Rathguten Samba Member
Posted: Tue May 23, 2017 2:31 pm Post subject: I need help with some split tail lights. |
I purchased these lights for my December '49. I'm building my car to be a driver, so I'm not really concerned with correctness. The seller stated that the parts are original. However, I am not familiar with them and was hoping to get some guidance as to what these parts are or aren't.
Both lenses appear to be the same and have a Hassia logo with the number K1533. The housings have different stampings. The left side is stamped L443.001.2 with a VW and Hella logo on the bottom part and an ink stamp of K0815 on the inside surface. The right side housing has RT1???? with an SB logo stamped on the bottom. The lens retaining rings are also differently shaped.
The brackets appear to be for the same side, but I don't know which side. If someone can help me with that it would be great! Both are stamped with the number 111 945 162 along with a VW and SB logo.
The seals do not have any numbers that I can see.
If anyone can tell me a little more about these parts I would really appreciate it.
Thanks!
kdf38 Samba Member
Posted: Tue May 23, 2017 4:09 pm Post subject: Re: I need help with some split tail lights. |
111 945 161 - Left side
111 945 162 - Right side
The 1 at the end of the part number means left side.
The 2 at the end of the part number means right side.
Mike |
splitjunkie Samba Member
Posted: Tue May 23, 2017 7:03 pm Post subject: Re: I need help with some split tail lights. |
The Hella and SB or SHO as some call them were different suppliers to VW. I had a split with a mismatched pair of housings and they are definitely shaped differently. I noticed it but you might not. The bulb holders will work fine with either version of the housing. _________________ Chris
rod_vw Samba Member
Joined: December 20, 2006 Posts: 416 Location: Shropshire, UK
Posted: Sat May 27, 2017 4:38 am Post subject: Re: I need help with some split tail lights. |
If you are building it as a 'driver' then you may want to consider fitting double filament bulb holders & bulbs (Stop Light & Tail Light). Maybe Sam in Spain can supply the brackets / bulb holders for these bulbs. http://www.repuestossam.com/en/beetle/split/s033.html
I've fitted these to my '46 with LED Stop & tail bulbs for safety on the highway.
Rod _________________ Rod,
Please visit http://www.historicvws.org.uk
https://www.facebook.com/historicvwclub/
1946 Beetle (Back on the road after over 50 years! Last major outing - Hessisch Oldendorf 2022)
2016 T6 Selfbuild Camper and a LWB MAN TGE in build. |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Sat May 27, 2017 8:08 pm Post subject: Re: I need help with some split tail lights. |
Since you don't care about originality, you won't care that those running lights and bulb holders are for a 50 or later split.
You'll definitely need to change the bulb holders and wiring to turn running lights into brake lights, and still use the stock brake light.
I'd like to see more of your 49. I have an October 1949 split. |
pastellgreen Samba Member
Joined: January 06, 2012 Posts: 1049 Location: Germany
Posted: Sun May 28, 2017 1:47 am Post subject: Re: I need help with some split tail lights. |
rod_vw wrote: |
Rod |
I also bought these from sam and have to fit them during the next weeks - am I right to say, a hole need to be drilled for getting the wires through it and also they need to be bend in the lower area where the lower screw of the housing will attach? I just ask becuase I have no original one to compare... |
rod_vw Samba Member
Posted: Sun May 28, 2017 2:00 am Post subject: Re: I need help with some split tail lights. |
The ones that I purchased from Sam were the early pattern for my '46 and did not need any modification to fit rear wings (fenders) with the dent for the light bracket. i.e. this type http://www.repuestossam.com/en/beetle/split/s037.html You will notice that he also supplies these to fit a normal wing.
I can't say if the later versions like yours will need any modification as I have never used them. _________________ Rod,
rs58rag Samba Member
Joined: August 22, 2010 Posts: 419 Location: riverside,ca
Posted: Mon Jun 19, 2017 10:44 pm Post subject: Re: I need help with some split tail lights. |
At least you have original split taillights... no reproduction taillights that were made six months ago. |
