MorkC68 Samba Member
Joined: December 23, 2015 Posts: 610 Location: Nottingham, England
Posted: Tue Nov 14, 2017 2:48 pm Post subject: Re: 1977 Westy renovation project thread |
popuppopdog wrote: |
MorkC68 wrote: |
good luck with the build buddy, we are just renovating our '77 Campmobile ourselves |
I need luck for sure and a lot of dollars, thanks keep on postin' |
Ill do an update in the coming days. I agree entirely on the dollars, they are money pits for sure _________________ Major; 1977 Westfalia Campmobile
- Subaru EJ20
- Koni Classic adjustable dampers & Empi Heavy Duty Anti Roll Bar
- 180W Solar System
My blog: https://twolatebays.wordpress.com/ |
popuppopdog Samba Member
Joined: April 19, 2017 Posts: 80 Location: Oakhurst, CA
Posted: Wed Nov 15, 2017 8:39 pm Post subject: Re: 1977 Westy renovation project thread |
Hoody wrote: |
How do you know that you blew the engine? |
I really don't, here is what I do know. 15 years ago a buddy GAVE me this vehicle...it drove fine but for some unknown reason I felt the need to start sprucing up the engine....dumb...for appearances.... I took the engine out and my nephew pulled off a cylinder head and I felt the need to replace the rings....etc. etc., basically I rebuilt part of the upper end...I really knew nothing about vws but had a bentley manual all chewed up, I put it back together and it worked fine, drove it 50 miles to have the valves adjusted , should have done it myself, they I assume were done to spec and real tight, I did no break in of the engine, just jumped in and zoomed away at 65 plus down the free way and big noise and sounded like a engine garbage disposal going on, pulled over and called tow truck...4 kids...and it started raining of course....took it to shop and they said needs rebuild, 4K....so it has sat for 12 years....I just want a new engine and am considering long block from Kombi Haus in Sacramento CA
YOur thoughts |
Posted: Wed Nov 15, 2017 8:42 pm Post subject: Re: 1977 Westy renovation project thread |
cmonSTART wrote: |
Was this free? Looks fairly solid for free.
Is there an engine in it now? |
Sorry for the late response, yes given to me 15 years ago , free, engine in it and blown. |
Hoody Samba Member
Posted: Wed Nov 15, 2017 10:57 pm Post subject: Re: 1977 Westy renovation project thread |
Have you tried turning it over? Are you sure it's seized? Have you drained the oil and looked at it? |
Dkwautounion Samba Member
Posted: Thu Nov 16, 2017 12:37 am Post subject: Re: 1977 Westy renovation project thread |
Why don't you just pull the heads and take a look? See if it rotates with the heads off... maybe it's just top end work and your good to go. |
Posted: Thu Nov 16, 2017 7:37 pm Post subject: Re: 1977 Westy renovation project thread |
Hoody wrote: |
Now you got me thinking, this happened twelve years ago, and basically it sounded like something broke off in the engine , but it ran enough to get me off the freeway and limp down the road 1/2 a mile, and I shut it off. The kids all jumped out and started running through an open field...it started to rain and I waited for the tow truck.
Anything is possible, the shop I took it to said it needed a complete rebuild, 4K, they never took heads off, just two spark plugs and the fan, I assume to manually turn it over, it was not seized when I pulled off the highway so who knows.Guess its time to take the engine out, need to with the fuel injected, checked the Bentley, and pull the heads, what am I looking for? |
Posted: Thu Nov 16, 2017 7:38 pm Post subject: Re: 1977 Westy renovation project thread |
Dkwautounion wrote: |
Hoody Samba Member
Posted: Thu Nov 16, 2017 10:21 pm Post subject: Re: 1977 Westy renovation project thread |
You don't need to pull the heads to see if it turns over. Pull the plugs and put a shot of oil down each plug hole. Let it sit for a day. Put a socket on the fan hub bolt and see if the engine turns. Being that is been 12 years the piston rings may be hung up with rust. But it may still not be seized. You should drop the engine and look at it much further before getting a rebuilt one in my opinion. I would guess that it may need a rebuild. But why not see if you have a working engine to begin with. Your blindly trusting one shops opinion. Don't get gorrilla crazy with the socket on the hub. You don't want to break anything. Others will chime in on how to test if it turns over. Leave the plugs out when you do it. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22641 Location: NYC/Upstate/ROW
Posted: Fri Nov 17, 2017 4:18 am Post subject: Re: 1977 Westy renovation project thread |
Once you get it turning over get a good battery and check compression on all four cylinders. That will reveal any valve or big piston/ring problems.
Most sudden road stop engine mechanical breaks are valves. _________________ .ssS! |
Posted: Sat Nov 18, 2017 10:34 pm Post subject: Re: 1977 Westy renovation project thread |
Thanks all to those that have put the word in ...so here I am...jacking up this ol girl....I think this is the safest method....tell me I am an idiot and going to die, My wife has an insurance policy on me so....I think this is really stable, did the one side today next is the other side....tips ?, am I a Darwin canididate
Hoody Samba Member
Posted: Sun Nov 19, 2017 3:00 am Post subject: Re: 1977 Westy renovation project thread |
I hope to God there was no stress put on your door jam. For future reference you can just chalk the front wheels and put quality floor jacks under the rear beam. Then jack up the front in the middle of the front beam and put 2 quality floor jacks on the front beam. Your wooden jack stands would make excellent "fail safes" However now that I think about it your base maybe unstable being that your not on concrete. But in the future do the front then the back. Not one side at a time. There are very specific places these unibody rigs need to be lifted from unless you want crushed steel. |
Posted: Sun Nov 19, 2017 10:59 pm Post subject: Re: 1977 Westy renovation project thread |
[quote="Hoody" and put quality floor jacks under the rear beam. Then jack up the front in the middle of the front beam and put 2 quality floor jacks on the front beam. Not one side at a time. There are very specific places these unibody rigs need to be lifted from unless you want crushed steel.[/quote]
Interesting enough that is my same thought, I went to the rear jacking point but it lifted the whole side....worked out fine. I have now jacked up all sides , 8 inches in the air, seem to be really safe and will not move unless we get a San Andreas. I do not really trust jack stands as their jacking points are minimal. This vehicle is sitting on its own wheels on a 16" x 24" base with wheel chocks, looks good to me, I am on concrete slab btw.
Posted: Mon Nov 20, 2017 9:43 pm Post subject: Re: 1977 Westy renovation project thread |
Okay I got this thing up 8" in the air, thinking maybe higher if I work to clean up undercarriage, I don't have a lift....so we are getting ready to pull the engine got my blocks which I think only an earthquake could move this vehicle, my wife has an insurance policy, see she made me put a tie off to another vehicle so I would not tip this vehicle jacking up, is there a tipping point, don't want to find out.
I got a nice shag rug to lay on and let us begin....I think a rebuild...have some great advice on this site here is what I saw, virtually rust free undercarriage and some oil leaks
I don't mean to be dumb is this the fuel filter
Let the games begin.. of course work at night is a must
and it must be below 50 |
Posted: Mon Nov 20, 2017 10:05 pm Post subject: Re: 1977 Westy renovation project thread |
Hopefully your tranny has not been run dry of oil, the old "it used to leak but doesn't any more" story.
Yes that is your fuel filter, hate to think what it looks like inside. |
BUSBOSS Samba Member
Joined: January 21, 2009 Posts: 2161 Location: Northern California
Posted: Mon Nov 20, 2017 10:06 pm Post subject: Re: 1977 Westy renovation project thread |
Yes it is. _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible (sold - but not forgotten) |
Posted: Mon Nov 20, 2017 11:28 pm Post subject: Re: 1977 Westy renovation project thread |
For what it's worth, I would much much rather have a vehicle with its tires supported by blocks than have a vehicle with its wheels removed and sitting on jack stands. I all but refuse to wrench on a vehicle if it is sitting on four jack stands. Just too easy for things to slide around when the contact is steel on steel and once things start sliding it's no telling what is going to happen. |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3841 Location: San Jose, CA
Posted: Tue Nov 21, 2017 12:35 am Post subject: Re: 1977 Westy renovation project thread |
Damn dude, your rims look great. Put some shiny hub caps on it and that thing will look like a million bucks. One thing that isn't so great is those fresh rollers bolted up to rusty drums. That rust is going to tattoo the back sides of your rim discs with funky orange Maybe scrub those babies down and get a clean face on them, then hit 'em with a thin coat of black It does look like at least one rotor is black, hopefully it's clean under the wheel. |
Posted: Wed Nov 22, 2017 8:53 pm Post subject: Re: 1977 Westy renovation project thread |
Busstom wrote: |
That was my plan, I am going to check the rotors, and see if they need turning,
but also rebuild everything and paint certain parts with appropriate paints that I have researched ;...more later, got any suggestions on hubcap vendor |
Posted: Wed Nov 22, 2017 8:56 pm Post subject: Re: 1977 Westy renovation project thread |
Wildthings wrote: |
I totally agree nice chocked wheels on a large flat surface of blocking on concrete, the only way to go , jackstands to me are sketchy they never catch much surface area, I always want a back up though depending on the job, thanks for the input |
Posted: Thu Nov 30, 2017 9:49 pm Post subject: Re: 1977 Westy renovation project thread |
Busstom wrote: |
Damn dude, your rims look great. Put some shiny hub caps on it and that thing will look like a million bucks. . |
Thanks for the input and been thinking about doing things right....I would like to have stainless lug nuts, why , I don't know why except everything I replace on my bus I go stainless...rust never sleeps...still looking for stainless lug nuts. I am almost inclined to buy new rotors cause mine are rusted and never drive in the rain ...haha that wont work... |
