AndyC13 Samba Member
Posted: Mon May 22, 2017 9:14 am Post subject: 1979 California Aftermarket Exhaust |
My OE exhaust began to rot away.
So I bought a replacement muffler.
Needless to say, the repro part was not the same as the OE part!
I have spent the last two weeks trying to find a fitting kit, and in the end have had to bodge fit it. Not ideal!
I have decided to fit a nice aftermarket system that will replace the cat and all the pipework.
In the UK, there is only one person that seem to make an exhaust for the triangular flanges! They cost about £350-400. But he's a one man band.
Is there anyone in the US that makes them? Surely there must be! |
airkooledchris Samba Member
Posted: Mon May 22, 2017 10:50 am Post subject: Re: 1979 California Aftermarket Exhaust |
If you have a 79 California model and it's original exhaust - you can switch to the better 72-74 style system and use all of their aftermarket exhaust systems instead going forward.
To switch you will need the drivers side FEDERAL 79 heater box, to match the passenger side heater box which is already setup to accept the 72-74 style exhaust.
You will also need the tinware for that side of the motor, for the heater box connection to the heater fan. |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Tue Sep 05, 2017 3:24 am Post subject: Re: 1979 California Aftermarket Exhaust |
you will need to look at your cylinder head to manifold connection and see if you have the 79 square manifold or the earlier "round"exhaust ports- as in the picture- the 79 took gaskets and bolted to the head flat- the pre 79 had a round copper seal deeper in the head and had the manifold as you see in the ad.
This is the latter one- notice that the manifold has the mating surface and bolt holes on the same plane- and you ad shows the mating surface and the bolt holes at different "heights " along the header.
[img][/img]
and as mentioned- the cabin heat intake moved - so the tin work and tube will need to be added. You can just cut a new hole in the top tin and plug the old one, but the tube will need to be replaced.[img][/img] _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
BayCreamPuff Samba Member
Joined: August 10, 2015 Posts: 769 Location: Oakland, CA
SGKent Samba Member
Posted: Tue Sep 05, 2017 9:13 am Post subject: Re: 1979 California Aftermarket Exhaust |
AndyC13 wrote: |
can you post some photos please so we may make a better assessment of what you have and need? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Sep 06, 2017 1:16 am Post subject: Re: 1979 California Aftermarket Exhaust |
SGKent wrote: |
can you post some photos please so we may make a better assessment of what you have and need? |
Will try and take some today.
But this is the setup I have.
Posted: Wed Sep 06, 2017 2:10 am Post subject: Re: 1979 California Aftermarket Exhaust |
I've been told I will also likely need different heat risers.
Is that the case?
Also, two new pieces of tinwear?
Lower and rear lower engine? |
Posted: Wed Sep 06, 2017 6:56 am Post subject: Re: 1979 California Aftermarket Exhaust |
replacing the DS heat box and manifold and long cross the back tubing with just the federal heat exchanger will solve all your problems. that will put 2 identical exhaust outlets to the rear of the bus and you can then put a header and vanagon style long muffler on there or the single full width muffler on there- I'll see if I can find my other pic. you end up with a 3 piece exhaust system- (not counting the tail pipe.
[img]
[/img][img]
Or this
Don't step in any!
SGKent Samba Member
Posted: Wed Sep 06, 2017 6:58 am Post subject: Re: 1979 California Aftermarket Exhaust |
Andy - are you in a smog state? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Sep 06, 2017 7:01 am Post subject: Re: 1979 California Aftermarket Exhaust |
SGKent wrote: |
Andy - are you in a smog state? |
No. I'm in the UK.
No emissions tests on our old buses. |
Posted: Wed Sep 06, 2017 7:04 am Post subject: Re: 1979 California Aftermarket Exhaust |
AndyC13 wrote: |
SGKent wrote: |
No. I'm in the UK.
Perfect. _________________ some days I get up and just sit and think. Some days I just sit.
Posted: Wed Sep 06, 2017 7:05 am Post subject: Re: 1979 California Aftermarket Exhaust |
williamM wrote: |
[img]
[/img][img]
Or this
[/img] |
Perfect. Thanks. Hard to visualise how it would look.
My plan is to fit a Vintage Speed exhaust or something afterwards |
SGKent Samba Member
Posted: Wed Sep 06, 2017 7:18 am Post subject: Re: 1979 California Aftermarket Exhaust |
If UK laws allow you to remove smog parts, you need to find a left side heat exchanger, and new muffler. That is the easiest solution. I would keep the 1979 California parts in case there ever is a need to smog the bus. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Sep 06, 2017 8:22 am Post subject: Re: 1979 California Aftermarket Exhaust |
SGKent wrote: |
If UK laws allow you to remove smog parts, you need to find a left side heat exchanger, and new muffler. That is the easiest solution. I would keep the 1979 California parts in case there ever is a need to smog the bus. |
Cheers very much.
The hunt is on! |
Posted: Wed Sep 06, 2017 8:30 am Post subject: Re: 1979 California Aftermarket Exhaust |
Perfect.
Thanks very much. |
Posted: Wed Sep 06, 2017 8:38 am Post subject: Re: 1979 California Aftermarket Exhaust |
Just edited it with some links for UK vendors _________________ Cream Puff
'79 CA Stock FI Deluxe Campmobile
Earl Grey
'87 GoWesty 2.2 Westfalia
Marsha Mellow
'00 Eurovan VR6 Full Camper |
Posted: Thu Sep 07, 2017 12:25 am Post subject: Re: 1979 California Aftermarket Exhaust |
One last question before I start ordering parts...
As a fuel injected bus, I assume there is a lambda sensor?
Goes into the cat from what I remember?
Therefore, will the lambda sensor reach the hole on the Vintage Speed exhaust, which seems to be on the other side to the original cat placement.
Posted: Thu Sep 07, 2017 12:48 am Post subject: Re: 1979 California Aftermarket Exhaust |
Fear not!
Managed to find a picture from above, where I can see two holes.
