KollynnBlackpaw Samba Member
Joined: October 19, 2016 Posts: 528 Location: Hubbard, Oregon
Posted: Tue Oct 24, 2017 8:07 pm Post subject: Re: Unnamed 68 Panel Bus project |
Progress! Sorta. I'm getting a big ol clunk when I turn the ignition. It's more than what I was getting so I'm excited!
*Battery isn't dead, just starter the Square with no issues at all on it.
Probably the terminals. I know they're pretty corroded. But the starter was definitely bad - looked like the original (hefty mofo!)
I also found, while testing stuff -
The green light comes on only when the headlights are on (which turns on the running lights in the car) but turns off when the ignition is turned, which turns on the red light.
The left blinker doesn't work and induces very very quick clicks inside the car. Not sure what causes this.
Right signal works fine.
Dome light is VERY bright. I was looking right at it when I turned it on, as I was sure it wasn't working (It has a "on/off" slider on itself, plus the dash button)
All bus doors sound the same when you close them. Sounds exactly like when I'd close the door on my mom's old bus. _________________ '71 Shantung Yellow AT/FI Squareback |
Posted: Tue Oct 24, 2017 11:33 pm Post subject: Re: Unnamed 68 Panel Bus project |
Oh, also I haven't checked my fuses yet - probably a couple down. Gotta figure I'm only just getting around to this stuff since I got the starter! Without it I was at a bit of a stand-still as far as engine goes - and I wanted to get it running first if I could, since it looks so good. _________________ '71 Shantung Yellow AT/FI Squareback |
Posted: Thu Oct 26, 2017 5:29 pm Post subject: Re: Unnamed 68 Panel Bus project |
Sucess! After using the "Push backward in 3rd gear" trick, the starter unstuck and tried to turn over the engine! Only issue is it's stuck every time I try. If it doesn't start the engine, and I let it off, it's stuck and I have to redo it. What can I try now? _________________ '71 Shantung Yellow AT/FI Squareback |
Posted: Thu Oct 26, 2017 6:21 pm Post subject: Re: Unnamed 68 Panel Bus project |
Pics for you guys. The air cleaner is off as I tried a bit of starting fluid. My guess is spark right now - which I'll look into tomorrow. I definitely have gas, and air. Though that thing on the carb looks messed up - not sure what it is?
I also included a pic of that weird wire on the bat positive.
I changed the spark plugs when I first got her but haven't done the timing yet, which will be my first attack tomorrow. The points are definitely good, and the cap/plugs look okay, so I think I'm good there. I'll probably replace the cap and rotor anyways as I have new ones. _________________ '71 Shantung Yellow AT/FI Squareback |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Fri Oct 27, 2017 6:34 am Post subject: Re: Unnamed 68 Panel Bus project |
Where does this wire go to? _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Posted: Fri Oct 27, 2017 10:57 am Post subject: Re: Unnamed 68 Panel Bus project |
Spike0180 wrote: |
Where does this wire go to? |
It comes off the pos cable, and splices in it as far as I remember (i'll check in a bit when I'm awake.) My mother had said something about her old battery having a tab on it that this connected into, or something similar? She mentioned this when I first got the bus so not 100% now. _________________ '71 Shantung Yellow AT/FI Squareback |
Posted: Fri Oct 27, 2017 11:23 am Post subject: Re: Unnamed 68 Panel Bus project |
KollynnBlackpaw wrote: |
Spike0180 wrote: |
It comes off the pos cable, and splices in it as far as I remember (i'll check in a bit when I'm awake.) My mother had said something about her old battery having a tab on it that this connected into, or something similar? She mentioned this when I first got the bus so not 100% now. |
So it came from the positive battery terminal and went straight back into the battery? _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Posted: Fri Oct 27, 2017 12:06 pm Post subject: Re: Unnamed 68 Panel Bus project |
Spike0180 wrote: |
Spike0180 wrote: |
So it came from the positive battery terminal and went straight back into the battery? |
Just checked - it and some black, capped off wires come off the battery terminal, but no it doesn't go to the battery. I'm using my Type 3's battery as of right now, so maybe a different battery would have tabs. They werent connected to anything when I bought her, hence the confusion.
On the upside... she runs! I messed with the timing a bit and she fired up! She smokes a good amount, probably from sitting plus the fact her exhaust is practically falling apart, but she runs! Happy days!
Looking at the brakes it looks like I might need a new master, that might be what's leaking. I bought extra brake fluid I'll throw in her to see if I can't spot the leak, but it must have been a slow leak as it was totally fine last time I put fluid in, then in the morning was drained entirely. _________________ '71 Shantung Yellow AT/FI Squareback |
Posted: Fri Oct 27, 2017 12:53 pm Post subject: Re: Unnamed 68 Panel Bus project |
It sounds like those wires could have been for a starter relay or some other PO hack. If you had extra wires going from the battery to the starter it would just reduce the resistance on the battery cables... It just doesn't make sense to me. Or maybe I'm misunderstanding where these wires should be going. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Posted: Fri Oct 27, 2017 1:09 pm Post subject: Re: Unnamed 68 Panel Bus project |
Spike0180 wrote: |
It sounds like those wires could have been for a starter relay or some other PO hack. If you had extra wires going from the battery to the starter it would just reduce the resistance on the battery cables... It just doesn't make sense to me. Or maybe I'm misunderstanding where these wires should be going. |
I had thought maybe the secondary battery (can't remember what people call them - the ones that are just used for accessories) - maybe hooked to it somehow, but I have no accessories, since this is a panel, and the only thing in the back was the transporter seat. _________________ '71 Shantung Yellow AT/FI Squareback |
Posted: Sat Oct 28, 2017 10:42 pm Post subject: Re: Unnamed 68 Panel Bus project |
New exhaust installed, though it was a bit difficult. Re-used the exhaust off the parts Type 3 (in good condition, don't worry!) and a header my boss gave me. I REALLY was hoping the tuck-in exhaust I had would fit - but it hits part of the frame, so it doesn't fit. I'm looking to sell it if anyone needs it!
Still having sticky starter on and off, hopefully just needs broken in a bit. _________________ '71 Shantung Yellow AT/FI Squareback |
Posted: Sun Nov 26, 2017 1:44 pm Post subject: Re: Unnamed 68 Panel Bus project |
So I think I asked before about lowering here, but are there any spindles that let me keep Wide 5 but not modify the other bits of the suspension?
I saw a decently priced pair on here today that sounded like I'd not need to modify the suspension, but requires the narrow 5 + '73 brake parts.
If not - any other options, or good suggestions for spindles for what I'd like? I know you can't have everything sometimes which is fine - but in the end I'd prefer to keep the wide 5 at least. I can't afford new tires and rims! _________________ '71 Shantung Yellow AT/FI Squareback |
Posted: Fri Feb 16, 2018 8:53 pm Post subject: Re: Unnamed 68 Panel Bus project |
Hia, everyone! Big news! Frau, the official name for the bus now, has been titled, plated and registered. She drives great! Very loud exhaust (love it) but she still has the starter clunk issue. It's a brand new starter, but won't go once I've stopped somewhere. I have to roller her backward still. Any advice? _________________ '71 Shantung Yellow AT/FI Squareback |
Posted: Mon Feb 19, 2018 2:14 pm Post subject: Re: Unnamed 68 Panel Bus project |
Meine Frau is running and driving me to work while Blue is down, but she's a bit rough and it seems she's a bit of a leak! I'm not sure where from yet, but she obviously leaks. She also runs very loud, though the exhaust is on there well. Might just be the exhaust design. _________________ '71 Shantung Yellow AT/FI Squareback |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Mon Feb 19, 2018 7:45 pm Post subject: Re: Unnamed 68 Panel Bus project |
lil-jinx wrote: |
Best replace that alt. belt,looks like it's about to cause you a lot of grief. |
Will do! I actually have like four belts. Two came with it, two NAPA sold me, unsure of which one was correct, both said 68 so. _________________ '71 Shantung Yellow AT/FI Squareback |
Posted: Mon Feb 19, 2018 9:27 pm Post subject: Re: Unnamed 68 Panel Bus project |
lil-jinx wrote: |
The crank pulley you have is not stock size,so a stock belt will be too big,my buggy has a smaller pulley like yours,it is 5.75 inch in diameter,My belt size is.11/850. |
Thank you, kindly! I'll see if the two belts that came with it are correct size come tomorrow. I'm very excited to be working here in the Type 2 department for a bit rather than the Type 3. Blue has been exhausting and frustrating! _________________ '71 Shantung Yellow AT/FI Squareback |
Posted: Fri Feb 23, 2018 7:05 pm Post subject: Re: Unnamed 68 Panel Bus project |
Well! I went out to go pick up a spare generator belt, as I only have one spare, and the tire goes flat, and comes off the rim! I was lucky I pulled into the local car wash where I used to work, as they have air. But even my impact socket wouldn't get those damn lugs off! My previous boss had to help me use the four way to get all five lugs cracked off. In the end I got the spare on and made it to the napa. And the generator belt busted in their drive way! What a day!
On that note, who can suggest good tires for a cargo van? I'd like something aggressive looking but can hold good weight, if possible, as I'll be transporting people, parts, and tools day in and out! _________________ '71 Shantung Yellow AT/FI Squareback |
Posted: Sat Feb 24, 2018 1:49 pm Post subject: Re: Unnamed 68 Panel Bus project |
Getting some General Grabber AT2s installed on Monday! 111 each form Discount Tire who had a real tough time finding the right tires for me. Wasn't planning on spending so much money but its gotta be done! _________________ '71 Shantung Yellow AT/FI Squareback |
