gunslingertom Samba Member
Joined: May 21, 2017 Posts: 67 Location: Beautiful S.W. Missouri Ozarks
Posted: Sun Jun 04, 2017 1:52 pm Post subject: Thoughts on how to cure this problem? |
We didn't get it in the video, but it gets pretty violent. Will shocks fix this, or is it an issue with the springs?
The tires are Kenda motorcycle tires with 12 lbs pressure.
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20365 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun Jun 04, 2017 1:59 pm Post subject: Re: Thoughts on how to cure this problem? |
Are they balanced?
Posted: Sun Jun 04, 2017 2:53 pm Post subject: Re: Thoughts on how to cure this problem? |
Dale M. wrote: |
Are they balanced?
Dale |
That, my friend, is a good question. I guess I should start there. It doesn't bounce until I hit a hole or bump though, and comes out of it eventually. |
enjoyther1de Samba Member
Joined: December 19, 2010 Posts: 1279 Location: chino,ca
Posted: Sun Jun 04, 2017 3:28 pm Post subject: Re: Thoughts on how to cure this problem? |
I'd put some shocks on first and go from there. Didn't see any shock in the video. _________________ HBB took me to BBV. |
Posted: Sun Jun 04, 2017 4:20 pm Post subject: Re: Thoughts on how to cure this problem? |
enjoyther1de wrote: |
I'd put some shocks on first and go from there. Didn't see any shock in the video. |
No shocks. The frame has a mount, but the lower control arm does not. I thought about welding a mount to the control arm, but they are polished chrome. |
vwjetboat Samba Member
Posted: Sun Jun 04, 2017 4:41 pm Post subject: Re: Thoughts on how to cure this problem? |
both front tires? or just the left? check torsion springs for any broke springs if its just the left side.. |
oldschool5er Samba Member
Posted: Sun Jun 04, 2017 6:55 pm Post subject: Re: Thoughts on how to cure this problem? |
You must have shocks on it to stop it while driving on the street. If you were just duning then you would get away with it. Same as getting a wobble from not having a steering dampner. |
Posted: Sun Jun 04, 2017 7:23 pm Post subject: Re: Thoughts on how to cure this problem? |
vwjetboat wrote: |
Yep, just the left. Will take it apart.
Thanks. |
Posted: Sun Jun 04, 2017 7:33 pm Post subject: Re: Thoughts on how to cure this problem? |
gunslingertom wrote: |
vwjetboat wrote: |
Thanks. |
if you find a few broken.. they broke .. because???? no shock.. |
Posted: Wed Jun 07, 2017 6:17 am Post subject: Re: Thoughts on how to cure this problem? |
Grind that gaudy chrome off and weld a shock mount on. Function before shiny shit I always say. _________________ HBB took me to BBV. |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5388 Location: Holland, MI
Posted: Wed Jun 07, 2017 8:05 am Post subject: Re: Thoughts on how to cure this problem? |
Grind that gaudy chrome off and weld a shock mount on. Function before shiny shit I always say. |
agree, 110%
A cheap way to add a mount is to weld on a 12mm rod coupler. Just grind off the zinc before welding, and make sure your shocks reach with .75" extra extension...
_________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
Posted: Wed Jun 07, 2017 8:18 am Post subject: Re: Thoughts on how to cure this problem? |
Side note: When you get that shock mount welded on I would put some regular oil filled stock shocks on that rail. I'm thinking a gas filled may be to stiff for that front end. _________________ HBB took me to BBV. |
jsturtlebuggy Samba Member
Posted: Wed Jun 07, 2017 4:45 pm Post subject: Re: Thoughts on how to cure this problem? |
What tire pressure are you using in the front tires?
As light as the buggy, anything more than 12PSI (and that high IMOP) is to much. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Posted: Thu Jun 08, 2017 5:15 pm Post subject: Re: Thoughts on how to cure this problem? |
I agree, but I hate to have to remove chrome from 4 trailing arms. Guess I could just paint them all.
Vanapplebomb wrote: |
My trailing arms have no remnant of an old shock mount whatsoever, so I'll have to do some creating gusseting.
jsturtlebuggy wrote: |
As light as the buggy, anything more than 12PSI (and that high IMOP) is to much. |
They were at 12 psi in the video. |
Posted: Thu Jun 08, 2017 5:52 pm Post subject: Re: Thoughts on how to cure this problem? |
Only need to grind two trailing arms because only the bottom ones get the mount. Creative gusseting is pretty easy with some scrap 1/4" plate. What Requires a bit more precision is getting the mounts parallel. A straight edge is your friend. _________________ 1800 Type 4 Berrien 295
Posted: Thu Jun 08, 2017 6:30 pm Post subject: Re: Thoughts on how to cure this problem? |
Side note: When you get that shock mount welded on I would put some regular oil filled stock shocks on that rail. I'm thinking a gas filled may be to stiff for that front end. |
I'm thinking about taking the torsion plates out and going with a thru rod and coil-overs. What shock would you all recommend in that case? |
Krochus Samba Member
Joined: January 01, 2017 Posts: 892 Location: NW Arkansas
Posted: Thu Jun 08, 2017 6:47 pm Post subject: Re: Thoughts on how to cure this problem? |
Gas is way way too stiff but to you know how hard it is to find oil filler shocked these days?
What I discovered by accident when my front end build went a different direction is that the commonly used air shock only really has rebound damping. Compression is just the rubber and air pressure. This makes them darn near perfect for a light buggy where you want the suspension to compress but need enough dampening to prevent the OP's problem.
I run like 40psi in them which is just enough to firm the bladder up. |
Posted: Thu Jun 08, 2017 6:54 pm Post subject: Re: Thoughts on how to cure this problem? |
I almost did this but shied away for two reasons
That 12mm stud isn't designed to carry the weight of the suspension
If you lose a shock the front is going to plow the ground and will be in for a wild ride!
So what I did was I split the difference. I removed the center block from my upper tube, that turned the upper spring pack into a sway bar and removing it from the spring rate overall but allows it to retain the arms. Like a thru rod.
With that done it was a little soft so a pair of air shocks makes up that difference with just a little air. Gas charged shocks were actually too stiff
It rides like a dream now AND handles like it's on rails |
Posted: Thu Jun 08, 2017 7:54 pm Post subject: Re: Thoughts on how to cure this problem? |
Krochus wrote: |
What shocks did you use? |
Posted: Mon Jun 12, 2017 6:20 pm Post subject: Re: Thoughts on how to cure this problem? |
I would say that going coil overs is a lot of work just to fix that problem. You could swap a pair of stock arms on there and bolt your kyb gr2 on. I all but guarantee it keeps that wheel hop in check. _________________ HBB took me to BBV. |
