pomfritz Samba Member
Joined: December 18, 2014 Posts: 477 Location: Folsom, CA
Posted: Mon Jun 12, 2017 5:53 pm Post subject: Wiper washer fluid refilling |
Where do you fill the fluid? I see there is a neck close to the bottle but how do you access it? ...asking for a friend 😉[/i] _________________ 83.5 233K. GW 2.3, SS exhaust, My German Frau named her Stefi |
61Scout Samba Member
Joined: November 06, 2011 Posts: 1297 Location: Shoreline/Yakima WA
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9799 Location: Mt Lemmon, AZ
Posted: Mon Jun 12, 2017 6:28 pm Post subject: Re: Wiper washer fluid refilling |
I find a long funnel useful for that --
timichango Samba Member
Joined: April 07, 2012 Posts: 858 Location: Squamish, BC, Canada
Posted: Tue Jun 13, 2017 1:37 pm Post subject: Re: Wiper washer fluid refilling |
Yep — your left foot is probably on top of the filler cap a lot of the time. Under the carpet There's a black stud in the driver wheel well near the door that holds that carpet up. Pull the carpet off of the stud, and lift the carpet. Bob's your mother's brother.
Long funnel is advisable. Also, I like to take a rag or a couple pieces of paper towel, and make a donut around the opening to catch any overflow. I have a habit of overfilling the tank, and then needing to lift up my floor insulation to wipe it out. Because I'm a dufus. The paper towel donut trick mitigates that requirement usually. _________________ . . . . . . . . . . . . . . . . . . .
Vroomhilde-San: Our 1991 Silver Vanagon Westy automatic + Subie EJ25 |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4349 Location: United States, Iowa
Posted: Tue Jun 13, 2017 1:45 pm Post subject: Re: Wiper washer fluid refilling |
You might tell your friend that in addition to 'under your left foot' there is another place... for the back washer. Its that black bump in the wall behind your back seat. Slide that off, there's the tank! _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
kamzcab86 Samba Moderator
Posted: Tue Jun 13, 2017 2:11 pm Post subject: Re: Wiper washer fluid refilling |
Here's a visual:
_________________ ~Kamz
2016 Golf GTI S
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Tue Jun 13, 2017 8:29 pm Post subject: Re: Wiper washer fluid refilling |
FWIW, the tank holds about 2 liters -or- slightly more than 1/2 gallon. Stop
pouring at about 1/2 gallon & no overflow, drips, rags, towels, rust, etc...
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Hybrid VW Samba Member
Joined: May 03, 2014 Posts: 128 Location: Central Oregon
Posted: Tue Jun 13, 2017 8:42 pm Post subject: Re: Wiper washer fluid refilling |
I guess my tank has a crack in it. I put a significant amount of fluid in it, then heard it leaking onto the garage floor. I figured zee Germans designed it so that it couldn't overflow into the interior |
Posted: Tue Jun 13, 2017 8:59 pm Post subject: Re: Wiper washer fluid refilling |
The grommet between the top of the tank and the filler often leaks.
In that case, stop filling when your shoes start getting wet...
"The WonderVan"
Posted: Tue Jun 13, 2017 10:15 pm Post subject: Re: Wiper washer fluid refilling |
The washer tank fill is not for the queasy folks who don't like drips, spills, or oozing. Dhavvers is right, the grommet goes on every tank I've heard of. And, to boot, it goes almost immediately after replacement as well. So, go with his advice, stop filling, short of the drip. Yes, you CAN R&R it, but just wait the few weeks and there it goes oozing, dripping and otherwise spreading a blue puddle on your floor.
The worse, by far, is the rear tank and pump. Those are sneaky MoFo'z that end up putting a hole in the well below the rear tank, 'cuz they leak and you never knew it. Squirt squirt, rust a little, rust a little more... HOLE! whamo! Now that is a hole that is hard to repair.
Better than the EV I had tho.. the line for the rear ran all the way from the front tank to the rear nozzle. It blew about half way through the cabin, on the passenger side, and the dorks even added insult to injury as it was engineered to run along the TOP of the compartment. Blue trickle down the inside of the Westy, soaking the bed. That is murder worthy, right there, I'd have to say. Who the F thought that up! _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
bizarre Samba Member
Posted: Wed Jun 14, 2017 2:17 am Post subject: Re: Wiper washer fluid refilling |
Just a question on filling these
I have a Caravelle C with the rubber mats
These dont "lift" that well and I am getting a tear in the rubber
Stupid question, but I dont like the tears forming, but does anyone else have issues with the rubber mats?
Barry |
