madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Sun May 14, 2017 4:52 am Post subject: slider |
Is anyone going to the Vintage fest in Yipsi that can show/help me adjust this sliding door on my 70 Bay? Spike? _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
aeromech Samba Member
Joined: January 24, 2006 Posts: 16959 Location: San Diego, California
Posted: Sun May 14, 2017 7:29 am Post subject: Re: slider |
You can find that info here or in your shop manual _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Mon May 15, 2017 6:45 am Post subject: Re: slider |
I am currently planning on showing up. It is mainly a bunch of fiddling from my experience, not really a set procedure. But I should be able to help _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Mon May 15, 2017 8:50 am Post subject: Re: slider |
my night mare ended when we figured out the bores the "U" bolt rode on were egged shaped. this allowed it to sag and not close right and ended up with 2 broken claw n cam bits- (I know- slow learner) also found the return spring on the claw bolted to the body was missing.
There was a recent post here that covered the whole thing from top to bottom. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Posted: Mon May 15, 2017 10:30 am Post subject: Re: slider |
http://www.itinerant-air-cooled.com/viewtopic.php?f=49&t=9182
Do you have a difficult-to-move handle on your post '73 bus?
Did you know that the resistance you experience is actually a coiled-up spring installed precisely to give you thatr resistance? Who wudda thunk?
Step 1) Remove Door Panel.
Start at a healthy section and pull out as close to a determined clip location as possible.
Before proceeding, please re-glue the entire perimeter of the vinyl to the masonite panel. I'll wait here . . . . .
Step 2) Release Cable and Return Spring Anchor
Remove C clip from cable end in front latch. Gently pull cable sheath out of plastic retainer midway. If retainer is broken, procure a wire tie for reassembly. There should be a foam block at the middle point, and at the forward third of the cable sheath. If yours are damaged or missing, cut a couple of 2" blocks out of the mattress in the guest bedroom.
Release cable end from forward latch assembly. There is a preload so don't freak if the latch actuator springs away a bit. Loosen the 10mm locknut that holds the cable sheath to the latch bracket. Do not disturb the adjustment if your door has been working correctly.
Step 3) Remove Latch Assembly From Door
Push the coiled up spring swaddled in foam towards the front of the car so you can remove the anchor rod from the sliding door inner frame. Let spring lay down slowly. Remove the cabin-facing phillips screw in the rear latch. Now open the door halfway and loosen the outer phillips screws while supporting the assembly.
There's much more in the link _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Tue May 16, 2017 5:02 am Post subject: Re: slider |
really appreciate it ,(I'm a Motor/transmission builder NOT a Bodyman ) I does close if I lift the slider UP a bit , maybe just tell me what is worn out and I'll replace ,Thanks _________________ 'Black Ice'Drag Buggy 'Turbo'
Posted: Tue May 16, 2017 5:43 am Post subject: Re: slider |
You need to remove the door. Clean, inspect, and lube the rollers. Check the nylon block _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Tue May 16, 2017 7:04 am Post subject: Re: slider |
Had it off a cpl. years ago did all that, was the same _________________ 'Black Ice'Drag Buggy 'Turbo'
Posted: Tue May 16, 2017 9:53 am Post subject: Re: slider |
From my experience, there is just a lot of different adjustable parts so getting them all to adjust with each other is tedious. Hopefully I'll be there Sunday and can help you out a bit. I fiddled with mine for hours, but it slides well now. Just my front locking mechanism is broken so it will lock on me as I'm shutting it sometimes. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Posted: Wed May 17, 2017 4:03 am Post subject: Re: slider |
I'll bring tools
I have a spare carb with your name on it _________________ 'Black Ice'Drag Buggy 'Turbo'
Posted: Wed May 17, 2017 6:58 am Post subject: Re: slider |
madmike wrote: |
I'll bring tools
I have a spare carb with your name on it |
Assuming I have my bus with me, my whole garage will be there because the bus is my garage. lol _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Posted: Mon May 22, 2017 3:30 am Post subject: Re: slider |
Hey Volks, Spike did an awesome job adjusting my slider and He's got a workable carb
only 4 hr. to get home 60mph average, one long stop for fuel,, could of made it on one tank full I believe
Thanks again,Madmike _________________ 'Black Ice'Drag Buggy 'Turbo'
Posted: Mon May 22, 2017 1:09 pm Post subject: Re: slider |
madmike wrote: |
Thanks again,Madmike |
That's 2/3 the time! you were sand bagging it on the way down! (still sandbagging on the way up with that 2110 between your rails.). And thanks for the carb, it is much nicer than the Mexican piece I had on there. I'm going to throw it on hopefully tomorrow or if I'm lucky, tonight. But probably tomorrow. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Posted: Tue May 23, 2017 3:00 am Post subject: Re: slider |
Sandbaggin ,ha, I can cruise @ 75 but remember it's got 'drum brakes' _________________ 'Black Ice'Drag Buggy 'Turbo'
