partwerks Samba Member
Joined: March 27, 2007 Posts: 160 Location: Grand Island, NE
Posted: Sun Jun 04, 2017 12:14 pm Post subject: PS door handle |
On my 1996 VW Jetta, the passenger side door handle is lockable, but the 1999 VR6 Jetta, MK3 I have, it doesn't have the passenger side locking handle, and so I don't know if it originally came that way, or if it is possible to convert it to a locking handle? |
crsmp5 Samba Member
Posted: Sun Jun 04, 2017 2:45 pm Post subject: Re: PS door handle |
why would ya want too? idea is power locks mean not required why vw took it away.. but remove handle.. look to see it its got the white plastic box the lock goes into _________________ [url=http://cdn2.driiive.com/7037.jpg]Click to view image[/url] |
Posted: Sun Jun 04, 2017 3:15 pm Post subject: Re: PS door handle |
You mean the box that the tongue like wobbly paddle goes into a slot at inside the door? |
crsmp5 Samba Member
Posted: Sun Jun 04, 2017 8:28 pm Post subject: Re: PS door handle |
yup... if it lacks that.. then adding a key slot will be more work as you would require it... no key slot means the handle should come off easy to look.. but did vw redesign the powerlock switch piece on that side to eleminate the key slot.. _________________ [url=http://cdn2.driiive.com/7037.jpg]Click to view image[/url] |
dub01 Samba Member
Joined: September 21, 2016 Posts: 29 Location: Wrightsville, Pa
Posted: Mon Jun 05, 2017 5:24 am Post subject: Re: PS door handle |
crsmp5 wrote: |
yup... if it lacks that.. then adding a key slot will be more work as you would require it... no key slot means the handle should come off easy to look.. but did vw redesign the powerlock switch piece on that side to eleminate the key slot.. |
98-99 Mk3s have a different latch, so no, not without changing both the handle and the latch. |
