Shlomi32 Samba Member
Posted: Wed Jun 14, 2017 12:54 am Post subject: Weber idle problems |
Hi.
I can't get idle on a 1.7 type 4 engine..
I just finished rebuilt IDF's 40.
Idle was 50 but was to lean I think.
I put now 65 and still can't idle.
I have to open the adjustment screw about 6-7 turns to it to begin idle...
Should I get a bigger idle then that? |
mark-s Samba Member
Posted: Wed Jun 14, 2017 1:26 am Post subject: Re: Weber idle problems |
What made you think it was too lean with 50 idles? ie what where the symptoms?
65 seems way too large, bit it depends on the engine specs. You'll have to post those along with information such as carb venturi size, distributor type etc. Also you need to be confident that there are no issues elsewhere, so that means timing, compression, valves adjusted, plugs ok.
I'm just telling you this before someone else does. |
Posted: Wed Jun 14, 2017 1:29 am Post subject: Re: Weber idle problems |
I saw online a manual that tell that if you should open the adjustment screw more than 1 1/2 - 2 turn that mean the idle jet is too small
I have a svda distributor. Scat c25 cam. Venturi side is 30. |
modok Samba Member
Posted: Wed Jun 14, 2017 2:13 am Post subject: Re: Weber idle problems |
What model of 40 idf? |
Posted: Wed Jun 14, 2017 2:17 am Post subject: Re: Weber idle problems |
Model??? What do you mean?
Its made in Spain. And the idle jets are on top of the carb |
modok Samba Member
Posted: Wed Jun 14, 2017 2:26 am Post subject: Re: Weber idle problems |
here
says "40 IDF 70" this one, 1-2 turns out is normal
model "40 idf 78" 2-5 turns out is normal, (finer thread)
Made in spain? with the idle jets on top? REALLY? That might be something I have not seen. What kind of car did you take them off?
Posted: Wed Jun 14, 2017 2:36 am Post subject: Re: Weber idle problems |
My mistake... Made in Italy...
modok Samba Member
Posted: Wed Jun 14, 2017 2:40 am Post subject: Re: Weber idle problems |
Ah yes, from alfa romeo?
2-5 turns out.
it should idle ok with 65 jet
My charts only go to model 84, I think, I wonder if there is a difference? |
Posted: Wed Jun 14, 2017 2:43 am Post subject: Re: Weber idle problems |
I'll do a compression check and update |
modok Samba Member
Posted: Wed Jun 14, 2017 2:46 am Post subject: Re: Weber idle problems |
Maybe it could be this problem? worn throttle plates
From another thread:
Agent47 wrote: |
This is the throttle plates out. Where they connect to the throttle shaft the plates look notched.
I switched which side they went in and got a better seal.
Adjusting the idle mixture screws on cylinders 1 and 3 now affect the idle, however 2 and 4 still don't do shit.
I took it out for a drive and between 1500 and 2000 rpms the power was not good but then it a smooth surge of power came and followed all the way up to 4500 rpms. The backfire on deceleration happens right at 2000 rpms, it is actually suprisingly consistent.
Light leak test #3
Light leak #4
The throttle plate screws heads stripped while taking them out, so I had to use ssome 4mm SS hardware; they will be getting replaced with proper hardware soon.[/img] |
Posted: Wed Jun 14, 2017 5:39 am Post subject: Re: Weber idle problems |
OK. Problem found. All the cylinder have a compression of 60-70.
The cylinder heads had rebuild before 1000 km.
Piston & cylinders are brand new by KS.
what I miss here? |
mark-s Samba Member
Posted: Wed Jun 14, 2017 5:52 am Post subject: Re: Weber idle problems |
From www.ratwell.com/technical/FAQ/FAQContent.html:
According to VW, a heathy Type IV engine is like so:
1700cc: 100-135psi, no lower than 85 psi
1800/2000cc: 85-135psi, no lower than 71 psi
So your compression readings are low. That may not be the sole reason for the idle problem, but it's worth checking that your engine is in good condition before throwing money at jets. |
YDBD Samba Member
Joined: February 25, 2017 Posts: 891 Location: Bavaria, Germany
Posted: Wed Jun 14, 2017 6:15 am Post subject: Re: Weber idle problems |
Are your valves closing all the way? Did you set the valve clearance gap to .006"?
Were the piston rings installed correctly? Unless they are total seal all your piston ring gaps should be set at various gaps. Each engine builder may have their own, but a good start is to have the gaps more than 90 degrees apart. _________________ '56 pan Dune Buggy since '69
don't live in the past...but when I did:
'67 bug
'64 baja
'60 dune buggy
'73 Personenkraftwagen Type 182 "Thing" |
jason Samba Member
Posted: Wed Jun 14, 2017 7:36 am Post subject: Re: Weber idle problems |
Rings spin. Staggering just makes you feel better. |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Thu Jun 15, 2017 12:18 pm Post subject: Re: Weber idle problems |
What Emulsion tubes are in those carbs?
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Posted: Thu Jun 15, 2017 12:45 pm Post subject: Re: Weber idle problems |
modok Samba Member
Posted: Thu Jun 15, 2017 5:11 pm Post subject: Re: Weber idle problems |
And they have 3.5 auxiliary venturi instead of 4.5 |
ReefKeeper Samba Member
Joined: December 06, 2016 Posts: 2 Location: Orange County
Posted: Fri Jun 16, 2017 4:39 pm Post subject: Re: Weber idle problems |
Your tubes are wrong should be F11 |
Posted: Fri Jun 16, 2017 4:43 pm Post subject: Re: Weber idle problems |
Looks like those carbs were set up for something else. I had the same problem with the set of 44's they were set up for a 2332 or some other monster they were not stock. They had the CB performance venturi's in them |
Posted: Fri Jun 16, 2017 4:55 pm Post subject: Re: Weber idle problems |
he's wasting anything he does until he fixes that 65psi compression reading. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
