twinsben Samba Member
Joined: March 01, 2017 Posts: 5 Location: Bend, Oregon
Posted: Sun May 14, 2017 11:10 pm Post subject: EVC Furnace Replacement |
Has anyone replaced their furnace? We have a 1995 EVC. We are having problems with our Suburban NT-12S. I have decided it is better to replace the whole furnace as everything is 22 years old. I purchased a Suburban NT-16SQ. Hopefully it arrives soon. I imagine the install will be pretty straight forward.
Any thoughts or advice? |
HerbieDave Samba Member
Posted: Mon May 15, 2017 10:11 am Post subject: Re: EVC Furnace Replacement |
turn off your propane
Slide the rear seat all the way forward and out of the tracks
take off the side panel
disconnect the electrical, gas line and air duct
remove the 4 screws that hold the front cover of the furnace on
remove the 2 bolts in the lower front that bolt the furnace down
Slide it out. |
tds3pete Samba Member
Joined: April 04, 2004 Posts: 914 Location: Seattle, WA
Posted: Sun May 21, 2017 3:31 pm Post subject: Re: EVC Furnace Replacement |
While you have it out, I would suggest replacing all left rear tail light bulbs..
It's easy while it's out and a total pita otherwise. _________________ '58 Westy camper-come and gone
'73 Westy-bought new in Holland,now gone
'86 Syncro weekender-come and gone
'79 Westy...Oscar
'95 Eurovan Camper/5 spd...Marsha Mellow
Abscate Samba Member
Joined: October 05, 2014 Posts: 22638 Location: NYC/Upstate/ROW
Posted: Mon May 22, 2017 9:10 am Post subject: Re: EVC Furnace Replacement |
You will need to leak test the propane connections after install to ensure its safe. _________________ .ssS! |
Posted: Mon May 22, 2017 7:24 pm Post subject: Re: EVC Furnace Replacement |
The install took less than an hour including wiring in the original male electrical plug. The furnace was only $399 new from a third party seller on Amazon. If you are considering a replacement just do it. Cheers. |
Posted: Mon May 22, 2017 7:26 pm Post subject: Re: EVC Furnace Replacement |
Abscate wrote: |
You will need to leak test the propane connections after install to ensure its safe. |
Thanks! Soapy water always does the trick. |
sdunn35 Samba Member
Joined: September 05, 2008 Posts: 38 Location: Concord, CA
Posted: Tue May 23, 2017 9:20 am Post subject: Re: EVC Furnace Replacement |
@twinsben I'm curious if you think the fan on the new furnace is any quieter than the original. That's my only complaint really - makes it harder to sleep downstairs when it is cold enough to need the furnace. _________________ 99 EVC
ex-03 Weekender |
Posted: Tue May 23, 2017 1:57 pm Post subject: Re: EVC Furnace Replacement |
Yes. The fan is quieter. The old fan had a low pitch hum. This fan is super quiet. You still here the air flow though. |
springsvan Samba Member
Joined: January 21, 2018 Posts: 1 Location: Colorado Springs
Posted: Wed Mar 21, 2018 7:48 pm Post subject: Re: EVC Furnace Replacement |
Has anyone had difficulty getting the gas line compression nut loose? Have a 2000 EVC , doing a converter/battery upgrade and the nut connected to the copper line just outside the furnace housing is really stuck on there. I'm clearly the first person to open the panels up. Any tips for getting it loose? I don't want to bend that copper line. Thanks _________________ 2000 EVC- Mostly Running |
alexkistler Samba Member
Joined: January 17, 2019 Posts: 1 Location: Olympia, WA
Posted: Thu Jan 17, 2019 7:53 pm Post subject: Re: EVC Furnace Replacement |
Use two wrenches. One inside the heater and the other on the flare nut. |
gjjens Samba Member
Joined: May 07, 2019 Posts: 1 Location: Evergreen, Colorado
Posted: Tue May 07, 2019 4:58 pm Post subject: Re: EVC Furnace Replacement |
So, I ditched my NT12S on my 1995 EVC about 4 yrs ago. I replaced it with a NT 16SQ. I had an RV dealer , who was certified in Suburban repair and replacement install the new furnace. No Way I'd do it myself when I think about a furnace that needs to vent properly out the side. Than must have the gas line hooked up properly and checked for any gas leakage before use. That's just me. After the furnace was installed, I started having problems where the blower would come on and after 3 cycles, shut off. (using coach battery) After spending $ on new batteries, and control board, lp regulator, etc, I found a repairman who claimed that he could make that furnace hum all the way down to 10.5 v. The VW furnace is only vented to the right side as you look in at it. The sail switch is unfortunately on the left side. The left side has a knockout for additional heating duct but there is no room to add a duct. So, he removed the knockout on the left side, and that gave more air flow so the sail switch would stay on when the air from blower went over it. Only problem is that it is probably not great blowing some hot air into your compartment down there. I always get the sail switch to turn on correctly under shore power, just not with the battery. Again, the battery was fine. Now the furnace starts up all the time. I have a couple holes drilled in the knockout so that some of the air generated by the blower can flow more freely in the unit. If you can't get that air out, the air let out by the blower will hit the front of the unit and create resistance ultimately against the sail switch. Does this sound correct? I can't argue with the fact that he got my furnace to start every time. |
