videoguy009 Samba Member
Joined: March 31, 2008 Posts: 711 Location: Saint John N.B. Canada
Posted: Tue May 30, 2017 5:50 pm Post subject: Cranking coming to a quick stop when turning pulley clockwise |
My car was idling the other day and the motor came to a sudden stop and quit.I have a situation where if I turn the crank pulley with a wrench to the left it will turn all day.When I turn it clockwise a couple rotations it ends up stopping quick as if the crank is hitting something in the case.If I back and forth it it will move counter then stop on the same spot clockwise.It is a 73 beetle semi auto 1600 DP.I don't think a rod is broken as I cannot hear anything while rotating.I was thinking of checking the oil pump,distributor drive gear and distributor,etc for binding before doing a possible tear down.Could it be something to do with the torque converter and flex plate at the front of the engine.The car always shifted great! _________________ 1971 Super Beetle |
Bama Dave Samba Member
Posted: Tue May 30, 2017 5:56 pm Post subject: Re: Cranking coming to a quick stop when turning pulley clockwise |
Pull the engine and see if it turns while disconnected from trans. Either way, I think your gonna have to do that. _________________ David Richerson
1970 Beetle
1971 Super
1972 Baja
hellthorne wrote: |
First off, I know i made stupid decisions that led to my predicament, so while you are welcome to tell me that I am an idiot for doing the things I did, please know that I am already aware of this. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue May 30, 2017 6:05 pm Post subject: Re: Cranking coming to a quick stop when turning pulley clockwise |
Yes, engine pull time, with any luck you'll find a foreign object in the bellhousing. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
buggnuttz Samba Member
Joined: January 28, 2006 Posts: 404 Location: southern cheeseland
Posted: Tue May 30, 2017 6:56 pm Post subject: Re: Cranking coming to a quick stop when turning pulley clockwise |
check your valves ive had two different motors drop a valve at idle with same symptoms _________________ owned 39 different VWs so far |
rosevillain Samba Member
Joined: December 28, 2005 Posts: 1290 Location: roseville, ca
Posted: Tue May 30, 2017 10:03 pm Post subject: Re: Cranking coming to a quick stop when turning pulley clockwise |
Is it possible that your distributor clamp slipped and allowed the distributor to lift a bit? That would allow the drive gear to lift when you rotate clockwise and jam the gear. Counter cl9ckwise would drive the drive gear down. Or maybe I'm backwards? |
