Source for quality ignition / electric switch?
79WestyinVermont
79WestyinVermont is offline
PostPosted: Fri May 19, 2017 10:04 am    Post subject: Source for quality ignition / electric switch? Reply with quote
Can anyone recommend a vendor who stocks a quality plastic electric ignition switch for a 79 Westy ? Someone mentioned quality/fit issues and I only hope to do the job once.
Thanks!
vwwestyman
vwwestyman is offline
PostPosted: Fri May 19, 2017 10:08 am    Post subject: Re: Source for quality ignition / electric switch? Reply with quote
I think this is the one I used in my '78
http://www.busdepot.com/171905865
Years ago, the coil came loose and rotated around, which shorted the +15 wire from the switch. Also fried the original ignition switch.
Somehow, that seems to have also damaged the function of the lock slightly. Well, I tried a bunch of aftermarket switches and none ever worked.
This one finally let me remove the push button system I had for my starter for a long time.
Dave Cook
Stuartzickefoose wrote:
I'm gonna punch vwwestyman then shake his hand when I meet him.
notchboy wrote:
Ill just punch you in the face. Wink
1973 Wild Westerner
My Thing
www.thefosterdads.com
79WestyinVermont
PostPosted: Fri May 19, 2017 10:51 am    Post subject: Re: Source for quality ignition / electric switch? Reply with quote
Thanks WestyMan, I ordered the OEM German part from them, along with a new foam engine seal.
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Sat May 20, 2017 4:36 am    Post subject: Re: Source for quality ignition / electric switch? Reply with quote
FWIW, that switch was used in the water cooled cars well into the 90s in Golfs & Jettas
