Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2079 Location: Bulli Klinik, Colorado Springs
Posted: Tue May 09, 2017 8:06 am Post subject: Westfalia electrical side outlet seals |
Hello all. I'm working on a 73 Westfalia and am wondering about the availability of the seals used on the exterior electrical hook-up. The Bus I'm currently working on did not have the seals and I'm unsure what it's supposed to look like. Any pictures/information would be appreciated.
This is the steel, hooded style outlet on the drivers side of the Bus. _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
Cavilry6 Samba Member
Joined: February 07, 2016 Posts: 142 Location: Santa Cruz, ca
Posted: Tue May 09, 2017 10:25 am Post subject: Re: Westfalia electrical side outlet seals |
The one in question is different. I don't think the seals would work.
I'll take some pictures to post in order to clarify.
Thanks for your help! _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
BayCreamPuff Samba Member
Joined: August 10, 2015 Posts: 769 Location: Oakland, CA
Posted: Tue May 09, 2017 11:03 am Post subject: Re: Westfalia electrical side outlet seals |
That gowesty seal was too small for the outlet on my 79. Ended up making my own from gasket material. _________________ Cream Puff
'79 CA Stock FI Deluxe Campmobile
Earl Grey
'87 GoWesty 2.2 Westfalia
Marsha Mellow
'00 Eurovan VR6 Full Camper |
Posted: Wed May 10, 2017 8:41 am Post subject: Re: Westfalia electrical side outlet seals |
I installed the outlet with a foam seal around the perimeter, but if you look closely, there is a gap around the the part which penetrates the side of the Bus. Is there a replacement seal available for this style of outlet?
Mike K
Bulli Klinik
Colorado Springs |
Sloride Samba Member
Posted: Wed May 10, 2017 8:52 am Post subject: Re: Westfalia electrical side outlet seals |
Thanks for the reply. IMO, it's a terrible design, but I was hoping there was a seal made with a lip for the inner portion. I bought some SIKAflex caulk to seal it up, but I prefer something that works. _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Wed May 10, 2017 10:11 am Post subject: Re: Westfalia electrical side outlet seals |
Just buy a sheet of closed cell foam and make you own. You might try an RV supply and see if they have something. |
Posted: Wed May 10, 2017 5:08 pm Post subject: Re: Westfalia electrical side outlet seals |
Thanks for the replies. I'll assume correct seals aren't available.
You're correct. They were originally sheet metal screws. I'm doubtful it will get used let alone need to be removed, but thanks for the heads up. _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51145 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed May 10, 2017 6:02 pm Post subject: Re: Westfalia electrical side outlet seals |
ToolBox wrote: |
Craft foam sheets from the $ store or craft store work well for gaskets like that, you can even get it in wild colors if you wish _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
LazyLightning75 Samba Member
Joined: August 02, 2016 Posts: 115 Location: Carmichael, CA
Posted: Wed May 10, 2017 6:13 pm Post subject: Re: Westfalia electrical side outlet seals |
Ditto on the suggestion from Toolbox & busdaddy.
Yeah, upon looking at your picture a second time...I still have a gap in the same location you're concerned with. _________________ 1975 Riviera 1.8L FI |
Posted: Thu May 11, 2017 8:23 am Post subject: Re: Westfalia electrical side outlet seals |
It's a wonky area to seal. I can certainly see how a generic foam seal would shrink and allow moisture in. Perhaps the original had a lip around the flat, outer surround?
Does anyone have a picture of the original seal? This Bus came to me in parts. _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
pantone149 Samba Member
Joined: August 19, 2004 Posts: 1018 Location: Mt. Shasta
Posted: Thu May 11, 2017 11:36 am Post subject: Re: Westfalia electrical side outlet seals |
I made the outlet-to-body and outlet-to-frame seals from an old truck inner tube. Got the inner tube from a tire shop for free. Sharp scissors and a paper punch thing were my friends. |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Thu May 11, 2017 1:55 pm Post subject: Re: Westfalia electrical side outlet seals |
Don't forget adhesive weatherstrip material from places like Ace Hardware, available in rolls of various thicknesses. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Posted: Fri May 12, 2017 7:57 am Post subject: Re: Westfalia electrical side outlet seals |
I understand the availability of generic seals. That is what's installed in the picture. I used 1/2" thick closed cell foam and compressed it behind the plate. The perimeter is sealed. The problem, as it turns out others have as well, is the slight gap where the hood protrudes.
Does anyone have a pic of what was there originally?
Thanks! _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
ChipWrecked Samba Member
Posted: Mon May 22, 2017 6:31 pm Post subject: Re: Westfalia electrical side outlet seals |
This what I used: http://amzn.to/2q4Q8ed
_________________ "You're too retarded for a retard." Amskeptic |
