vw_bud Samba Member
Joined: March 23, 2008 Posts: 265 Location: Bradford, PA
Posted: Tue May 16, 2017 8:16 pm Post subject: 1976 fuel injection problem |
I'm working on my friends fuel injected bus 1976 and 2.0l it died one day on him...I sprayed carb cleaner into the intake and it started so I know it has spark. I replaced the fuel pump and relay and turned the key but no whirring from the pump. I told him go carb like my bus and my 78 bus but he wants to keep it does anyone have any ideas? |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Tue May 16, 2017 8:30 pm Post subject: Re: 1976 fuel injection problem |
The AFM flap must be opened to get the fuel pump to start.
He's a smart owner, since he wants to keep the FI system. _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
vw_bud Samba Member
Posted: Tue May 16, 2017 8:35 pm Post subject: Re: 1976 fuel injection problem |
I did not know that I'll give it a shot. I thought just key on and it pumps til pressure is reached then cuts off unless it's running of course |
BayCreamPuff Samba Member
Joined: August 10, 2015 Posts: 769 Location: Oakland, CA
Posted: Tue May 16, 2017 8:42 pm Post subject: Re: 1976 fuel injection problem |
If the pump isn't running while cranking I'd check for 12V at 86a on the double relay while cranking. Also make sure all the terminals are properly seated in the two double relay terminal blocks, and that the relay ground is properly grounded to the firewall.
_________________ Cream Puff
'79 CA Stock FI Deluxe Campmobile
Earl Grey
'87 GoWesty 2.2 Westfalia
Marsha Mellow
'00 Eurovan VR6 Full Camper |
Posted: Tue May 16, 2017 8:50 pm Post subject: Re: 1976 fuel injection problem |
My favorite site for FI info:
https://www.thesamba.com/vw/archives/manuals/afc_fi_training_troubleshooting_manual.php _________________ -Kent-
---williamM |
vw_bud Samba Member
Posted: Tue May 16, 2017 9:06 pm Post subject: Re: 1976 fuel injection problem |
Thanks guys I'll look more into it hopefully I can fix it I'm in the middle of two other projects and this one |
Randy in Maine Samba Member
Posted: Wed May 17, 2017 4:29 am Post subject: Re: 1976 fuel injection problem |
Have him (not you) start cleaning the power cables at the battery and the starter first.
He may need to troubleshoot the double relay. You can show him how to do that using the volt ohm meter he needs to buy. Let him do it as he will never learn how any younger.
http://www.itinerant-air-cooled.com/viewtopic.php?f=50&t=5459
Keep in mind that the fuel pump electrical connections have a + and a ground and have to be installed that way. |
BusLust Samba Member
Joined: September 20, 2016 Posts: 185 Location: High Springs, Florida
Posted: Wed May 17, 2017 4:53 am Post subject: Re: 1976 fuel injection problem |
Also if all else fails.... Check his grounds. Their should be some grounds by your spark plug wires... Happened to us a few weeks ago while driving for some time. She would start and go some and then just turn off. We have a 75 with FI. Checked the grounds and cleaned up the ends and have not had an issue at all since then! _________________ BUSLUST IS NOW IN HIGH SPRINGS FLORIDA!
Dynamic Duo - William & Jenn =)
1975 VW Westfalia "Willow"
1970 VW Single Cab Truck "Woodstock"
[email protected] |
vw_bud Samba Member
Posted: Wed May 17, 2017 8:31 pm Post subject: Re: 1976 fuel injection problem |
Thank you guys very much this helps I'm only 25 working full time and also redoing three Volkswagens plus working on this one lol luckily my 75 drives perfectly |
Posted: Thu May 18, 2017 2:58 am Post subject: Re: 1976 fuel injection problem |
vw_bud wrote: |
Let us know what you find out!! _________________ BUSLUST IS NOW IN HIGH SPRINGS FLORIDA!
[email protected] |
vw_bud Samba Member
Posted: Thu May 18, 2017 5:18 am Post subject: Re: 1976 fuel injection problem |
Ok so. It was vacuum lines man lol. Plus pump it'll start and run but rough I heard air leaking sprayed carb cleaner on the intake boots and it picked up rpm so he needs those as well at least now I can get back to my 78 automatic bus engine buuld |
vw_bud Samba Member
Posted: Sun Oct 29, 2017 8:17 pm Post subject: Re: 1976 fuel injection problem |
Ok so after I patched the battery tray and put fuel in the bus it won't start now and I disconnected a fuel rail line and cranked it while the pedal was depressed and it's not sending fuel to the engine...fuel pump is brand new any ideas? |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16970 Location: San Diego, California
Posted: Sun Oct 29, 2017 8:23 pm Post subject: Re: 1976 fuel injection problem |
Pressing the pedal is not the same as moving the afm door. You need to reach in there with a long screwdriver and push the door open with the key on. The pump should then run. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
curtp07 Samba Member
Posted: Mon Oct 30, 2017 12:05 am Post subject: Re: 1976 fuel injection problem |
When I was originally setting up my FI, it helped to put a fuel pressure gauge on the rail test port. This way it’s easy to monitor,,,and when you’re all tweaked, remove it. _________________ Subaru |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Mon Oct 30, 2017 8:07 am Post subject: Re: 1976 fuel injection problem |
along the lines of trouble shooting FI-- Can you run a noid light in parallel with a running injector? _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
tommu Samba Member
Posted: Mon Oct 30, 2017 12:51 pm Post subject: Re: 1976 fuel injection problem |
If the pump is very noisy, and the previous pump failed, have you checked the fuel filter? I would change it if it hasn't been touched for a while.
Without any background on the bus I wouldn't overlook the possibility of the fuel tank being full of so much rust and debris that it blocks flow through the pump. _________________ |
vw_bud Samba Member
Posted: Mon Oct 30, 2017 8:28 pm Post subject: Re: 1976 fuel injection problem |
I was thinking filter maybe that white box under the bus lol but if I hook the pump up directly to a battery should it whirr and buzz or does it not make a sound? |
vw_bud Samba Member
Posted: Mon Oct 30, 2017 8:30 pm Post subject: Re: 1976 fuel injection problem |
Oh and thanks up above for the info on the afm with the screw driver I'll give it a go and if it does work what would be the correction? |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22727 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Mon Oct 30, 2017 8:37 pm Post subject: Re: 1976 fuel injection problem |
vw_bud wrote: |
There's a spring tension adjustment for the flap under the plastic AFM cap. You'll need to move it a click at a time till it runs the pump as it flaps when cranking. Count how many clicks so you can "get back home again" if necessary.
Then you'll need to reset your CO value but you really need an exhaust sniffer for that.
This was never an authorized repair- the authorized repair was replace your airflow meter, but all us techs were cheap! _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Mon Oct 30, 2017 9:05 pm Post subject: Re: 1976 fuel injection problem |
Tram wrote: |
vw_bud wrote: |
This was never an authorized repair- the authorized repair was replace your airflow meter, but all us techs were cheap! |
He's just talking about using a pencil or wooden dowel (either is preferred over a screw driver) to open the door in the AFM, not adjusting it. |
