Turk.380 Samba Member
Posted: Mon Jun 05, 2017 1:26 pm Post subject: USB outlets in dash |
So the wife and I are currently outfitting our new-to-us 2002 Winnebago Vista, and I'm sittin there looking at all the blanked-out ports in the dash where the heated seats, defrost, etc switches would go. I'm thinking.. gee, it would be swell if someone made a USB power outlet that would pop in place of one of these blanks..
I check the forums here.. nothing found
check the usual vendors.. nothing found..
Checked eBay.. hmm.. this says it fits a T4.. but looks iffy..
http://www.ebay.com/itm/Car-Suv-12-24V-3-1A-Dual-U...mp;vxp=mtr
anyone tried one? I suppose for the $$ I could just risk it..
Thx
Brian _________________ Brian W
St. Louis, MO
'64 SO-33 Hatch Top Westy | '87 Syncro Westy: Subaru EZ30D powered | 2002 VW Winnebago Vista |
jjvincent Samba Member
Joined: January 11, 2016 Posts: 1268 Location: Bethlehem, PA
Posted: Mon Jun 05, 2017 2:24 pm Post subject: Re: USB outlets in dash |
Since I have one of those rectangle blocks left in my dash, I can fill it with one but will wait for you to do it first to see if it works. Buy one and let us know how it works out. It could be an easy upgrade or maybe not.
By last count, I have 7 USB ports in the EV, so two more would just add to what I can plug in. |
wildenbeast Samba Member
IdeaNerd Samba Member
Joined: May 24, 2016 Posts: 598 Location: Central California
Posted: Mon Jun 05, 2017 2:54 pm Post subject: Re: USB outlets in dash |
I've been thinking about this too, for both the cab area and also by the Weekender rear seat where there's already a 12V cigarette lighter plug.
@stl_stadtroller, if you end up installing one of these, please update us w/how it worked out + pics. |
formerknuckledragger Samba Member
Joined: May 11, 2016 Posts: 48 Location: San Francisco
Posted: Mon Jun 05, 2017 5:01 pm Post subject: Re: USB outlets in dash |
We've got this little guy in the cigarette lighter: http://a.co/as9BBR4
It's flush with the dash, can be swapped to the rear outlet easily, and is pretty cheap.
One downside - it makes an audible high-pitch whining noise that can be heard when the engine is off (or, for OCD folks like myself, even when driving). |
Posted: Mon Jun 05, 2017 5:14 pm Post subject: Re: USB outlets in dash |
I have a dual USB plugged in my cigarette lighter. My radio has a USB port in the front and I have an iPhone cable coming out of the rear. Then two dual USB's in the rear 12v ports. That's a total of 7 USB ports plus the iPhone cable. We have lots of USB powered stuff but I've never filled all 7 of them. I could put another one in that last 12V port and have 9 USB ports. I have the inverter and a 6 gang USB in my house. So, I could have up to 15. Is that enough? |
eurovank Samba Member
Posted: Tue Jun 06, 2017 12:28 am Post subject: Re: USB outlets in dash |
formerknuckledragger wrote: |
I use the same thing in all of my cigarette lighter ports in my EVC. That gives me 6 USB total. So far that's been sufficient. |
Abscate Samba Member
Posted: Tue Jun 06, 2017 7:09 am Post subject: Re: USB outlets in dash |
jjvincent wrote: |
Lets see - 7 passengers and and iPhone+Ipad for each is 14 USB ports.
I make it you have one extra. _________________ .ssS! |
I'm familiar with the round USB plug-ins, and have a few myself. I'm hoping to find something a little more elegant than that.. and also something that provides more Amperage..
Also Winnebago has the dashboard 12v socket wired to the coach battery, so it's hot all the time.
A separate, fitted, in-dash USB outlet that's keyed-hot would be useful.. most of these devices have built-in LED illumination which would be annoying at night, and also drain the battery over storage intervals. _________________ Brian W
St. Louis, MO
Posted: Tue Jun 06, 2017 8:35 am Post subject: Re: USB outlets in dash |
stl_stadtroller wrote: |
A separate, fitted, in-dash USB outlet that's keyed-hot would be useful.. most of these devices have built-in LED illumination which would be annoying at night, and also drain the battery over storage intervals. |
Over the storage intervals in question, you would trickle charge your battery, or disconnect it. An LED indicator will pull about 10 mA, not enough to worry about. If you have 14 or 15 of them, a trickle charger would still keep up
You can source them without LEDs too.
You could wire in a switch to let you cut power to the sockets as well - a fused switch would even be better.
All ideas good - just throwing them out there. _________________ .ssS! |
Joshwa Samba Member
Joined: November 18, 2015 Posts: 810 Location: North Seattle WA
Posted: Tue Jun 06, 2017 9:24 am Post subject: Re: USB outlets in dash |
Joshwa wrote: |
most of these devices have built-in LED illumination which would be annoying at night |
My main reason for adding a switch.
or piece of black electrical tape
Itsamoto Samba Member
Posted: Tue Jun 06, 2017 9:33 am Post subject: Re: USB outlets in dash |
Unless you like to chain smoke while you're driving, that flush mount 12v/USB can't be beat. Simple, clean, reversible, transferable.
You can use blanked buttons for things like adding heated seats (if you don't have them) or doing the B5 passat hazard switch for trans temp gauge mod.
Posted: Tue Jun 06, 2017 9:56 am Post subject: Re: USB outlets in dash |
The lighter might not be usable because when I bought my Alltrack, they were giving away these 12V VW rechargeable mini flashlights (it actually works pretty well):
Posted: Tue Jun 06, 2017 10:03 am Post subject: Re: USB outlets in dash |
Itsamoto wrote: |
ooh... that's pretty nifty..
can yo share the specs? what y/m that switch come from? is it a direct changeover or is there rewiring involved?
what gauge is that and how do you have the sender installed? _________________ Brian W
St. Louis, MO
Posted: Tue Jun 06, 2017 10:27 am Post subject: Re: USB outlets in dash |
Itsamoto wrote: |
what gauge is that and how do you have the sender installed? |
The hazard switch is pulled out from a B5 passat (My-98-05) -- all you need to do is cut off a plastic alignment tab/pin off the back and it's plug and play to the Eurovan harness.
The gauge is from New South Performance - its a colour matching gauge for blue/indigo cluster VW's - and comes with a metric thread sender that fits the trans' pressure port (an unused port). This is measuring trans temp - but you could use any gauge you want (this one just lights up nicely). |
Posted: Tue Jun 06, 2017 10:37 am Post subject: Re: USB outlets in dash |
Itsamoto wrote: |
Itsamoto wrote: |
That's not where you place a gauge if you want to go all JDM on your Eurovan. You mount them on the A pillar and then add in some other gauges (i.e when the v-tec kicks in). To finish it off, put a bunch of stickers on the front and rear window at an angle. |
Joshwa Samba Member
