Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2078 Location: Bulli Klinik, Colorado Springs
Posted: Mon May 15, 2017 7:58 am Post subject: What are these called and how do I remove them? |
Thanks!
_________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
Starbucket Samba Member
Posted: Mon May 15, 2017 2:41 pm Post subject: Re: What are these called and how do I remove them? |
That's a circled minus sign, just sand it off. |
Posted: Tue May 16, 2017 8:20 am Post subject: Re: What are these called and how do I remove them? |
I have no idea what that's supposed to mean.
Any other takers? To clarify, I'm talking about removing the 'air control horns' shown in the photo. _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
Posted: Tue May 16, 2017 3:43 pm Post subject: Re: What are these called and how do I remove them? |
Sorry about that. Google photos album link but it must have been set on private.
For your viewing pleasure...
Mike K
Bulli Klinik
Colorado Springs |
Posted: Tue May 16, 2017 4:44 pm Post subject: Re: What are these called and how do I remove them? |
If that's back by the motor it would be called heater control valves. The heat exchangers connect to this with flex hoses. Never removed one but I would GENTLY tap upward as it looks like it's a tapered fit to the lower piece UNLESS the rivets look like they are going through both pieces. I thought your first post was a test as I never seen the circled minus sign it a post before LOL. |
Posted: Wed May 17, 2017 7:37 am Post subject: Re: What are these called and how do I remove them? |
Sorry for the poor description. These are located under the hood, just outboard of the hood hinges. There is a flapper valve which is controlled by cables running to the dash. I imagine they are for fresh air?
I've been staring at them like a monkey looking at a coconut, but can't seem to figure out how they are removed. There are rubber sleeves connected to them as well. _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
Posted: Wed May 17, 2017 11:13 am Post subject: Re: What are these called and how do I remove them? |
Look behind the boot where the cable connects. There should be a tab with a single bolt holding it in place. |
Posted: Wed May 17, 2017 7:36 pm Post subject: Re: What are these called and how do I remove them? |
Thanks for the reply. I'll have a look. _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
68IHscout Samba Member
Joined: March 10, 2010 Posts: 3122 Location: santa ana ca
Posted: Tue Jun 26, 2018 12:23 pm Post subject: Re: What are these called and how do I remove them? |
Those have a nut on the outside in the wheel well,probably covered by undercoating,iirc |
