Single port thermostat rod vs dual port thermostat rod
Page: Previous  1, 2
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Thu May 18, 2017 10:55 am    Post subject: Re: Single port thermostat rod vs dual port thermostat rod Reply with quote
busdaddy wrote:
When I find bent rods like that I look very carefully at the C shaped thing on the flap the rod attaches to, if its been stretched the fulcrum changes and the flaps may not open fully.
Thanks for the heads up, but in this case, the rod was on a different set of flaps than the ones that I'll be using. It's still worth checking though.
TDCTDI
TDCTDI is offline
PostPosted: Thu May 18, 2017 10:59 am    Post subject: Re: Single port thermostat rod vs dual port thermostat rod Reply with quote
hazetguy wrote:
are you going to farmington this weekend? let me know, i could bring you a good one.
I didn't even know that it was this W/E, that would be great thanks.
hazetguy
hazetguy is offline
PostPosted: Thu May 18, 2017 1:40 pm    Post subject: Re: Single port thermostat rod vs dual port thermostat rod Reply with quote
i've got one packed. look for me in the swap.
Parts and mechanical restoration services available. I restore and rebuild fuel pumps, distributors, spindles, etc.
Check my ads or send a PM.
" just because YOUR hobby is another's profession, it doesn't mean that a shop works for free. " -Don
"I don't think it's a bad thing. Make people to be more green and things like that."
http://www.plagiarism.org/plagiarism-101/what-is-plagiarism/
TDCTDI
TDCTDI is offline
PostPosted: Thu May 18, 2017 2:10 pm    Post subject: Re: Single port thermostat rod vs dual port thermostat rod Reply with quote
Yes sir! Thanks!
blue72beetle
blue72beetle is offline
PostPosted: Mon Jun 19, 2017 3:11 pm    Post subject: Re: Single port thermostat rod vs dual port thermostat rod Reply with quote
Can a doghouse fan shroud be added to a single port engine?
-Andy-
-1970 Ghia-
-1971 Bus-
-1972 Bug-
busdaddy
busdaddy is offline
PostPosted: Mon Jun 19, 2017 4:02 pm    Post subject: Re: Single port thermostat rod vs dual port thermostat rod Reply with quote
Yes, but you'll need a doghouse style cooler as well as the adaptor mount and the appropriate seals to convert the oil port sizes (depending on your case), you'll also need the wider fan and a different link bar for the thermostat mechanism.
Tcash
Tcash is offline
PostPosted: Mon Jun 19, 2017 5:24 pm    Post subject: Re: Single port thermostat rod vs dual port thermostat rod Reply with quote
70 single port conversion to doghouse tin & cooler
https://www.thesamba.com/vw/forum/viewtopic.php?t=245758&highlight=single+port+doghouse
Oil cooler seals
bus doghouse fire wall tin
aeromech
aeromech is offline
PostPosted: Mon Jun 19, 2017 7:20 pm    Post subject: Re: Single port thermostat rod vs dual port thermostat rod Reply with quote
You guys are awesome
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
busdaddy
busdaddy is offline
PostPosted: Mon Jun 19, 2017 7:28 pm    Post subject: Re: Single port thermostat rod vs dual port thermostat rod Reply with quote
I know right? Very Happy Razz
It just occured to me you'll also have to retap the case or use step studs since most SP's have 6mm studs yet the adaptor is 8mm.
Along with the front tin Tcash posted (you can cut a hole in your existing tin if you like) you'll need the 2 exhaust duct tins for the cooler to reach that hole. And a Hoover bit, can't forget that.
Tcash
Tcash is offline
PostPosted: Mon Jun 19, 2017 8:07 pm    Post subject: Re: Single port thermostat rod vs dual port thermostat rod Reply with quote
Ah good one BD. Can't forget the Hoover bit
thnx to Bob Hoover
http://bobhooversblog.blogspot.com/2006/11/vw-hoover-bit.html
The "Hoover Bit"
https://www.thesamba.com/vw/forum/viewtopic.php?t=105542
Fanshroud & Oil Cooler Sealing Frame (Hoover Bit) Combos
https://www.thesamba.com/vw/forum/viewtopic.php?t=360743&highlight=making+hoover
search hoover bit
https://www.thesamba.com/vw/forum/album_search.php...t_dir=DESC
Thanks Gary
Tcash
Page: Previous  1, 2
Page 2 of 2
