jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Mon May 08, 2017 10:31 am Post subject: gas in oil: from leaking carburetor(s) or past rings? |
I am refurbishing an essentially all-original 1972 Sportsmobile, with its original 1700 engine and carb setup, to boot.
This bus has sat for a long time -- probably did not move for 20 years. Colin and I got it fired up at the end of last summer, and I had not done much with it over the winter, but spring is here, and my goal is to bring it to a level that we could make the August trip to southwest Colorado for the bus bomb trip up from Durango.
Done before/with Colin:
- new fuel lines
- oil and filter change
- valve adjustment
- cleaned out air cleaner (cool 1972 oil bath bucket type)
- basic timing adjustment
At that time, the bus ran, held idle, but seemed sort of gutless. We did the remove-the-spark-plug-wire-at-the-rotor-for-each-cylinder-to-see-if-it-is-contributing trick, and decided that a couple of cylinders were not contributing. Fresh spark plugs and wires might do the trick, but we were out of time.
Done this spring:
- new spark plugs and wires (old plugs were black and sooty)
- replaced several cracked vacuum elbows
- fresh gas
It drives about the same, and I can definitely say that cylinders 2 and 4 are doing all the work, while 1 and 3 are doing nothing.
Then I had a thought: I should not drive this much if these cylinders are not firing, because that is just squirting gas into the cylinders and it might damage them -- certainly the oil would be made less effective.
So I go to sniff the oil dipstick. Ah - definitely gasoline. This does not make a good lubricant.
Now I am wondering - Is the gas in the oil due to gasoline introduced into and not burned win the 2 dead cylinders, or could it be from a leaking carburetor? How could I tell?
Note that it is one cylinder on each side that is dead, so this does not point to just one carb or the other needing attention.
So, I'm looking for another test to fix the gas-in-oil situation, so that I can change the oil and not have to worry about more getting in there. So, I would like to pose a couple of questions:
1. Would the amount of gasoline mixing into the oil from non-firing cylinders amount to enough that I could smell it in the crankcase oil?
2. Is there a simple test to see if the carburetors are leaking? I was thinking:
A. See if the oil level is rising with time with the bus sitting still, and
B. unbolt the cylinder [edit] carburetor and set it on a piece of cardboard or something (still in place), and see if it is draining gas through the bottom.
All constructive thoughts appreciated! _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
aeromech Samba Member
Joined: January 24, 2006 Posts: 16961 Location: San Diego, California
Posted: Mon May 08, 2017 11:26 am Post subject: Re: gas in oil: from leaking carburetor(s) or past rings? |
B. unbolt the cylinder and set it on a piece of cardboard or something (still in place), and see if it is draining gas through the bottom.
I think you mean carburetor. Might work if you leave it hooked up to the fuel line. It's the head pressure from the tank that overcomes the carburetor needle valve.
Have you tried doing a compression test? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Joined: August 31, 2013 Posts: 12848 Location: North Carolina
Posted: Mon May 08, 2017 11:28 am Post subject: Re: gas in oil: from leaking carburetor(s) or past rings? |
More than likely it's from a ruptured diaphragm in the fuel pump. The fuel will then continue to drip into the crank case, when it gets full enough, it will seep past the rings & foul the plugs upon start up. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Mon May 08, 2017 12:21 pm Post subject: Re: gas in oil: from leaking carburetor(s) or past rings? |
Twenty plus year old carbs need to be kitted, period. Even if they weren't giving problems today they might very likely fail tomorrow. You don't need either a bus fire or a seized engine.
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Mon May 08, 2017 1:06 pm Post subject: Re: gas in oil: from leaking carburetor(s) or past rings? |
My friend had an issue with his factory dual carb bus dripping with the original carbs; he didn't drive it often either.
Here is a video of the fuel dump after shutting down the engine. Hopefully yours isn't this bad:
_________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
jtauxe Samba Member
Posted: Tue May 09, 2017 6:05 pm Post subject: Re: gas in oil: from leaking carburetor(s) or past rings? |
TDCTDI wrote: |
More than likely it's from a ruptured diaphragm in the fuel pump. The fuel will then continue to drip into the crank case, when it gets full enough, it will seep past the rings & foul the plugs upon start up. |
Well, that's a possibility. I am using the original fuel pump. I wonder how i could test that without pulling the pump and inspecting it...
Wildthings wrote: |
Twenty plus year old carbs need to be kitted, period. Even if they weren't giving problems today they might very likely fail tomorrow. You don't need either a bus fire or a seized engine. |
Yes, I expect you are right.
I was perhaps overly optimistic that I could just make this thing run and go! It's never like that, of course. Never. Ever. _________________ John
http://vw.tauxe.net
jtauxe Samba Member
Posted: Sat May 20, 2017 3:07 pm Post subject: Re: gas in oil: from leaking carburetor(s) or past rings? |
Any thoughts from folks on how to evaluate the health of the original fuel pump? _________________ John
http://vw.tauxe.net
wihr Samba Member
Joined: August 15, 2010 Posts: 344 Location: PORTLAND, OR
Posted: Sat May 20, 2017 3:47 pm Post subject: Re: gas in oil: from leaking carburetor(s) or past rings? |
I had the same problem when I used to park nose high on a relatively steep hill. I would leave my bus for a few weeks and would find the oil reeking of gasoline. I never solved the problem, but I am sure it was the carburetor. I do not live on a hill now and park my bus in a garage. No problems.
WW _________________ WIHR
1970 Campmobile "Van Ordinaire"
2009 Lincoln Town Car "Behemoth"
1969 Lambretta 150 DL "Nina"
1962 Matchless G 12 CS 650cc |
