Cusser Samba Member
Joined: October 02, 2006 Posts: 31266 Location: Hot Arizona
Posted: Wed May 10, 2017 9:17 am Post subject: VW Pedal Assembly information in the Orange Bentley manual? |
I may need to replace the clutch pedal hook part in my 1970, and haven't done this job in a decade. So I tried to find information in my Orange 1970-1979 Bentley manual - which, of course, has no index, and I couldn't find it. Actually, I find that finding things in that manual is difficult.
So if anyone can detail exactly what chapter and page number this is found, I'd appreciate that !!! Thanks. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11739 Location: Redding, CA
Posted: Wed May 10, 2017 9:25 am Post subject: Re: VW Pedal Assembly information in the Orange Bentley manual? |
Brakes and Wheels. Page 30.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Posted: Wed May 10, 2017 9:34 am Post subject: Re: VW Pedal Assembly information in the Orange Bentley manual? |
The Haynes manual has a lot more How-to detail, but once you get the pedal cluster out, clutch shaft removal is basically a matter of driving out the pin, then pulling the shaft out.
I took it all apart and greased everything that touched metal. Once done, the clutch moves like butter.
Richard O'Brien |
johnR Samba Member
Joined: August 25, 2009 Posts: 668 Location: Virginia
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Wed May 10, 2017 10:54 am Post subject: Re: VW Pedal Assembly information in the Orange Bentley manual? |
(edited to remove impertinent information . . . I misread the question.) _________________ Jesucristo es mi Seņor y Salvador!
MSBenko Samba Member
Joined: January 31, 2017 Posts: 90 Location: Winter Haven, FL
Posted: Wed May 10, 2017 11:02 am Post subject: Re: VW Pedal Assembly information in the Orange Bentley manual? |
This is Awesome! I have always wondered if someone makes a kit to move both the clutch and brake away from the accelerator. I don't mind how close the break and clutch are, but they both should move to the left a little. _________________ Mike
75 Standard Beetle
72 Standard Beetle (first car) sold in '96 |
johnR Samba Member
Posted: Wed May 10, 2017 11:23 am Post subject: Re: VW Pedal Assembly information in the Orange Bentley manual? |
Th kit only moves the clutch pedal over. The brake remains in the same position. |
Cusser Samba Member
Posted: Wed May 10, 2017 11:48 am Post subject: Re: VW Pedal Assembly information in the Orange Bentley manual? |
Tim Donahoe wrote: |
Tim |
Thanks, Tim - figured it was "somewhere". How silly of me not to think that clutch pedal R&R would be under "Brakes and Wheels" !!!
Still think the Bentley needs an Index...
I have considered that, think it's a great idea. However, I already have a new traditional pedal hook, so I'll go that route. With the number of miles I expect to put on this 1970, and the factory clutch hook has lasted 260+K so far, I think original design will suffice for me.
Yes, I have a "used" finger-type pressure plate on this that takes a fair amount of pedal pressure, and I'm at the end of adjustment on my 1979-installed clutch cable. So using my practice of "fix FIRST what you KNOW is bad", the worn clutch hook (and old cable) are first to be replaced.
The pressure plate will be replaced with new Brazilian unit next time the engine is out, pretty sure I don't want to remove exhaust and shove engine rearwards (or remove engine entirely) replace the PP. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Wed May 10, 2017 12:51 pm Post subject: Re: VW Pedal Assembly information in the Orange Bentley manual? |
I think that Bently was written to intentionally confuse home mechanics so they'd just take the car--and the problem--to the dealer. Thus, the "Idiot" book was there to simplify what Bently made more difficult.
Richard O'Brien |
calvinater Samba Member
Posted: Wed May 10, 2017 2:04 pm Post subject: Re: VW Pedal Assembly information in the Orange Bentley manual? |
I still think Vernoc is the one to write up an index for Bentley. Ya out there Vernoc? _________________ "Albatross"! |
sawitt Samba Member
Tim |
I don't think this is the reason. In my experience (since the '70s), nearly all auto and motorcycle workshop manuals I've ever had, from several different manufacturers from Europe and Japan organize the manuals this way. I've never understood it, because it makes finding things much more difficult IMHO than a comprehensive index would. I don't know the reason, but it seems that this is the style the workshop manuals have taken for many years now. Maybe school-trained factory mechanics become so familiar with the manual that they don't need an index for the whole manual, maybe the manuals are published in separate books, one book per section so an overall index doesn't make sense. I think the Bentley is a condensed version of the factory workshop manual -- I don't know as I've never seen the official VW factory manual. But I was, just this morning, trying to find the accelerator cable adjustment procedure in the Bentley and finally after about 15 min. of searching found it in the Fuel Injection Section (for a '78 Super Beetle). I probably should have realized that that is the section it would be in, but I just don't have to reference the Bentley enough to remember where everything is. I'm sure somebody knows why workshop manuals are organized this way, but I sure don't. |
Posted: Wed May 10, 2017 3:29 pm Post subject: Re: VW Pedal Assembly information in the Orange Bentley manual? |
johnR wrote: |
I know. I like the idea of moving the clutch. What I meant was that I wish someone would design a kit to move both pedals. On occasion my foot will hit the edge of the brake pedal on the way to the accelerator. I have wide feet. _________________ Mike
75 Standard Beetle
vernonc Samba Member
Joined: April 23, 2012 Posts: 681 Location: Parkersburg, WV..yes, I sold the boat
Posted: Wed May 10, 2017 4:08 pm Post subject: Re: VW Pedal Assembly information in the Orange Bentley manual? |
calvinater wrote: |
I still think Vernoc is the one to write up an index for Bentley. Ya out there Vernoc? |
Yah, I'm here. However, I don't think you want me to try and organize anything 'cause I got the same problem Tim, Cusser and several others have; here, at the marina, we call it "Oldtimer's Disease". Often times I walk into the boat and start 'Thinking about the Hereafter'; like 'what was it that I came in here after'. Anyhow, I have the same problem with the Bentley so I only use it as a last resort and, often times, I don't even do that. That's why, if you have read some of my posts, I ask some stupid questions 'cause I couldn't find answers in the book. But, you all have always helped me out.
By the by, Elwood is all serviced, polished, gassed and ready to hit the road for some more Summer trips through West Virginia. Last Summer we rolled up over 7000 miles; hope to do as much or more this Summer.
Well, got a go..........gettin' time for an old movie but I'll leave you all with another saying we have here at the marina.....Gettin' Old Ain't for Sissy's.
mort _________________ "Those who don't read newspapers are un-informed. Those who do read newspapers are mis-informed." Will Rogers
'69 sedan, low mileage, all original.....currently being 'freshened-up' for road trips and daily driving...just not every day
Freshening-up link http://www.thesamba.com/vw/forum/viewtopic.php?t=617386
Cusser Samba Member
Posted: Wed May 10, 2017 4:11 pm Post subject: Re: VW Pedal Assembly information in the Orange Bentley manual? |
I have used the out-of-print poorly-bound Clymer repair manual for years, like that the best.
However, after reading many here praise the Bentley manual, caved in and bought a used copy on Ebay....still like Clymer better !! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Wed May 10, 2017 4:13 pm Post subject: Re: VW Pedal Assembly information in the Orange Bentley manual? |
My shoe size is only nine and one-half, so my feet are okay with the stock pedal arrangement; however, when I drive the bug, I only wear certain shoes. These are not wide, clunky rubber sport shoes, but more like a dress shoe, which is much thinner in width.
I also don't drive the bug while wearing sandals, which is a bitch on hot summer days. The pedals just don't feel the same while wearing sandals, and I end up not working them--the pedals--with the same precision.
Richard O'Brien |
allenw Samba Member
Joined: September 20, 2016 Posts: 221 Location: Dalton, GA
Posted: Wed May 10, 2017 4:52 pm Post subject: Re: VW Pedal Assembly information in the Orange Bentley manual? |
I must have thin feet, work boots, runners or bare feet all work the same on the pedals. |
baldessariclan Samba Member
Joined: October 14, 2016 Posts: 1351 Location: Wichita, KS
Posted: Thu May 11, 2017 8:52 am Post subject: Re: VW Pedal Assembly information in the Orange Bentley manual? |
Here's a link to an "unofficial" index for the Bentley manual (from Rob and Dave's Aircooled VW page):
http://www.vw-resource.com/bentley1.html
May not have everything you want/need, but still find it fairly useful at times. I copied the text and edited slightly to make a printable version -- keep a couple hard copies lying around or tucked in the book. |
Cusser Samba Member
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13842 Location: White Mountains Arizona
Posted: Thu May 11, 2017 11:23 am Post subject: Re: VW Pedal Assembly information in the Orange Bentley manual? |
Say won't Mrs Cusser be doing most of the driving on the vehicle?
What you could do would be take that to a weld shop in your area and have them just build up the area where the hook goes. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2645 Location: Long Island, NY
Posted: Thu May 11, 2017 11:35 am Post subject: Re: VW Pedal Assembly information in the Orange Bentley manual? |
Tim |
I'm in the same boat, but a size 11D. I need more clearance between the gas and brake pedals, especially with certain (most) shoes. As it is, my shoe hits either the tunnel or the brake pedal when I'm on the gas, and requires frequent adjustment. |
