aeromech Samba Member
Joined: January 24, 2006 Posts: 16959 Location: San Diego, California
Posted: Tue May 30, 2017 6:55 pm Post subject: 1971 stock muffler modification? |
I'm building an 1800 type 1 for my 1971 bus. I want to use all stock components but will modify the carburetor to flow more. I am trying to pick an appropriate exhaust and need good manifold preheat. Is it possible to modify a stock exhaust to flow more air? Is there a better option for me? Please keep in mind that I've given this a lot of thought and looked at several exhausts. I want one as quiet as possible too. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
bay window dude Samba Member
Joined: June 22, 2007 Posts: 144 Location: Portland, OR
Posted: Tue May 30, 2017 8:30 pm Post subject: Re: 1971 stock muffler modification? |
I'm sorry, I should have mentioned that I'm using stock heater boxes. I've considered Vintage Speed but have heard they are loud and crack out. If I could make my stock muffler flow about 25% more I think I'd be happy _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
richparker Samba Member
Joined: November 24, 2011 Posts: 6980 Location: Durango, CO
Posted: Tue May 30, 2017 8:43 pm Post subject: Re: 1971 stock muffler modification? |
I agree that Gary should go with a VS Sport exhaust, but I think a stock port would be fine. However, I think the "bad press" has made him lean against one. There is a total of 25k on mine and it's the best all around system I've had on my bus. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Tue May 30, 2017 9:05 pm Post subject: Re: 1971 stock muffler modification? |
Maybe I should call Tiger? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2078 Location: Bulli Klinik, Colorado Springs
Posted: Tue May 30, 2017 10:03 pm Post subject: Re: 1971 stock muffler modification? |
How about a beetle muffler? I've run one on my 70 for years. I've also run one on a split with dual pipes similar to a single peashooter.
My old split:
_________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Tue May 30, 2017 11:40 pm Post subject: Re: 1971 stock muffler modification? |
The split stock pipe system above has always intrigued me, but the stock restrictors in the 2/4 manifolds would hold WAY more flow back than the tailpipe. Remember, exhaust gases shrink as they cool, so the farther downstream a pipe is, the less large is has to be to flow the same amount as something upstream.
Didn't someone on here recently drill out the "cone" waffle restrictors in the 2/4 headers? Anybody?
www.airschooled.com |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22639 Location: NYC/Upstate/ROW
Posted: Wed May 31, 2017 4:06 am Post subject: Re: 1971 stock muffler modification? |
aeromech wrote: |
Maybe I should call Tiger? |
I think he is DUI, not DIY, right now.... _________________ .ssS! |
Posted: Wed May 31, 2017 5:54 am Post subject: Re: 1971 stock muffler modification? |
Abscate wrote: |
aeromech wrote: |
I think he is DUI, not DIY, right now.... |
Hahah, different guy _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Wed May 31, 2017 6:19 am Post subject: Re: 1971 stock muffler modification? |
asiab3 wrote: |
Robbie |
On page 4 of this thread RayGreenwood talks about taking the cones out, less restrictive but LOUD.
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=60 _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Wed May 31, 2017 7:07 am Post subject: Re: 1971 stock muffler modification? |
If you are running stock size valves a stock carb and heater boxes, you will be fine running a stock Beetle exhaust. Even with the extra displacement.
I've had the same setup in my Dormobile (1776) for over 50K miles. I use these oversize tail-pipes on mine so it doesn't whistle like a Bug.
Mike K
Bulli Klinik
Colorado Springs |
Posted: Wed May 31, 2017 7:44 am Post subject: Re: 1971 stock muffler modification? |
I don't want to run a bug exhaust with two pea shooters. I guess you're saying I need to for the extra flow. Can I get a muffler shop to weld on a larger outlet pipe to a stock bus muffler? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Wed May 31, 2017 7:53 am Post subject: Re: 1971 stock muffler modification? |
With a welder and some skill, anything is possible.
Here's a link to help you determine if you want to or not:
http://www.vwdcqinc.org.au/insideabug-insideamuffler
After thinking about it, I think one could make a single tailpipe which joins the two exhaust outlets into a single, side outlet with a slightly bigger pipe.
I'm stuck with a stock-style exhaust because I have a trailer hitch. _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51124 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed May 31, 2017 7:58 am Post subject: Re: 1971 stock muffler modification? |
How about a bug muffler with a modified custom zoom tube? I guess you'd have to add the diameter of the 2 slightly smaller outlets together to determine the potential % of gain. Lining the tube with the perforated stuff like the stock damper pipe may even quiet it down enough to compensate for removing the cones.
I experimented with a larger tailpipe a few years ago and discovered I lost much of the low end torque, but that was with a stock engine, displacement and cams will no doubt interact differently. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed May 31, 2017 8:11 am Post subject: Re: 1971 stock muffler modification? |
That's got my attention. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Brian Samba Moderator
Posted: Wed May 31, 2017 12:09 pm Post subject: Re: 1971 stock muffler modification? |
-1 for the VS
+1 for modifying a bug muffler _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Wed May 31, 2017 12:34 pm Post subject: Re: 1971 stock muffler modification? |
Brian wrote: |
+1 for modifying a bug muffler |
Hypothetically; can't you just stick two bus damper/tail pipes into a bug muffler and call it a day?
Brian wrote: |
-1 for the VS |
+1 for not smashing yours into rocks on three occasions…
Posted: Wed May 31, 2017 1:08 pm Post subject: Re: 1971 stock muffler modification? |
asiab3 wrote: |
Brian wrote: |
Brian wrote: |
-1 for the VS |
Robbie |
Robbie, isn't that what Bulli is showing in the pic above with the Split?
Brian is like Stu, they just beat the living shit out of stuff. Don't think I'd listen to a review from either one of them. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Wed May 31, 2017 1:29 pm Post subject: Re: 1971 stock muffler modification? |
No Rich, it's actually very useful information if you want to know what five years of wear and tear looks like in a fraction of the time. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Wed May 31, 2017 1:47 pm Post subject: Re: 1971 stock muffler modification? |
yea, what's his name with the nice bus did that as well. you just weld in some t3 stuff or something like that and you have ''sport'' muffler.
aeromech wrote: |
No Rich, it's actually very useful information if you want to know what five years of wear and tear looks like in a fraction of the time. |
you both have a point there. Rich you saw the other thread going on in the performance section about the VS mufflers, they're well built but some aren't meant to last. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
