Any upgrades I should/could do to my split case transmission?
Rasser
Rasser is offline
PostPosted: Wed May 31, 2017 3:06 pm    Post subject: Any upgrades I should/could do to my split case transmission? Reply with quote
Hi
I am planning to take my Ghias original 1957 transmission apart winter 17/18. It doesn't have any apparent defects/faults, but it does have some slight bearing wear/noice. So my plan is to take it apart, check things over, replace the worn out bearings, fulcrum plates, synchros and what else might need changing. "If it ainīt broken, donīt fix it" Wink
But then I thought... Are there any upgrades or mods I should carry out while I have it apart?
What are the biggest weakness on these transmissions, and can the strength be improved?
I have previously rebuilt the later style tunnel transmissions, but never opened up a split trans before.
I run a 60hp 356 engine, so the transmission has a bit more power put through the gears.
Thanks
Rasmus
1957 Ghia - http://www.thesamba.com/vw/forum/viewtopic.php?t=647222
1966 Deluxe bus
[email protected]
Mr. OGPaint Premium Member
Mr. OGPaint is offline
PostPosted: Wed May 31, 2017 10:56 pm    Post subject: Re: Any upgrades I should/could do to my split case transmission? Reply with quote
Engine looks awesome!
https://instagram.com/mr_ogpaint
Patrick Hall
henry roberts
henry roberts is offline
PostPosted: Thu Jun 01, 2017 4:03 am    Post subject: Re: Any upgrades I should/could do to my split case transmission? Reply with quote
guard transmission used to make a pre a 356? limited slip diff that would fit a splitcase, but I didn't see them in their products list now.
mind you, when you add "limited slip diff" to any shopping list you know it won't be cheap, then add the prefix "Porsche" and then add "Pre A"... Shocked
i'm sure there was a post a few years ago with a fair bit of information and ideas on splitcase modifications but I can't find it.
Rasser
Rasser is offline
PostPosted: Thu Jun 01, 2017 2:41 pm    Post subject: Re: Any upgrades I should/could do to my split case transmission? Reply with quote
Please let me know if you find the thread. Searched with no results :-/.
1966 Deluxe bus
[email protected]
John Moxon Premium Member
John Moxon is offline
PostPosted: Fri Jun 02, 2017 12:22 am    Post subject: Re: Any upgrades I should/could do to my split case transmission? Reply with quote
Just had a look myself Rasmus and there's not much that likely to be relevant... Confused
https://www.thesamba.com/vw/forum/viewtopic.php?t=498142
John.
My 1958 Karmann Ghia
Rasser
Rasser is offline
PostPosted: Fri Jun 02, 2017 5:19 am    Post subject: Re: Any upgrades I should/could do to my split case transmission? Reply with quote
Thanks John.
I will most likely just do a normal rebuild, if no other tips and tricks appear Smile.
1966 Deluxe bus
[email protected]
gears
gears is offline
PostPosted: Wed Jun 14, 2017 11:44 am    Post subject: Re: Any upgrades I should/could do to my split case transmission? Reply with quote
These are still available:
aka Pablo, Geary
9.36 @ 146 in '86
'90 Syncro Westy SVX
'87 Syncro GL 2.5
Needed: Stock 14" x 6" Syncro steel rim
