Speedo Ribbon Cable
Forum Index -> Water-cooled VW Share: Facebook Twitter
spacebiscuit
spacebiscuit is offline
PostPosted: Thu May 11, 2017 3:53 am    Post subject: Speedo Ribbon Cable Reply with quote
Hi,
Does anyone know what this blue ribbon cable is for - looks like it should slot into a piece that says "abgriff" on the bak of the speedo.
The "abgriff" piece is levered as if the ribbon should slotted in and then be held by the lever but there is no tension to hold it and I am worried it might come lose once the dashpod is put back in.
Any ieas?
Thanks,
Rob.
crsmp5
crsmp5 is offline
PostPosted: Thu May 11, 2017 10:36 am    Post subject: Re: Speedo Ribbon Cable Reply with quote
piece in the spedo head breaks out for a cruise control speed sensor... no idea what the pcb goes too.. but it does NOT goto it
[url=http://cdn2.driiive.com/7037.jpg]Click to view image[/url]
kamzcab86
kamzcab86 is offline
PostPosted: Thu May 11, 2017 6:08 pm    Post subject: Re: Speedo Ribbon Cable Reply with quote
The ribbon is normally attached to a speed (aka Hall) sender for a Golf II-era (often MFA) cluster (part #321907345B).
Pics and install instructions here: http://forum.sciroccoregister.co.uk/viewtopic.php?f=11&t=404 .
~Kamz Anxious
2016 Golf GTI S
Butcher
Butcher is offline
PostPosted: Fri May 12, 2017 6:51 am    Post subject: Re: Speedo Ribbon Cable Reply with quote
Like the others said and abgriff is German for pickup [signal pick up].
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
