68IHscout Samba Member
Joined: March 10, 2010 Posts: 3122 Location: santa ana ca
Posted: Sun May 21, 2017 10:23 am Post subject: Afm 79bug |
Not knowing anything about fuel injection bugs ,i thought all afm were the same ,that being said my 79 is a California bug, now are the afm different in Ca than the other states ? It has a 0280 200 006 the one i bought used (come to find out )its actually out of van 75to79 van 0280 200 012 can any one shed some wisdom upon me . Thanks in advance. |
vwoldbug Samba Member
Posted: Sun May 21, 2017 2:17 pm Post subject: Re: Afm 79bug |
Is the electrical plug the same ( does it plug in ) |
Posted: Sun May 21, 2017 3:01 pm Post subject: Re: Afm 79bug |
vwoldbug wrote: |
its the same it plugs injust fine,only difference is the numbers |
Posted: Thu May 25, 2017 2:03 pm Post subject: Re: Afm 79bug |
I think it should work |
Randy in Maine Samba Member
Posted: Thu May 25, 2017 5:29 pm Post subject: Re: Afm 79bug |
Does it work or not? |
Posted: Thu May 25, 2017 5:43 pm Post subject: Re: Afm 79bug |
Randy in Maine wrote: |
hey Randy ,ihave nit been able to get it started yet , do you think it should work or should i just get the right numbered one |
Posted: Fri May 26, 2017 4:22 am Post subject: Re: Afm 79bug |
If it were me, I would try to find the correct one. |
sawed off Samba Member
Joined: September 15, 2016 Posts: 428 Location: Idaho
Posted: Fri May 26, 2017 7:19 am Post subject: Re: Afm 79bug |
Rebuilt my AFM recently and did lots of research, I would agree if it plugs in your good to go. You have 6 pins, 2 are for fuel pump and the other 4 are air temp sensor and basic throttle position via how much the flap opens which is determined by throttle opening from accelerator pedal. The only difference might be air fuel ratio but not for certain, it would be nice to dial it in with air fuel ratio meter stuck in exhaust pipe. They are adjustable but some discourage this if your not sure how or why this is done. |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9879 Location: Huntington Beach, CA
Posted: Fri May 26, 2017 7:21 am Post subject: Re: Afm 79bug |
What is the reason for changing out the AFM? |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12686 Location: on a bike ride somewhere
Posted: Fri May 26, 2017 8:53 am Post subject: Re: Afm 79bug |
Off topic shitposting:
I think it's almost cute how many blame AFM's for problems, just because it's the component that fewest people understand. If the base line measurements of the AFM check out according to the AFC Handbook, look elsewhere for your problems.
Robbie
https://www.thesamba.com/vw/archives/manuals/afc_f...Manual.pdf _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Posted: Fri May 26, 2017 12:25 pm Post subject: Re: Afm 79bug |
VW_Jimbo wrote: |
it's frozen. Aluminum oxide (rust)inside. |
Posted: Fri May 26, 2017 12:28 pm Post subject: Re: Afm 79bug |
asiab3 wrote: |
Robbie
https://www.thesamba.com/vw/archives/manuals/afc_f...Manual.pdf |
thank you ,i dont blame the amf ,my only concern was ,will the unit i got would work with mine. |
Posted: Fri May 26, 2017 12:46 pm Post subject: Re: Afm 79bug |
68IHscout wrote: |
VW_Jimbo wrote: |
How much for frozen rusted one? |
Posted: Fri May 26, 2017 1:15 pm Post subject: Re: Afm 79bug |
That is a good reason to replace. I just asked because 9 out of ten times the AFM is good and there is a loose ground else where.
On the Samba there is an ad (Ad number 0280200006) for one rebuilt;
"Rebuilt Air Flow Meter for Beetle 0280200006 Price: $245 exchange
Rebuilt air flow meter for fuel injected Beetle, years 1975-1979. Part number 0280200006 or 043906301. One year warranty. Limited supply. May require your core for the rebuild. Price $245 exchange. Core charge is an additional $125 if your core is not rebuildable.
Price increase effective 8/29/16. "
Link is;
https://www.thesamba.com/vw/classifieds/detail.php?id=1558771
Never bought one off of this vendor, but easy enough to get. I have a rebuilder near me that I have used through the years. Been awhile since I looked them up.
Good luck, hope that helps and in the end fixes your problems! |
Posted: Fri May 26, 2017 5:48 pm Post subject: Re: Afm 79bug |
Thanks guys fir the replies,i really apreciate it ,i wonder if the old guts from mine can be changed over to the other one ? |
Posted: Fri May 26, 2017 5:51 pm Post subject: Re: Afm 79bug |
sawed off wrote: |
68IHscout wrote: |
VW_Jimbo wrote: |
ill hold on to it for now but when im ready ill let you know. |
Posted: Sat Jun 24, 2017 7:19 am Post subject: Re: Afm 79bug |
Update ,i got a used one (numbers match now)that checks out per bentley testing with o meter ,i havent got a chance to install it yet ,i compared the two .
That is when i noticed the idle screw missing from the one i had installed , that is probably another reason the car wont start . |
Posted: Sat Jun 24, 2017 8:04 am Post subject: Re: Afm 79bug |
Air bleed on AFM has some control over fuel mixture thru entire range, Idle speed on throttle body. The two screws kinda work together. Once you get idle speed where you want it you can adjust idle mixture on AFM. they work together. |
Posted: Sat Jun 24, 2017 8:14 am Post subject: Re: Afm 79bug |
sawed off wrote: |
thank you ,i have not been able to start it yet ,trouble shooting one tep at a time |
