Can you identify this case in this 67???
fifthcenturycheese Premium Member
fifthcenturycheese is offline
PostPosted: Mon May 29, 2017 7:03 pm    Post subject: Can you identify this case in this 67??? Reply with quote
Sorry, I don't have the serial number, does anyone out there recognize what this case might be in this 67? Can't recognize the gray painted lobe under the distributor...Thanks for your help!
aircooled
aircooled is offline
PostPosted: Mon May 29, 2017 7:55 pm    Post subject: Re: Can you identify this case in this 67??? Reply with quote
Go to the Technical tab https://www.thesamba.com/vw/archives/info/bugchassisdating.php. I can't see the serial number in your picture.
67 Sun Roof / Born Sept 66 / Second Owner
67 Convertible / Born Aug 66 / Second Owner
Member of 67 Posse
Omaha Volkswagen Club
Neb VVWCA Chapter Rep
Volkswagen Club of Nebraska
bill may
bill may is offline
PostPosted: Tue May 30, 2017 5:22 pm    Post subject: Re: Can you identify this case in this 67??? Reply with quote
good helpful info Richard.
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
PostPosted: Tue May 30, 2017 7:44 pm    Post subject: Re: Can you identify this case in this 67??? Reply with quote
I was able to take a picture of the engine case today, here is the number...
Looks like H 5441999 Looks like someone painted it for some reason, either bad paint or case got too hot???
Thanks again....Mike
tasb Premium Member
The Distributor Distributor
tasb is offline
PostPosted: Tue May 30, 2017 8:47 pm    Post subject: Re: Can you identify this case in this 67??? Reply with quote
At the technical tab atop this page you will find a link to a VIN list. It starts with Bus so click on Bug. I'm not seeing an H case by itself. Likely restamped.
Cases are often painted when they are rebuilt to make them look all purty. Flaking paint on a case is as much and indicator of old rebuild as it is having gotten too hot. Heat cycles in an engine are a parts of it's multiple lives.
Roads Scholar & distributor restorations
1956 oval third owner 36 hp- slow drag Champion 2012, 2014, 2015, 2017
1957 Kombi low mileage 36 hp governor equiped M 178 Slow Drag Winner 2014, 2015, 2018
1960 sunroof beetle owned since 1991 36 hp
1965 hrdtop Deluxe Microbus owned since 1990 M 620 factory 12 v 1500cc
PostPosted: Tue May 30, 2017 8:55 pm    Post subject: Re: Can you identify this case in this 67??? Reply with quote
Tasb, could this be an "H 5" case maybe?
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Wed May 31, 2017 6:26 am    Post subject: Re: Can you identify this case in this 67??? Reply with quote
H5 yes and this is a perfect example of what happens when you paint a case.
Cusser
Cusser is offline
PostPosted: Wed May 31, 2017 6:51 am    Post subject: Re: Can you identify this case in this 67??? Reply with quote
H5 typical case for 1500 SP engine.
1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2005 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297
