
Yes the gaskets were/are stored in the attic. I have a one car garage and space it tight.
The gaskets are sealed in the original plastic wrapping. and yes I cut the package open with a razor knife. No I did no even come near the gasket while cutting the package open. Just cut it near the edge and tore it open from there.
The VC and gasket posted by Bill is not mine. Mine are clean and metallic in appearance inside.
For the last couple of years I have not used any sealant on the VC gaskets. Just remove the old one and clean the gasket flange on the VC and install the new gasket dry. That's the way I'm gonna install the new one once I roll the car out of the garage tonight after I get the new screen and gaskets from the FLAPS. What I did while greasing the VC gasket was bend the gasket beyond tolerance likely fracturing it before the install. When I had the bail on the VC I wiggled it in the thought that it would center the gasket. It's likely here where it broke into the four pieces.
A new filter will be fitted and new 10-30w synthetic will be poured in and I'll look for static leaks before cranking to build pressure HT lead of the coil. Once I get pressure(hopefully) I'll fire it up and see where I stand.
Thanks for all of your concerns. I'll let you know what the outcome is.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
Pruneman99
PostPosted: Tue May 09, 2017 5:55 pm    Post subject: Re: New VC gasket, now a much bigger issue Reply with quote
When I grease the gaskets, I lay them in the valve cover, do one side, then flip it over. The light grease actually makes it stick pretty well while I do the other side. When I fiddle them into place, they generally stay put real well.
I guess you have to stick to what works for you. I think everyone has their favorite technique for keeping the drips at Bay.
PostPosted: Tue May 09, 2017 8:28 pm    Post subject: Re: New VC gasket, now a much bigger issue Reply with quote
Ok so I did all as described in my last post.
Fired it and it ran without any odd noises. But that was only for a minute. I have a bitchy neighbor that hates my hobby. I'll drive the car to work tomorrow and see what's up.
I do have VDO gauges and at 80-85mph on twisting mountain roads it's a bit difficult to scan gauges and not run off the road.
I did think about Mrs. cusser's engine. I seriously doubt she drives her engine at the top end of the RPM range in high gear on twisting mountain roads. But stranger things have happened.
Thanks all. Have a great night.
Buy Once, Cry Once!
calvinater
calvinater is offline
PostPosted: Wed May 10, 2017 2:54 am    Post subject: Re: New VC gasket, now a much bigger issue Reply with quote
Is this the same engine that caught on fire?
"Albatross"!
KTPhil is offline
PostPosted: Wed May 10, 2017 8:21 am    Post subject: Re: New VC gasket, now a much bigger issue Reply with quote
So far, so good!!
fl59bug
fl59bug is offline
PostPosted: Wed May 10, 2017 9:54 am    Post subject: Re: New VC gasket, now a much bigger issue Reply with quote
I've never asked, but does the idiot light only come on once the pressure drops to dangerously low levels or zero? I guess I'd want the gauge to alert me to the issue before it got so low.
rockerarm
PostPosted: Wed May 10, 2017 10:34 am    Post subject: Re: New VC gasket, now a much bigger issue Reply with quote
Yes, especially if your on the throttle.
Pruneman99
PostPosted: Wed May 10, 2017 11:42 am    Post subject: Re: New VC gasket, now a much bigger issue Reply with quote
Has anyone installed something like this?
http://www.starmarinedepot.com/sierra-warning-kit-...fgodiBULEw
After a quick search it seems like there was a bunch of similar things related to marine applications. A loud buzzer might alert the driver better than that tiny light.
Either modify something like this or come up with a circut in case of oil pressure loss while driving, but not during the starting sequence.
Cusser
Cusser is offline
PostPosted: Wed May 10, 2017 12:35 pm    Post subject: Re: New VC gasket, now a much bigger issue Reply with quote
Pruneman99 wrote:
Has anyone installed something like this? A loud buzzer might alert the driver better than that tiny light.
Either modify something like this or come up with a circuit in case of oil pressure loss while driving, but not during the starting sequence.
In the VW world, almost always "somebody" has tried just about "everything".
I would be wary of the buzzer buzzing every time I came to an idle after high speed driving.
That said: I did wire up a Radio Shack 12 volt buzzer as a headlight-on reminder, here's what I did, maybe someone can elaborate how to use something like this for low oil pressure. I think I could figure this out but would lose my warning light if I used the stock oil pressure switch (a "normally open" switch which closes when pressure is low to complete the circuit).
Radio Shack 12 volt buzzer as headlight-on reminder. The + positive wire went to the headlight circuit to be energized when it was on, and the - negative wire went to something that was energized (live) with the key on, like the wiper circuit. Then, when you turn the key off, the wiper circuit goes dead and grounds the buzzer, causing it to make noise....
PostPosted: Wed May 10, 2017 4:21 pm    Post subject: Re: New VC gasket, now a much bigger issue Reply with quote
Yes I mentioned that before I had this on a car and it worked well. Actually it came on every time you turned the key to power up but went off soon as Engine primed. I thought it was a good idea and it saved me once when the filter pump over pressurized and blew out the o ring from oil filter. I was on it going into third when the horn sounded. 1776 dual kads 67 bug ... This may have saved me.
PostPosted: Wed May 10, 2017 5:26 pm    Post subject: Re: New VC gasket, now a much bigger issue Reply with quote
A buzzer/horn is a good idea. And more than likely would have alerted me to the no pressure condition.
I'm torn between just driving it and possibly damaging it further. And tearing it down.
In my mind, I can't justify running it and damaging it further. When with care and careful inspection I may just need new bearings and rings to get back in fighting condition. The case was new at the build and has less than 20K on it.
Last time I checked. I had a weak #1 cylinder likely a exhaust valve issue. So this may have been a fortuitous moment.
I do have a spare engine I can throw in and keep driving. But it's an unknown build. It came with my other 67. It does start right up whenever I ask it to do so. But I have never driven this engine on the road. For sure it will be a BORING bone stock POS SP engine. But hey, I'll get better fuel mileage Shocked
I know it's my engine and ultimately my decision whether to go through it and bring it back to reliable condition. And sound of mind on my part.
Buy Once, Cry Once!
PostPosted: Wed May 10, 2017 5:38 pm    Post subject: Re: New VC gasket, now a much bigger issue Reply with quote
I'm in your corner worst case scenario there's little to nothing wrong, but you have that nagging doubt in the back of your mind of you don't make sure. Nothing wrong with knowing what you've got Very Happy all hands on deck ready to help and lend support.
Cusser
Cusser is offline
PostPosted: Wed May 10, 2017 5:48 pm    Post subject: Re: New VC gasket, now a much bigger issue Reply with quote
If mine, I would correct bad VC gaskets, add oil, and drive it. And change the oil in a day or two. Remember: people here (like me) have had much harder material in their engines and no issues, like hard plastic fuel pump stand pieces.
And I even had slivers of main bearing #2 on my oil screen after all the oil drained out, we still drove that engine 3 more years. And you stopped right away once you saw your warning light, you didn't drive 3 more miles until it stalled out like Mrs. Cusser did !!!
Don't be a girly-man, bets are high that your engine will be fine. If you want, spring for a Maxi2 oil pump/filter, that will catch any stuff in your oil/engine.
If you've got time, true that an engine gasket kit and front seal aren't very costly...but never trouble trouble until trouble troubles you !!!
PostPosted: Wed May 10, 2017 5:54 pm    Post subject: Re: New VC gasket, now a much bigger issue Reply with quote
Cusser makes a very compelling argument.
PostPosted: Wed May 10, 2017 5:56 pm    Post subject: Re: New VC gasket, now a much bigger issue Reply with quote
Thank you Jim.
The engine is just so much damn fun to drive when I have it running correctly.
It's been 20 years since I built an engine. So I'm a little rusty on the specifics. But I have a couple of manuals that will lead me correctly. Plus the support of folks like yourself.
Anterior motive is that I'm curious as to what the builder did to this engine to have it stand up to my abusive driving habits.
And yes there's that little voice in my head that will keep telling me it might fail at any time. It's not a very friendly voice.
Buy Once, Cry Once!
Page 2 of 4
