markcm2 Samba Member
Joined: September 02, 2015 Posts: 505 Location: Bellingham, Washington
Posted: Sat May 27, 2017 12:47 pm Post subject: Sensor on block behind oil cooler leaking, what is this? 01 VR6 |
I'm trying to track down an oil leak on my 2001 weekender (vr6). After cleaning it up, it appears the sensor bolted to the block right behind the oil cooler is accumulating and dripping although Im not sure if it isn't maybe coming from something above that. I checked and it is tight.
What is this (knock sensor?) and is it a common leak point? I Dont see a crush washer, would I replace the sensor?
It's the 13mm right above the cooler
gakali Samba Member
Joined: August 19, 2007 Posts: 448 Location: Cambridge, Ontario, Canada
Posted: Sat May 27, 2017 12:53 pm Post subject: Re: Sensor on block behind oil cooler leaking, what is this? 01 VR6 |
Looks like the knock sensor. It's just bolted to the outside of the block so it can't leak.
Quite likely it's a leak from the upper timing cover and/or valve cover gasket leaking down and just dripping off the knock sensor. _________________ Why do it? Because you can.
1999 Eurovan
2003 A4 Avant 1.8T Quattro
1992 W201 190e 2.3 Mercedes
2006 W220 S600 V12 Twin Turbo 5.5 Mercedes |
bgray Samba Member
Posted: Tue Nov 23, 2021 3:23 pm Post subject: Re: Sensor on block behind oil cooler leaking, what is this? 01 VR6 |
Curious if you were able to confirm the source of the oil leak. I have the exact same situation and am trying to track it down. Per the advice of another expert, I'm planning to put some dye in the engine oil and use an ultraviolet light to see where it comes from, but wanted to check on this post.
thanks,
Brian |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22646 Location: NYC/Upstate/ROW
Posted: Tue Nov 23, 2021 7:45 pm Post subject: Re: Sensor on block behind oil cooler leaking, what is this? 01 VR6 |
That’s not coming from the knock sensor. Get some fake Brake clean up there, rinse it off, see how the oil comes back, _________________ .ssS! |
Rallyedude Samba Member
Joined: December 06, 2009 Posts: 206 Location: Aylmer, QC
Posted: Fri Dec 03, 2021 10:30 am Post subject: Re: Sensor on block behind oil cooler leaking, what is this? 01 VR6 |
That is definitely a knock sensor , the bolt does not go through the block .
My guess is head gasket leaking down . Time to pull an engine! _________________ 85 2wd Doka ABA In progress
82 westy diesel under the knife , MTDi ,weddle gears |
