Re torque head studs?
jeffinohio
jeffinohio is offline
PostPosted: Fri May 26, 2017 8:17 am    Post subject: Re torque head studs? Reply with quote
I have seen some people suggest retorquing the bottom head bolts when you have the valve covers off.Ive never done it as the head is supposed to be torqued in a specific order.Are a lot of you guys doing this?Should I?Thanks JK
64 Sunroof
73 Standard
70 Convertible
67 Cougar
3 Subarus
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri May 26, 2017 8:33 am    Post subject: Re: Re torque head studs? Reply with quote
Never done it and thing doing the bottom without the top is a waste of time.
Glenn
Member #1009
#BlueSquare
vwracerdave
vwracerdave is offline
PostPosted: Fri May 26, 2017 9:12 am    Post subject: Re: Re torque head studs? Reply with quote
Nope.
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos
FreeBug
FreeBug is offline
PostPosted: Fri May 26, 2017 10:45 am    Post subject: Re: Re torque head studs? Reply with quote
If that were necessary, VW would have gone out of business long ago...23 million new engines sold...imagine 23 million customers coming back for a re-torquing!
jeffinohio
PostPosted: Fri May 26, 2017 11:04 am    Post subject: Re: Re torque head studs? Reply with quote
That was my thinking as well.Why would you re torque half the studs?
64 Sunroof
73 Standard
70 Convertible
67 Cougar
3 Subarus
vwjetboat
vwjetboat is offline
PostPosted: Fri May 26, 2017 11:32 am    Post subject: Re: Re torque head studs? Reply with quote
It is common practice in any vw shop when doing a valve adjustment on an old motor to re torque the bottom Nuts.. was doing it 33 years ago.. and its still done at most shops.. why ?
Ok so you put torque wrench on and they are almost right on the number.. just a tad tad loose.. then the rest on top are most likely tight too..
Ok so you put torque wrench on and they are loose.. you stop .. call customer and recommend the motor be pulled and heads re torqued..
If it is your personal car.. then you should check the bottom nuts..or wait till it starts popping..and spend more money.. for something that just a little labor could have solved..
maui
maui is offline
PostPosted: Fri May 26, 2017 11:52 am    Post subject: Re: Re torque head studs? Reply with quote
You're correct. I've bin doing it that way for as long as you.
Mr. 010
Glenn is offline
PostPosted: Fri May 26, 2017 11:54 am    Post subject: Re: Re torque head studs? Reply with quote
Little labor?
Remove engine
Remove fan shroud
Remove intake
Remove upper cylinder tins
Torque head studs
Put it all back together
Glenn
Member #1009
#BlueSquare
vwjetboat
PostPosted: Fri May 26, 2017 12:01 pm    Post subject: Re: Re torque head studs? Reply with quote
Little labor?
Remove engine
Remove fan shroud
Remove intake
Torque head studs
half a days work.. yea.. a little labor..
Mr. 010
Glenn is offline
PostPosted: Fri May 26, 2017 12:19 pm    Post subject: Re: Re torque head studs? Reply with quote
If you're paying a shop you can be looking at $500+
I've run a number of engines for more than 100,000 miles and never retorqued the heads.
Why stop there? How about the 6 main case studs?
Glenn
Member #1009
#BlueSquare
vwjetboat
PostPosted: Fri May 26, 2017 1:08 pm    Post subject: Re: Re torque head studs? Reply with quote
Is very common for head studs to come loose.. not so much case nuts.. its called insurance.. no clue how long it takes you but I can pull a rocker arm shaft off in a few seconds few more seconds to put a torque wrench on.. if they are loose.. it needs to be addressed.. if you have never had or seen a head come loose.. then you have not been around vws much.. but its VERY VERY COMMON.. and if you can adjust valves proper.. as the OP was referring to doing, then pulling the motor and tin is not a big deal..
Mr. 010
Glenn is offline
PostPosted: Fri May 26, 2017 1:17 pm    Post subject: Re: Re torque head studs? Reply with quote
If you call owned the same VW for 43 years, for building over 40 engines, for running a local club for 20 years "not been around vws much', then yes.
My good friend owns a shop, for 45 years, that maintains over 100 aircooled VWs and i've never seen him once recommend retorqueing the heads.
I've dealt with a number of engine builders including Art Thraen, Gary Berg and Anibal Chico and have never seen anything about retorquing the heads in their instructions.
I know (2) retired VW trained mechanics and never head them talk about routinely retorqueing heads.
Doesn't seem very common to me.
Glenn
Member #1009
#BlueSquare
vwjetboat
PostPosted: Fri May 26, 2017 1:20 pm    Post subject: Re: Re torque head studs? Reply with quote
sounds like you do have a lot of experience and been around bugs a lot. I find it hard to believe you never heard a bug engine with a head popping..
Mr. 010
Glenn is offline
PostPosted: Fri May 26, 2017 1:32 pm    Post subject: Re: Re torque head studs? Reply with quote
I have... usually they are abused and overheated on a regular basis. Most have heads studs that are pulling out and retorqueing them is a band-aid... they'll continue to pull. At that point most need a top end rebuild with new p/c and a valve job if the heads don't have sunken valve seats or cracks.
I'm working on 3 engines at the moment, all needing top end rebuilds. Non has loose heads studs.
Glenn
Member #1009
#BlueSquare
vwjetboat
PostPosted: Fri May 26, 2017 1:40 pm    Post subject: Re: Re torque head studs? Reply with quote
not trying to argue with you.. I am talking from a business stand point. Someone comes in you have no clue who they are.. they want a tune up.. complete.. to us. this included oil change. check end play by hand of course.. tighten gen belt along with the normal plugs wires cap rotor points and condenser timing re-torq of lower head studs.. gently of course.. and do a compression test.. and let customer know condition of engine. .. If the valve lash is off by more then normal.. something is going on.. is the head loose? takes only a minute to check.. and that is my point.. period.. not arguing..
stanthedog
stanthedog is offline
PostPosted: Fri May 26, 2017 1:46 pm    Post subject: Re: Re torque head studs? Reply with quote
My brother had a 67 bug with a new 1835. He drove it for about a month when it started losing power, thinking it needed a tuneup he went to adjust the valves and the heads were just sloppy loose, retorqued, ran great for another month, same thing. No case savers!
Mr. 010
Glenn is offline
PostPosted: Fri May 26, 2017 1:50 pm    Post subject: Re: Re torque head studs? Reply with quote
Sounds like turning a $100 tuneup into a $1000+ job.
Glenn
Member #1009
#BlueSquare
Mr. 010
Glenn is offline
The studs are pulling out and retorqueing is a waste of time.
The case is bad.
Glenn
Member #1009
#BlueSquare
vwjetboat
PostPosted: Fri May 26, 2017 1:53 pm    Post subject: Re: Re torque head studs? Reply with quote
Actually no.. only IF there are issues.. this is why my boss had us check.. he would rather inform them later down road you will have and issue.. I have seen engines torn apart and heads were 100% trash.. there goes 500 bucks that could have been saved had the heads not been run loose.. its called doing a good service...
xzener
xzener is offline
PostPosted: Fri May 26, 2017 1:59 pm    Post subject: Re: Re torque head studs? Reply with quote
My mechanic (70 year old classic VW guru) recommended me to replace a #3 head bolt because of looseness... The motor is out, am I able to do this without a complete tear down??
My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>!
