consvws Samba Member
Joined: April 07, 2009 Posts: 950 Location: Roseburg, OR
Posted: Sun May 21, 2017 7:03 pm Post subject: clutch was chattering really bad |
the clutch on my 1979 bus was chattering worse & worse. I have a new pressure plate, disc, T/O bearing, boden tube, and cable. I was about ready to pull the engine & dig deeper into the issue when i noticed this.
The metal tube that the boden tube attaches to had a big crack in the support tab! Just thought i'd share to help anyone having this same problem
The tab welded up & i have no more chattering |
Posted: Sun May 21, 2017 7:54 pm Post subject: Re: clutch was chattering really bad |
My saying this will probably make some of the purist pull their hair out and then sacrifice themselves in a fire fueled by burning old Type 1 engines, but for the entire length of them I have owned and driven VW Transporters, I have just had some nylon starter cord very tightly wrapped around the torsion tube and clutch cable tube binding the two together. This is a temporary fix that I did way back in 1988 and has yet to give problems. The original weld lasted a far shorter time.
aeromech Samba Member
Joined: January 24, 2006 Posts: 16970 Location: San Diego, California
Posted: Sun May 21, 2017 8:08 pm Post subject: Re: clutch was chattering really bad |
The tube can cause chatter. Usually it needs shims to be an S pattern. If the mount is broken it can cause this problem. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Sun May 21, 2017 9:23 pm Post subject: Re: clutch was chattering really bad |
Wildthings wrote: |
My saying this will probably make some of the purist pull their hair out and then sacrifice themselves in a fire fueled by burning old Type 1 engines, but for the entire length of them I have owned and driven VW Transporters, I have just had some nylon starter cord very tightly wrapped around the torsion tube and clutch cable tube binding the two together. This is a temporary fix that I did way back in 1988 and has yet to give problems. The original weld lasted a far shorter time. |
I keep one of those giant hose clamps with me in case I get a little rambunctious off road again. Do you think the slight flexibility of your mount gives you a better or worse pedal feel?
www.airschooled.com |
Posted: Mon May 22, 2017 2:17 am Post subject: Re: clutch was chattering really bad |
asiab3 wrote: |
Wildthings wrote: |
Robbie |
It is cinched tight enough that I don't think it ever moves in normal use. My pedal feels 100% normal. |
