dshawirwin Samba Member
Joined: June 17, 2016 Posts: 35 Location: Salt Lake City
Posted: Sat May 20, 2017 1:43 pm Post subject: 1968 Ghia Equalizer Z Bar |
I'm kinda guessing there's no one answer to this, but throwing it out there.
Try as I might, the right lubricates, vice, torch I can't get this bolt off. And thinking maybe I'm missing something like it'd not suppose to come off.....
In case buying a new rod is where I end up, can someone recommend where to get.
Thanks a bunch!
Starbucket Samba Member
Posted: Sat May 20, 2017 3:12 pm Post subject: Re: 1968 Ghia Equalizer Z Bar |
Make a mix if 50% Acetone and 50% Auto. trans fluid and soak it for an hour then put something that the nut can rest on and smack the other side of the nut with a hammer, turn one flat and repeat until you work your way around the nut, soak with mixture for 15 more min.s and it should come off (make sure you are turning in the right direction). |
bhartwell59 Samba Member
Joined: December 28, 2014 Posts: 791 Location: dallas, tx
Posted: Sat May 20, 2017 3:57 pm Post subject: Re: 1968 Ghia Equalizer Z Bar |
Starbucket wrote: |
Make a mix if 50% Acetone and 50% ATF |
That's the ticket... cheap and works great. Get your acetone at Walmart in the nail polish section. Use the plastic bottle to mix with the ATF. GL _________________ '74 Zambezi green Ghia vert, autostick, 101k
'87 Jeep Wrangler, 4.2, 330k |
Posted: Sat May 20, 2017 4:17 pm Post subject: Re: 1968 Ghia Equalizer Z Bar |
Perfect. Heading that way.
Thanks so much |
xzener Samba Member
Posted: Sat May 20, 2017 4:54 pm Post subject: Re: 1968 Ghia Equalizer Z Bar |
I have a complete Z-Bar (including hardware) for sale in the classifieds if it comes to that. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
blue72beetle Samba Member
Joined: April 23, 2008 Posts: 846 Location: Fort Wayne, IN
Posted: Sun May 21, 2017 3:31 pm Post subject: Re: 1968 Ghia Equalizer Z Bar |
Please forgive my ignorance (I'm not a Ghia guy), but what is an Equalizer Z bar? _________________ -Andy-
-1970 Ghia-
-1971 Bus 1776 Microsquirt EFI- |
olspeed Samba Member
Joined: May 01, 2008 Posts: 489 Location: In the shadow of Denali, I still don't give a damn how they do it outside
Posted: Sun May 21, 2017 4:14 pm Post subject: Re: 1968 Ghia Equalizer Z Bar |
If it is truly frozen on where even lubricant wont let you remove it then the next step is a chisel and hammer. You should be able to split the nut on both sides and then take it right off there really is no reason to destroy the rod itself. _________________ 66- Ghia
76-Beetle |
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2874 Location: Auckland, New Zealand
Posted: Sun May 21, 2017 5:03 pm Post subject: Re: 1968 Ghia Equalizer Z Bar |
blue72beetle wrote: |
Please forgive my ignorance (I'm not a Ghia guy), but what is an Equalizer Z bar? |
The early Beetles and Ghias were unstable at the rear with the swing axle set-up. The theory is that VW installed a Z-Bar to forestall product liability litigation in the US. Beetles and Ghias with IRS (Independent Rear Suspension) behave much better and don't need the Z-bar. Since your car is a 70s model I'm not surprised you've never heard of this part. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
sactojesse Samba Member
Joined: November 21, 2006 Posts: 2655 Location: Sacramento, California, USA
Posted: Mon May 22, 2017 10:45 am Post subject: Re: 1968 Ghia Equalizer Z Bar |
Ah ok, sort of like an anti-sway bar. Thanks |
More like a camber compensator than a sway bar, IMO. _________________ 1966 Karmann-Ghia convertible |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Mon May 22, 2017 10:57 am Post subject: Re: 1968 Ghia Equalizer Z Bar |
Actually, it's the opposite.
VW softened the rear springs in order to get a little MORE rear sway so that the front suspension would take more of the cornering load and therefore not oversteer so badly. A front anti-roll bar was added for the same reason.
However, the softer springs in the rear meant the car could bottom out, so they added the equalizer, or Z-bar. It's really just an overload spring.
An anti-sway bar works when each side of the suspension moves in OPPOSITE directions. The Z-bar works only when both sides work in the SAME direction (of compression; it does nothing on extension).
Some owners have shimmed the Z-bar so that it works sooner (with less load), though this undoes the effect VW was trying to achieve. |
