911pickup Samba Member
Joined: March 06, 2004 Posts: 625 Location: Near Goats on the Roof
Posted: Wed May 24, 2017 4:23 pm Post subject: Backup light wires |
Subject: Backup light wires
I've got my engine back in but I've forgotten where one of the wires that comes off the tranny nosecone goes.
I know that one of the wires goes to the positive side of the coil and the other is supposed to go to the backup lights, but where exactly is that?
I can't figure out where to plug that wire in/to.
These aren't factory wires. Someone rewired them. |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2766 Location: The World's Motor Capital
Posted: Wed May 24, 2017 6:41 pm Post subject: Re: Backup light wires |
If you are able to follow the wires in the engine compartment, you will be looking for the blue wires in the tail light assemblies. The wire from the backup light switch on the transmission (probably a black wire) that carries +12V (with ignition on and transmission in reverse) runs to each of the blue wires. If memory serves, it runs first to the passenger side taillight assembly, then across the rear of the engine compartment to the driver's side taillight.
Hope that helps, Mondshine
Posted: Thu May 25, 2017 8:36 pm Post subject: Re: Backup light wires |
Thanks mondshine. I did a search and someone else had mentioned the blue wire connection. So far I haven't been able to find that blue wire, but I'll keep on looking. |
Posted: Fri May 26, 2017 4:30 am Post subject: Re: Backup light wires |
The blue wires are in the harnesses that are part of the taillight assemblies. |
Posted: Fri May 26, 2017 6:12 am Post subject: Re: Backup light wires |
So the blue wires should be at the back of the vehicle, below the backup light housing?
I see where the wires come out of the rear light housing, but I can't see a blue wire.
While I'm taking about wires, does anyone know what this wire spade should be connected to? It's located just to the right of the fan shroud, where the bundle of wires comes into the engine compartment. The spade seems to be longer than normal.
Posted: Fri May 26, 2017 7:01 am Post subject: Re: Backup light wires |
Take a look at this photo:
This is the rear corner of my engine compartment; driver's side.
Yes, I know it's filthy in there.
The white jacket at the top of the photo is the wiring harness that is part of the tail light assembly.
Two wires are called out.
The blue wire is connected to the center contact of the reverse light bulb.
On the other side of the (non stock) terminal block, that blue wire is connected to a black wire, which is inside the harness which passes along the rear of the engine compartment floor. That black wire is connected to the blue wire of the passenger side tail light harness, and ultimately to the reverse light switch on the transmission. When the blue wires are connected to +12V, the reverse lights light.
Re: your photo, the male spade is longer than normal because it is designed to lock into a plastic insulating sleeve. It is possible that it is the wire you are looking for; the wire from the reverse light switch on the transmission. Crawl under the car, poke your head in there and check it. Check that wire to determine if it carries +12V when the ignition is switched on and the transmission is in reverse. If that is the reverse light power, connect it to the blue wires in your tail light harnesses.
Be certain that all of your connections are properly insulated!
Good luck, Mondshine |
Posted: Fri May 26, 2017 12:18 pm Post subject: Re: Backup light wires |
911pickup wrote: |
I did put power to that long spade, but it didn't turn the backup lights on.
I'll have to do some more exploring later today. I'm not sure if I mentioned this or not, but somewhere in the past someone rewired the backup light wires from the coil to the tranny and from the tranny to the backup lights.
Mondshine, thanks for the response. |
Posted: Fri May 26, 2017 12:36 pm Post subject: Re: Backup light wires |
911-
Read my previous post again.
What I said was that the long spade connector might be providing power for the reverse lights.
Check it with your VOM or test light with the ignition switched on and the transmission in reverse.
In the photo I posted, you can see that the blue wires are only in the tail light assemblies and their associated wiring harness. Look at that photo again.
Posted: Fri May 26, 2017 3:18 pm Post subject: Re: Backup light wires |
The black wire with the long spade was the correct wire after all. Backup lights are now working.
Thanks mondshine. |
