OG Paint Turkis 15 Window Deluxe. El Pavo 15
Page: Previous  1, 2, 3 ... 12, 13, 14 ... 63, 64, 65  Next
Major Woody
Samba Enigma
Major Woody is offline
PostPosted: Mon Jul 24, 2017 11:36 pm    Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 Reply with quote
I see you have dry fit some safaris in there to check the fit. If those aren't the ones you'll be using and were just borrowed from a friend, you should know that the coating on them is powder coating. You can order them from Wolfgang unassembled and unpainted, then paint the frames and ship them back for assembly. They have all the jigs and the glass tape and stuff, and it really isn't possible to properly prep and paint them with the seals and glass in place.
Just something to consider, if it isn't already too late.
Take it to the Rants!
Skim
Rants Master
Skim is offline
PostPosted: Tue Jul 25, 2017 6:17 am    Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 Reply with quote
Those are the safaris I got for it. I wanted bare metal but they only offered them in stainless or the off white. I'm just going to prep and paint these the correct color.
GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
Skim
Rants Master
Skim is offline
PostPosted: Tue Jul 25, 2017 8:55 am    Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 Reply with quote
Z wrote:
Skim wrote:
What's some good tips on treating this area?
Mine looked a lot like yours. I mostly used one of these in a die grinder.
The different radii and edge profiles you get as they wear down will get you into all of those curved channels really well, and they are aggressive enough to knock back that kinda scale without taking off too much good metal. I had a few deeper pits that i used various Dremel stones to clean the rust out of. I followed all that with a metal prep/ospho type stuff, but you gotta keep that stuff away from the original paint you want to save.
I ended up with about 2 or 3 small holes, maybe 1mm or so, which i filled with All Metal filler. Prime, paint, blend the edge with the original paint, and its good as new. Looks like you have really strong paint almost all the way into the channel, so your blend line should be almost invisible.
Thanks, The actual prep process I've never had to do on any previous busses before so I want to take care of it once and for all. Ill use one of those bits. I'd like to smooth out the area. is the All Metal Filler something that is workable and smooth / sandable once dried?
GFK
1953 Kabriolet
1954 Sunroof
wcfvw69 Premium Member
Samba Purist
wcfvw69 is offline
PostPosted: Tue Jul 25, 2017 12:17 pm    Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 Reply with quote
IDK Skim, I can't see clearly enough in your pictures if that's really repairable vs. cutting that out and installing new metal around the window frame.
If you go the route of trying to make do w/what you have there, I'd remove all the loose rust. Then treat and remove the rest of the rust with acid like Naval Jelly or Ospho. It will kill and neutralize the remaining rust.
I'd then apply an epoxy primer and then a good filler to smooth it out. Follow that up with another good coat of epoxy primer, sand and repaint.
The Samba member since 2004.
Z
Z is offline
PostPosted: Tue Jul 25, 2017 12:52 pm    Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 Reply with quote
Yes, All Metal has a high metal content, doesnt absorb moisture, etc. It's applied directly to the metal surface. (The autobody teacher said it was like old school lead in bondo form.) Sands and finishes like regular filler, but seems to be harder which makes it easier to surface like the sheet metal around it. Cons are it's a little pricey for a can, and I don't think the shelf life is super long.
I have also used POR15 putty for filling pinholes, and it seems to be really good, too.
Goes without saying that the best plan of attack can't be determined til you see just how extensive the rust is. And since you are already welding....
Skim
Rants Master
Skim is offline
PostPosted: Tue Jul 25, 2017 9:32 pm    Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 Reply with quote
Thanks everyone for your input and advice. Much appreciated!
So there's a couple pieces of metal that I'm needing that should be arriving any day now. B pillars and such. So in the meantime I have to shift my focus to an area I've been dreading and that would be the drivers side dogleg. It's so nice on the outside but the inside is wasted. I had to come to the conclusion that it's gotta be replaced. The bright side is it will make it easy to handle a couple rusted areas that would be difficult to access with the dogleg in place.
GFK
1953 Kabriolet
1954 Sunroof
Skim
Rants Master
Skim is offline
PostPosted: Tue Jul 25, 2017 9:36 pm    Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 Reply with quote
GFK
1953 Kabriolet
1954 Sunroof
Skim
Rants Master
Skim is offline
PostPosted: Tue Jul 25, 2017 9:39 pm    Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 Reply with quote
Originally I had planned to partially repair the dogleg to save the OG paint one but it ended up being so bad I ordered the other half, hence I have to weld this one together. Had I known I would have got a complete one the first time. No worries.
GFK
1953 Kabriolet
1954 Sunroof
sgellis
sgellis is offline
PostPosted: Wed Jul 26, 2017 3:21 am    Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 Reply with quote
I welded the skin in place and then installed the inner piece. Was able to get a perfect alignment that way... and was able to get the hidden welds at B pillar.
My 64 Kombi restoration
My camper interior build
My 54 standard restoration
The Nova Scotian Barndoor (YouTube)
The Nova Scotian Barndoor (CAD drawings)
Skim
Rants Master
Skim is offline
PostPosted: Wed Jul 26, 2017 10:38 am    Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 Reply with quote
Thats a great idea! I didn't even think of that!!! That's exactly what Im going to do. Thanks sgellis Thumbs Up
GFK
1953 Kabriolet
1954 Sunroof
sgellis
sgellis is offline
PostPosted: Wed Jul 26, 2017 11:36 am    Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 Reply with quote
HaHa... Well I got the idea from glideking.
Some of his vids that I found helpful.
https://www.youtube.com/watch?v=sexLbz4W9N8&t=0s
https://www.youtube.com/watch?v=HJAkYfr6uig&t=0s
https://www.youtube.com/watch?v=aS9rKAgM_JA&t=0s
Skim
Rants Master
Skim is offline
PostPosted: Wed Jul 26, 2017 8:57 pm    Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 Reply with quote
Good stuff indeed.
GFK
1953 Kabriolet
1954 Sunroof
Skim
Rants Master
Skim is offline
PostPosted: Wed Jul 26, 2017 9:03 pm    Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 Reply with quote
Having to do some rust repair to the A pillars before doglegs can go in.
GFK
1953 Kabriolet
1954 Sunroof
oakman
oakman is offline
PostPosted: Wed Jul 26, 2017 9:59 pm    Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 Reply with quote
You're kicking some major ass on your bus Tony, thanks for documenting it here. Seeing all this metal work getting done is motivating me to get with it and fix my cut wheel wells.
Brandon
Skim
Rants Master
Skim is offline
PostPosted: Thu Jul 27, 2017 9:49 pm    Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 Reply with quote
Got an original dogleg from Campingbox Greg and Clara that I had to use for parts being the edge metal is wasted on my bus and the good metal is too far back to reach the Gerson doglegs. So I bought this one for the edge metal.
GFK
1953 Kabriolet
1954 Sunroof
Skim
Rants Master
Skim is offline
PostPosted: Thu Jul 27, 2017 9:52 pm    Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 Reply with quote
You can see what I mean. The slider window was busted so leaves and years of rain took its toll on the edge above the dogleg
GFK
1953 Kabriolet
1954 Sunroof
Skim
Rants Master
Skim is offline
PostPosted: Thu Jul 27, 2017 9:55 pm    Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 Reply with quote
GFK
1953 Kabriolet
1954 Sunroof
DONGKG
The Araneta Boys
Location: Cainta, Rizal, Philippines, "A Certified Type 3 and Karmann Ghia Maniac"
DONGKG is offline
PostPosted: Thu Jul 27, 2017 10:06 pm    Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 Reply with quote
Skim,
Wonderful find! Just read the thread and I was stunned by how straight the Splitty is. For sure, the Split is in good hands! Keep us posted! Congrats!
Thanks,
DongKG
'67 KG Cabrio (Mickey) ;
'66 Type 3 (Sharky 2)
'72 Type 2 Homey
'67 Splitty Bus
'65 beetle;'69 Country Buggy; '44 Kubelwagen (replica) TOOB MEMBER #20
Skim
Rants Master
Skim is offline
PostPosted: Fri Jul 28, 2017 10:51 pm    Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 Reply with quote
DONGKG wrote:
Skim,
Thanks,
DongKG
Thanks Don. Appreciate it my Filipino brother 💯 I'm getting there little by little .
GFK
1953 Kabriolet
1954 Sunroof
Skim
Rants Master
Skim is offline
PostPosted: Fri Jul 28, 2017 10:54 pm    Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 Reply with quote
Guess what arrived to work today? It's green so you guessed it. Thanks Gerson 👍 Gonna be going down this weekend.
GFK
1953 Kabriolet
1954 Sunroof
Page 13 of 65
