nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Mon Jun 12, 2017 6:46 pm Post subject: Speedometer reads fast |
We are the third owners of our 1966 SO44. The transmission and RGB's is original to the bus.
We are currently running 185R14 6PR LT tires on it which I believe are the proper size.
The speedometer reads way fast when compared to the speed showing on any of the half dozen speedometer apps I have tried, and when compared to the speed of a modern car driving along side.
It is not the same amount off, but the faster I go the more it is off. By off I mean like 15 or 20 MPH at higher speeds.
This being an SO44 was of course a German delivered model but the first owner (an american serviceman) told us he ordered it with US specifications and sure enough, the birth certificate and M-codes confirm this.
At first I was thinking that it has something with the MPH/KPH, but the speedo says MPH and only goes to 80.
So, what could be so off in the speedometer and is there anything I can do short of having it professionally restored? |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Mon Jun 12, 2017 7:23 pm Post subject: Re: Speedometer reads fast |
what's the date code / ratio stamped on the speedo housing? could be a speedo for a bus with 15" wheels. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Mon Jun 12, 2017 9:50 pm Post subject: Re: Speedometer reads fast |
I think 185's are a little smaller than stock, which might amount for being a few mph off. |
thomas. Samba Member
Joined: July 31, 2010 Posts: 1291 Location: South West (Pa.)
Posted: Tue Feb 20, 2018 5:38 am Post subject: Re: Speedometer reads fast |
I have the 195 version and my speedometer is right on the money. (1966 SO 42) According to this site I linked there should only be a 1.5 mph difference at 60mph between the two sizes. A P.O. may have had the needle off your speedometer and reinstalled incorrectly.
http://www.busdepot.com/ra18195 |
Don66bus Samba Member
Posted: Tue Feb 20, 2018 6:00 am Post subject: Re: Speedometer reads fast |
I have a 1966 with original equipment and reasonably sized tires and the speedometer always read fast.
I eventually replaced the speedometer with a rebuilt one and it gives the correct speed now, according to GPS calibration. Some speedometers are not going to be accurate after 50 years. |
dmuis Samba Member
Joined: September 01, 2004 Posts: 381 Location: Sunny Alberta, Wild Rose Country.
Posted: Tue Feb 20, 2018 8:42 am Post subject: Re: Speedometer reads fast |
https://www.thesamba.com/vw/archives/info/50_67_bus_gear_ratios.php
Stock tire height was approx 26.8" - 27.0", regardless of year. I found that with 205/75R15 tires (27.1") my speedometer was right on with the mobile speed app.
Your tires may only have a 25.6" diameter (Spec for Hankook RA18). This would represent a 5% high reading over 26.8" or 6% over 27.1".
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Tue Feb 20, 2018 10:08 am Post subject: Re: Speedometer reads fast |
agreed. 185/14s were the stock replacement radials in germany, but they are definitely smaller than the 7/14s that would have been stock.
The tire you wanted back then was the 185/15 michelin for a 15 inch wheel and 195/14 for the 14 inch wheels. Or the correct bias plies of course if you don't drive much.
In germany speedometers are typically a little fast from the factory. 5 or 6 miles fast at the top-end would be normal i think. especially with the smaller diameter radials.
15-20 miles off is NOT normal. might be time to rebuild _________________ regards
Uli
Posted: Sun Feb 25, 2018 6:13 pm Post subject: Re: Speedometer reads fast |
hazetguy wrote: |
what's the date code / ratio stamped on the speedo housing? could be a speedo for a bus with 15" wheels. |
Jon, once again you guessed right. I finally pulled the speedo out and sure enough it was dated 4.62, so a 15" wheel speedo.
Now to find a 1966 one. |
