nogoodwithusernames Samba Member
Joined: November 10, 2014 Posts: 599 Location: CA, USA
Posted: Sun Jun 04, 2017 5:49 pm Post subject: New Engine - Knock under load - now tuning |
Alright as the title says I'm getting a knock/rattle sound at low RPMs while under load. For sure engine speed related. Will do it taking off from stop and after changing gears.
Engine:
1956 cc setup for type 3
040 heads
New bearings, new CB crank and h-beam rods, new P&Cs.
About 10:1 compression with CB2250 cam
MS2 fuel and spark
1/4 tank of normal low octane fuel, will fill up on 91.
My thoughts are possibly spark timing or early detonation unless something catastrophic happened to my bearings?
Thanks for the help, and the entertainment that comes with posting on the samba. _________________ 71 Squareback, 1.7l T4 w/ crank trigger fuel and spark
(Conversion thread https://www.thesamba.com/vw/forum/viewtopic.php?t=732508&highlight= or https://shoptalkforums.com/viewtopic.php?f=1&t=151375&sid=f0542d44a322d290c29d6609fac7f215 )
74 914, 2.0L w/ D-Jet
-Derek
Last edited by nogoodwithusernames on Tue Jun 06, 2017 12:46 pm; edited 1 time in total |
Jessechop Samba Member
Joined: July 09, 2004 Posts: 60 Location: Caribou, Maine
Posted: Sun Jun 04, 2017 6:04 pm Post subject: Re: New Engine - Knock under load at low RPMs |
I would certainly side with donation. 10:1 will need hi test for sure |
sawed off Samba Member
Joined: September 15, 2016 Posts: 428 Location: Idaho
Posted: Sun Jun 04, 2017 6:14 pm Post subject: Re: New Engine - Knock under load at low RPMs |
Back the timing off a bit to see if it goes away. At least then you will know its just detonation. |
modok Samba Member
Posted: Sun Jun 04, 2017 6:19 pm Post subject: Re: New Engine - Knock under load at low RPMs |
well, it might be fooling you, or it might not. In either case yeah, back of the timing 4d egree and see if it changes. preferably, immediately.
If you have to get out your laptop to do that, HAHA But, you could put in a knob if you wanted. I would. |
Posted: Sun Jun 04, 2017 7:04 pm Post subject: Re: New Engine - Knock under load at low RPMs |
it would help if you'd post what distributor and timing you are currently running, rather than everyone guessing. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
mark tucker Samba Member
Posted: Sun Jun 04, 2017 7:07 pm Post subject: Re: New Engine - Knock under load at low RPMs |
my 2028 has that cam with 1.34 rockers and 10.4 cr and about 80000 miles, but I havent a clue if it knocks on reg fuel as it's always had premium in it., get good fuel, and tune it.....or listen to it.is it detonation? is it bearing? is it crank hiting something? is it pushrod? is it piston skirt? your there listening to it what is it? is it valve adjustment? I can tell if my lash/adjustment is out .002 or more either way from the sound of the engine, not the lash noise. listen & think. hows the oil pressure? how new is the engine? how many oil&filter changes?is it a wristpin noise? buttons or clips? |
nsracing Samba Member
Posted: Sun Jun 04, 2017 8:19 pm Post subject: Re: New Engine - Knock under load at low RPMs |
Rattles are not good. Could be chewed rod bearings. Could be cam wiped out.
It is a good idea to pull the engine out and see for sure. |
Posted: Sun Jun 04, 2017 8:50 pm Post subject: Re: New Engine - Knock under load at low RPMs |
you still need to tell us your ignition timing. And at 10:1, cheap gas is not wise. _________________ It's just advice, do whatever you want with it!
rrcade Samba Member
Joined: May 29, 2010 Posts: 735 Location: WI 1962 Bug 2276
Posted: Sun Jun 04, 2017 9:02 pm Post subject: Re: New Engine - Knock under load at low RPMs |
Don't save nickels on gas Good gas (high enough octane)is cheaper than a rebuild right? _________________ CHEAP - FAST - RELIABLE
You can only pick two of the above. |
Posted: Sun Jun 04, 2017 9:14 pm Post subject: Re: New Engine - Knock under load at low RPMs |
Just did a bit of a drive 'round the neighborhood with the computer hooked up and I don't have to keep so puckered up anymore
Pulled the timing back to 6.5° around idle and that cured it except for pulling up the driveway from a stop. I pulled a little fuel from idle as well if that matters?
Will get some good gas in it and see how it does maybe creep the timing up a hair if it'll take it.
Thanks for confirming my suspicions and for the tips! _________________ 71 Squareback, 1.7l T4 w/ crank trigger fuel and spark
-Derek |
vwkirb Samba Member
Joined: January 16, 2007 Posts: 812 Location: Athens, GA
Posted: Mon Jun 05, 2017 10:10 am Post subject: Re: New Engine - Knock under load at low RPMs |
nogoodwithusernames wrote: |
Pulled the timing back to 6.5° around idle and that cured it except for pulling up the driveway from a stop. I pulled a little fuel from idle as well if that matters? |
People like to drive real slow up their driveway, its a load, if your timing is wrong, your fuel is incorrect your engine may not like that, especially if off idle is lean with too little advance but you may not notice that if you were driving more normally.
But before you do anything you've gotta get your fuel type right, and I'd try and keep that consistent while your tuning. _________________ Andrew Kirby |
rodgersbadassbus64 Samba Member
Joined: January 24, 2009 Posts: 418 Location: Ortonville, Minnesota
Posted: Mon Jun 05, 2017 12:09 pm Post subject: Re: New Engine - Knock under load at low RPMs |
Can you see if the noise goes away when you pull individual plug wires... maybe a piston knock or cam noise to much play, single thrust bearings with heavy springs? |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Posted: Mon Jun 05, 2017 6:07 pm Post subject: Re: New Engine - Knock under load at low RPMs |
John no distributor, running Megasquirt for fuel and spark. |
With megasquirt you have the ability to watch data in realtime (through your phone) as you reproduce problems like this. Then you should be able to spot what to change in either the advance or fuel map.
Megasquirt means not guessing.
Max _________________ 1967 Type-3 Fastback
Home Stretch https://www.thesamba.com/vw/forum/viewtopic.php?t=767836 |
Posted: Mon Jun 05, 2017 6:32 pm Post subject: Re: New Engine - Knock under load at low RPMs |
he may be guessing like crazy for all we know, since he hasn't posted his ignition map. _________________ It's just advice, do whatever you want with it!
Posted: Mon Jun 05, 2017 8:04 pm Post subject: Re: New Engine - Knock under load at low RPMs |
I run about 15 idle degrees. nice and smooth idle., get some good fuel in it!!! |
Posted: Tue Jun 06, 2017 8:31 am Post subject: Re: New Engine - Knock under load at low RPMs |
Hey look a bunch of new posts!
Max looks like you answered your own question, yep crank triggered. Thought about going sequential with one of mario's cam syncs but never got around to it so just running wasted spark.
Got good fuel in it again but will wait till next fill up to make sure there's not any or much cheap stuff in the tank.
I have the spark setup as straight mechanical advance right now. Vacuum signal is bouncing a lot still. Seems to be doing alright on this for now.
-Derek |
Posted: Tue Jun 06, 2017 8:52 am Post subject: Re: New Engine - Knock under load at low RPMs |
I recommend ending your spark table around 4500 or 5k, since timing won't change above it anyways. By doing this you can use the additional cells for more resolution in the mid range (where you need it). This will help when you start really zeroing in on the proper timing map.
IE: 600, 800, 1000, 1200, 1500, 1900, 2300, 2800, 3200, 3700, 4200, 5000
Also, assuming you idle at 8-900, increase the timing in the 600 column, it will give you a more stable idle. Try 8 BTDC for 800, and 10-12 for the 600 column.
Right now your map is really raw, and your pinging is a result of that. It will probably be fine when you get it cleaned up even 1/2 way to ideal. _________________ It's just advice, do whatever you want with it!
