takeiteasy Samba Member
Joined: August 11, 2016 Posts: 169 Location: New York, NY
Posted: Sat May 20, 2017 6:37 pm Post subject: Power Steering Pump |
I am missing a connection here. Can someone help me in finding the correct lead for this? 1.9L
_________________ '85 Weekender 1.9L
"With your past and your future precisely divided.
Am I at that moment? I haven't decided." |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 4362 Location: Honolulu,Hawaii and France
Posted: Sat May 20, 2017 10:39 pm Post subject: Re: Power Steering Pump |
ALIKA T3 wrote: |
The wiring harness on my 85 westy doesn't have the wires. Maybe the same with yours? |
You hahe nothing there? _________________ '85 Weekender 1.9L
Posted: Sun May 21, 2017 1:14 pm Post subject: Re: Power Steering Pump |
takeiteasy wrote: |
ALIKA T3 wrote: |
You hahe nothing there? |
I got no wires at all! Not cut or anything. I replaced the hose unfortunately, with a 2.1L model I had laying around bc it was leaking badly. I cannot recall if the old one had the pressure switch or not before I threw it away  _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
bluebus86 Banned
Posted: Sun May 21, 2017 2:14 pm Post subject: Re: Power Steering Pump |
the switch is supposed to be wired to the idle module located ahead of the right tail lamp assembly, at least thats how it is done on my 1986.
good luck _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Sun May 21, 2017 6:23 pm Post subject: Re: Power Steering Pump |
I found a cut wire under the throttle body coming out of the engine. Is this the wire?
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 13307 Location: Syracuse, NY
Posted: Sun May 21, 2017 6:31 pm Post subject: Re: Power Steering Pump |
no that wire is for the dealer diagnostic tool RPM/TDC sensor.
it's no longer used. |
Posted: Sun May 21, 2017 6:41 pm Post subject: Re: Power Steering Pump |
danfromsyr wrote: |
Thanks _________________ '85 Weekender 1.9L
dlb154 Samba Member
Joined: December 27, 2006 Posts: 320 Location: Reno, NV
Posted: Sun May 21, 2017 6:51 pm Post subject: Re: Power Steering Pump |
I believe the 85 1.9l only has one wire to the power steering pump for idle enrichment.
Maybe the second connection goes to ground? |
Posted: Mon May 22, 2017 7:11 am Post subject: Re: Power Steering Pump |
dlb154 wrote: |
Thanks, I will try to confirm _________________ '85 Weekender 1.9L
Cookbook Samba Member
Posted: Sat Mar 31, 2018 12:35 pm Post subject: Re: Power Steering Pump |
Takeiteasy, did you ever figure out where the second wire went? I'm having the same problem... one wire is connected and I can it trace end to end. The other wire is connected to the PS switch, but is only about 5-6 inches long and appears like it was broken off. I've searched the engine compartment and cannot find where it once might have been attached. It's brown so I'm guessing it was a ground? |
