My 61 Bug Samba Member
Posted: Wed May 10, 2017 12:36 pm Post subject: Split bus front brake hose |
Hi All,
Sorry if this has been asked before but on the front drum brakes in a Split should the flexible brake hose be connected to the top or bottom wheel cylinder? At present mine is connected to the bottom but when you turn the steering is doesn't look correct. Or does anyone have photos of theirs please. Thanks. |
johny__utah Samba Member
Joined: September 02, 2008 Posts: 426 Location: Arizona/California
Posted: Wed May 10, 2017 1:14 pm Post subject: Re: Split bus front brake hose |
Stock should be on top, unless its a lowered Bus. Double check in the gallery section though. Any Bus category, type in brakes.. _________________ 1956 L31
1961 L346 L347
1963 L380 L289 |
thomas. Samba Member
Joined: July 31, 2010 Posts: 1291 Location: South West (Pa.)
Posted: Thu May 11, 2017 3:00 am Post subject: Re: Split bus front brake hose |
I just finished doing my fronts recently and like Johny Utah said , the hose goes to the top wheel cylinder. There should also be a guide bracket that the hose goes through before it attaches to the wheel. I'm on a tablet computer without access to my photos but if you do a search in the "Gallery" section on this site there should be something. Good luck. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Tue Aug 03, 2021 6:50 pm Post subject: Re: Split bus front brake hose |
Anyone have an off-the-shelf part for the spacer to hold the hose?
Hose O.D. is 10mm. Holder I.D. is 15mm.
Bentley Manual shows split surround installed after the hose it appears. The part is not listed in the parts manual.
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4572 Location: St Charles, MO
Posted: Tue Aug 03, 2021 8:54 pm Post subject: Re: Split bus front brake hose |
If your split rubber is missing from that hose holding bracket, you could cut a strip of bicycle inner tube and wrap it around the hydraulic brake hose a few times until the brake hose is snug (not too tight).
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1786 Location: Cleveland, Ohio
