exhaust recommendation, stock tailpipe locations
Page: 1, 2, 3, 4  Next
Projectp
Projectp is offline
PostPosted: Wed May 24, 2017 5:50 pm    Post subject: exhaust recommendation, stock tailpipe locations Reply with quote
Looking for an exhaust, car is a 65 with stock 1600 dual port running dual weber 40 ifs. What i'm looking for:
- Definitely need stock pea shooter location tailpipes.
- Ground clearance also a must.
- Would also like to retain heat (massachusetts) but its not a deal breaker.
- I don't mind it being loud but i don't want it to be obnoxious.
So far found these 3, any thoughts on these? Thanks
http://www2.cip1.com/ProductDetails.asp?ProductCode=C23%2D35171S
http://vwparts.aircooled.net/Vintage-Speed-SS-Sport-Muffler-155-212-05200-p/155-212-05200.htm
http://vwparts.aircooled.net/Tri-Mil-Hotdog-Muffler-VW-Beetle-and-Ghia-p/tri-mil-hotdog.htm
mcmscott
mcmscott is offline
PostPosted: Wed May 24, 2017 6:25 pm    Post subject: Re: exhaust recommendation, stock tailpipe locations Reply with quote
None of these are "performance" exhausts, if you dont mind leaving ponys on the ground then any of these will work. As far as that goes you could also just use a stock exhaust
There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
[email protected]
john@aircooled.net is offline
PostPosted: Wed May 24, 2017 6:54 pm    Post subject: Re: exhaust recommendation, stock tailpipe locations Reply with quote
The EMPI and Tri-mil are loud, the VS has an "extra quiet" option which makes it very quiet.
There is also the A-1 pea shooter muffler with the sidewinder header, but that is a pricey combo and has no preheat option.
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
Projectp
Projectp is offline
Its just a stock 1600, I doubt any of these would give a noticeable gain anyways. Mostly just looking to change the sound/the dinky look of the stock pea shooters.
[email protected]
PostPosted: Wed May 24, 2017 6:57 pm    Post subject: Re: exhaust recommendation, stock tailpipe locations Reply with quote
another option is to simply use a flared tail pipe insert, they do give a very different look and sound, even with the stock muffler.
Projectp
Projectp is offline
PostPosted: Wed May 24, 2017 7:08 pm    Post subject: Re: exhaust recommendation, stock tailpipe locations Reply with quote
That A-1 isn't available for heater boxes, and id need to get a header additionally correct? Also need to remove the muffler to adjust the valves it looks like? Might be more trouble than its worth.
I don't mind if its a bit loud as long as it doesn't sound stupid. Watched a few videos of the tri-mil and it sounded good, though its tough to tell just by a video.
mcmscott
mcmscott is offline
PostPosted: Wed May 24, 2017 7:12 pm    Post subject: Re: exhaust recommendation, stock tailpipe locations Reply with quote
The "hot dog" muffler sounds more like an untuned, over pressurised fart than any thing else, sorry, I dont see down grading an exhaust system just for the sound
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
Projectp
Projectp is offline
PostPosted: Wed May 24, 2017 7:13 pm    Post subject: Re: exhaust recommendation, stock tailpipe locations Reply with quote
Didn't think of that, thats a good idea. I see vintage speed makes some nice stainless tips. Since this is a stock 1600 with just dual carbs, does replacing the whole system make a negligible performance gain? If so I'd rather just replace the pea shooters as the stock exhaust on my car is actually in great shape.
Projectp
Projectp is offline
PostPosted: Wed May 24, 2017 7:15 pm    Post subject: Re: exhaust recommendation, stock tailpipe locations Reply with quote
If thats the case than that option is definitely out. Thanks for the input.
Sharp64
Sharp64 is offline
PostPosted: Wed May 24, 2017 7:35 pm    Post subject: Re: exhaust recommendation, stock tailpipe locations Reply with quote
What would you suggest? I'm going to be in the market for an exhaust for the 1776 I'm building. Dual Kadrons. I would prefer not too loud and stock exhaust exits and heater capabilities.
1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine
bugguy1967
bugguy1967 is offline
PostPosted: Wed May 24, 2017 8:02 pm    Post subject: Re: exhaust recommendation, stock tailpipe locations Reply with quote
Your options from worst to best for a stockish 1600:
EMPI/Tri-Mil Euro 2-Tip. Usually painted yellow inside, has chrome tips, and appears to be a glass pack. It also sucks balls.
A1 1 1/2" Sidewinder with stock exiting location.
Vintage Speed Mufflers, low dbm, good for lower performance
CSP Super Competition Exhaust - 1 1/2" primaries, twin mufflers, exits through stock locations
Ahnendorp B.A.S. Customsport SS Exhaust (item#21113) - equal length primaries, can use heater boxes
I vote for Ahnendorp. Look on their website. The pics speak for themselves!
piperj
piperj is offline
PostPosted: Wed May 24, 2017 8:13 pm    Post subject: Re: exhaust recommendation, stock tailpipe locations Reply with quote
4-5 years ago I went through the same decision process for my bug with a 1915 motor . I was looking to install in the standard apron cutouts , hook up to the heater box system and not have an issue with raspy exhaust note. I ended up going with the Vintage Speed Box and have been quite happy with it. The Dansk box was not available at that time. What I found is that you need compatibility between the muffler and the heater or J tube with respect to where the exhaust flange hooks to the muffler. The flange "clocking" has to match the muffler. If you consider the VS muffler I would work with John at ACN and make sure it will adapt to your heater box or J tube...just my input.
John
67 Sun Roof Bug
mcmscott
mcmscott is offline
PostPosted: Wed May 24, 2017 8:33 pm    Post subject: Re: exhaust recommendation, stock tailpipe locations Reply with quote
Stock heater boxes,,= 1 3/8" exhaust at best, nothing more. Chocking 2 cylinders so you can have 2 flow more is stupid.
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
bugguy1967
PostPosted: Wed May 24, 2017 8:39 pm    Post subject: Re: exhaust recommendation, stock tailpipe locations Reply with quote
Right. Stock boxes are actually smaller than 1 3/8". A lot of these European exhausts bolt-up to 1 1/2" boxes
Sharp64
Sharp64 is offline
PostPosted: Wed May 24, 2017 8:42 pm    Post subject: Re: exhaust recommendation, stock tailpipe locations Reply with quote
Didn't say stock heater boxes.
1967 Ghia
mcmscott
mcmscott is offline
PostPosted: Wed May 24, 2017 8:45 pm    Post subject: Re: exhaust recommendation, stock tailpipe locations Reply with quote
Also didn't say "1 5/8" heater boxes" so the assumption is???
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
EVfun
EVfun is offline
PostPosted: Wed May 24, 2017 8:48 pm    Post subject: Re: exhaust recommendation, stock tailpipe locations Reply with quote
He may be willing to change them to suit the chosen system.
Wildthings wrote:
Sharp64
Sharp64 is offline
PostPosted: Wed May 24, 2017 9:01 pm    Post subject: Re: exhaust recommendation, stock tailpipe locations Reply with quote
No assumption. You're a dick.
Basically the way it looks is the only way to keep heater boxes and have a stock exiting exhaust is to upgrade to larger heater boxes and get a CSP which puts it in the range of $1500.
Sorry for the hijack OP. Carry on.
1967 Ghia
Projectp
Projectp is offline
PostPosted: Thu May 25, 2017 4:51 am    Post subject: Re: exhaust recommendation, stock tailpipe locations Reply with quote
Don't worry about it! Keeps the conversation goin.
jeffinohio
jeffinohio is offline
PostPosted: Thu May 25, 2017 5:13 am    Post subject: Re: exhaust recommendation, stock tailpipe locations Reply with quote
I am running the EMPI GT on my 1600.It is a little louder than stock,but has a nice deep tone.I really like the sound of it.Actually fit as well.The large tips look cool.
64 Sunroof
73 Standard
70 Convertible
67 Cougar
3 Subarus
Page 1 of 4
