cmayna Samba Member
Joined: August 18, 2014 Posts: 1143 Location: SF Bay area, CA
Posted: Tue May 23, 2017 12:24 pm Post subject: What gauge wire for Westy 110v extension cord? |
My Westy did not come with an extension cord to power the fridge, etc, when we're a a campground that supplies 110v. What is the best gauge and length recommended? _________________ '90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17009 Location: Retired South Florida
Posted: Tue May 23, 2017 12:31 pm Post subject: Re: What gauge wire for Westy 110v extension cord ? |
Hello, I have something similar to this.
http://www.campingworld.com/shopping/item/25-15-amp-locking-extension-cord-with-light/102463
What makes it nice is the cord has a tiny light to let you know if you have power. Sometimes the breaker is popped. You will also want an adapter since some sites don't have 15 amp service. 15 amp to 30 amp. _________________ ☮️ |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6235 Location: Portland OR
Posted: Tue May 23, 2017 12:46 pm Post subject: Re: What gauge wire for Westy 110v extension cord? |
You really don't need much. A standard 16 ga will work fine. I wouldn't go longer than 50'. The power draw is really low for those items. _________________ 89 Westy 2.1 Auto |
kamzcab86 Samba Moderator
Posted: Tue May 23, 2017 1:02 pm Post subject: Re: What gauge wire for Westy 110v extension cord? |
PDXWesty wrote: |
You really don't need much. A standard 16 ga will work fine. I wouldn't go longer than 50'. The power draw is really low for those items. |
That's what my van came with, 25' 16-gauge and it's probably 20 years old at this point. I do like that light-up version...
Edit Dec. 2017: Replaced ancient 16-gauge with this lighted 25' 14-gauge: https://www.lowes.com/pd/Utilitech-Pro-25-ft-15-Am...rd/3191689 . _________________ ~Kamz
2016 Golf GTI S
j.l.godoy Samba Member
Joined: November 18, 2010 Posts: 12 Location: Souther California
Posted: Tue May 23, 2017 1:12 pm Post subject: Re: What gauge wire for Westy 110v extension cord? |
14 g wire is practical, and ez to work.. I use that gage regurly.. |
bluebus86 Banned
Posted: Tue May 23, 2017 1:27 pm Post subject: Re: What gauge wire for Westy 110v extension cord? |
j.l.godoy wrote: |
14G if you can afford it and have the little extra space for it, that way you can use it for say powering an electric heater, a coffee maker, microwave, hair dryer with little voltage drop. Its handy to have over sized for your expected needs, just to cover you for them unexpected needs.
longer cords should be fatter than very short ones for reduced voltage drop.
good luck _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3786 Location: VA/TN
Posted: Thu Dec 14, 2017 8:07 am Post subject: Re: What gauge wire for Westy 110v extension cord? |
25ft or 50ft? I guess it would be really rare that I would need a 50ft. That and it would need to be 12 gauge at 50ft = a lot of space.
Looks like 12 gauge is very common size.
I can get 50ft 12 gauge for same price as a 25ft 12 gauge.
I think most power (possible anyway) is me running a 1500w electric heater. I may have to bypass the breaker system and run the cord in through the window _________________ Brandon
Instagram @joannthevan |
RicoS Samba Member
Posted: Thu Dec 14, 2017 8:37 am Post subject: Re: What gauge wire for Westy 110v extension cord? |
cmayna wrote: |
. . . What is the best gauge and length recommended |
Since I've never been into that camping thing, I can't advise you from experience about what drop cord works best for a Westy.
What I can say is roll you're own from some SO cord with industrial grade plug and cap (aka, connector).
By no means cheap. but an SO drop cord will outlive you.
As with a lot of things, when it comes to wire gauge, the bigger the better or, more accurately, the bigger, the more versatile. I would hesitate to make up a drop cord less the 14 AWG in size. Also, I would prefer two 25 ft. cords over one 50 ft. cord.
Richie (near The Burgh) |
Posted: Thu Dec 14, 2017 9:02 am Post subject: Re: What gauge wire for Westy 110v extension cord? |
A 50 14ga cord is going to handle a resistance load like a 1500watt heater just fine as the heater isn't going to care much if the voltage is a bit low. The cord will not overheat doing this. It would also handle the fridge just fine, but not both fridge and heater at the same time as the fridge might not like the low voltage cause by the high resistance load of the heater. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32432 Location: Reading Pennsylvania
Sodo Samba Member
Joined: July 06, 2007 Posts: 9517 Location: Western WA
Posted: Thu Dec 14, 2017 7:26 pm Post subject: Re: What gauge wire for Westy 110v extension cord? |
If you're using it all the time, like once a week, for many weeks, get a good one. Or a contractor might use it several times per day. An old contractor. One that hasn't switched over to 18V battery tools Once you switch over to battery tools the ext cords remain coiled (for long periods).
If using it 3x per year, Harbor freight has a 14ga 25ft with real nice ends for $9.99.
Westy fridge uses a tiny amount of power, any extension cord, even a lamp cord can run a westy fridge. Only worry about ext cord size if you are using a 1500w heater (~13Amps) for example. _________________
....KTMs, GasGas, SPOT mtb |
Jeffrey Lee Samba Member
Joined: February 04, 2014 Posts: 1488 Location: Wisconsin
Posted: Thu Dec 14, 2017 8:02 pm Post subject: Re: What gauge wire for Westy 110v extension cord? |
I switched the male end of my extension cord to a 90-degree angle plug.
I find this fits better than a standard straight plug by allowing the swing-down lid on most campsite power stations to completely close when plugged in, for better rain protection.
_________________ Camp Westfalia
Camping Tips • Newsletter • Cool Campervan Apparel
www.CampWestfalia.com |
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Fri Dec 15, 2017 1:34 am Post subject: Re: What gauge wire for Westy 110v extension cord? |
djkeev wrote: |
As a contractor I've dozens of cords, two or three of the better ones I really like and use frequenly |
Sodo wrote: |
Or a contractor might use it several times per day. An old contractor. |
Lol _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
Posted: Fri Dec 15, 2017 2:37 am Post subject: Re: What gauge wire for Westy 110v extension cord? |
Mellow Yellow 74 wrote: |
djkeev wrote: |
Sodo wrote: |
Lol |
Yep..... I'm old.
But
While I've embraced battery powered tools, they are only good for small fast tasks.
Real work still requires the unwavering strength of hard wired tools.
Or cordless battery rechargers need an extension cord to the work area,
True confessions, I carry an uber cheap 16ga extension in my Van. It is small and takes up little space.
I carry it to top off my house batteries when parked for extended time periods.
I've used it exactly once.
Right now at current ourside remoerature of + 12* F it is so stiff that I'd be afraid to uncoil it for fear of cracking!
At home I run a quality commercial cord to my Van. It holds up to the elements well...... and withstands abuse from the snow plow, I just plowed it yesterday, I saw the yellow coil tossed aside..... "crap!" ...... but it was fine, the plug harmlessly pulled out.
Ghia
Vanagon
Beetle
dobryan Samba Member
Joined: March 24, 2006 Posts: 16474 Location: Brookeville, MD
Posted: Fri Dec 15, 2017 5:36 am Post subject: Re: What gauge wire for Westy 110v extension cord? |
Jeffrey Lee wrote: |
But in the outlet showne the plug has to go in with the cord facing upward which is not desirable. _________________ Dave O
The Western Syncro build
Posted: Fri Dec 15, 2017 8:32 am Post subject: Re: What gauge wire for Westy 110v extension cord? |
The plug ends are available in a variety of orientations, to suit one's needs/preferences.
When I occasionally encounter an 'upside-down' outlet, I've found that a gentle 180-degree bend in the cord suffices, and still allows the cord to lie flat inside the closed power station. _________________ Camp Westfalia
Posted: Fri Dec 15, 2017 10:12 am Post subject: Re: What gauge wire for Westy 110v extension cord? |
I can't think of a camp site we stayed at with hookups that required a 50 foot extension cord. I can tell you, that getting on the road the next morning, the cord is usually covered in dew and dirt and needs to be cleaned/dried as you coil it up to pack it away. So a longer cord is more to deal with if you don't need the extra length. _________________ ☮️ |
Posted: Fri Dec 15, 2017 10:45 am Post subject: Re: What gauge wire for Westy 110v extension cord? |
MarkWard wrote: |
I can't think of a camp site we stayed at with hookups that required a 50 foot extension cord. I can tell you, that getting on the road the next morning, the cord is usually covered in dew and dirt and needs to be cleaned/dried as you coil it up to pack it away. So a longer cord is more to deal with if you don't need the extra length. |
Boom this is what I needed. The only reason I thought I would need more than 25foot is for driveway camping. Imma cop a 25 footer.
25ft 14 Gauge Heavy Duty Indoor/Outdoor SJTW Lighted Locking Extension Cord by Watt's Wire for $25
Posted: Fri Dec 15, 2017 10:49 am Post subject: Re: What gauge wire for Westy 110v extension cord? |
No reason you couldn't get a second 50 footer cord and store it out of the way. This way, if you are driveway camping or where you need some length, you'd could actually combine the two cords and have 75 feet total. _________________ ☮️ |
Kirsche Wasserboxer Samba Member
Joined: November 03, 2016 Posts: 104 Location: Seattle
Posted: Fri Dec 15, 2017 11:24 am Post subject: Re: What gauge wire for Westy 110v extension cord? |
MarkWard wrote: |
No reason you couldn't get a second 50 footer cord and store it out of the way. This way, if you are driveway camping or where you need some length, you'd could actually combine the two cords and have 75 feet total. |
That is exactly what I do. They both store under the rear seat in coils. _________________ 1990 Westfalia Vanagon
2.1 Wasserboxer |
