Skim Rants Master
Joined: April 15, 2001 Posts: 17082 Location: GFK 31 Year Vet
Posted: Wed Aug 09, 2017 8:42 pm Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 |
First I tacked in my section then bolted the column in to make sure it would be straight before fully welding it in. My fear was the column being cocked over to the side a little bit.
Damn that wheel would be up there a bit
_________________ GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
Skim Rants Master
Posted: Wed Aug 09, 2017 8:43 pm Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 |
So mission complete now I have to shorten the column a tad bit.
1953 Kabriolet
1954 Sunroof
braddick Samba Member
Joined: March 11, 2017 Posts: 183 Location: Australia, Victoria
Posted: Thu Aug 10, 2017 4:44 am Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 |
Once again, lovin this build thank you for sharing
Interested to see how u shorten the column
I left mine high in my 63 but will be shorting the one in the mango |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12409 Location: Over 2002 posts deleted!
Posted: Thu Aug 10, 2017 7:28 am Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 |
Skim wrote: |
So mission complete now I have to shorten the column a tad bit. |
I'll be looking at that closely. I always hear about the box raise but never about how to take care of the steering wheel sitting so high!
Hell, I don't like mine as high as it is in stock form , more so the flat position of it. I've been pondering installing some universal joints and set it lower AND at a bit of an angle too which will give a clearer view of the speedo!
Try to take some detailed pix of that process. _________________ Some people are so busy being clever they don't have time enough to be wise. |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Thu Aug 10, 2017 2:33 pm Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 |
pyrOman wrote: |
Try to take some detailed pix of that process. |
spoken like a bay man _________________ regards
Uli
Skim Rants Master
Posted: Thu Aug 10, 2017 7:55 pm Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 |
Before I weld in the floor, there's a couple places that need attention. One is the shifter base. So I cut it out and traced it on a scrap piece of thicker gauge Metal.
1953 Kabriolet
1954 Sunroof
Skim Rants Master
Posted: Thu Aug 10, 2017 10:20 pm Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 |
Had to fix a rusty area on the passenger side inner nose kick panel before I can put the cab floor in. I used a grinder and uni bit and drilled through the rust holes to gauge how thick the metal was where there was rust holes, this way I could tell how much bigger area I need to cut out.
1953 Kabriolet
1954 Sunroof
Skim Rants Master
Posted: Fri Aug 11, 2017 9:07 am Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 |
pyrOman wrote: |
Skim wrote: |
I will get to it after I do the floors so then I'll post the pics _________________ GFK
1953 Kabriolet
1954 Sunroof
Skim Rants Master
Posted: Sat Aug 12, 2017 12:43 am Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 |
Found this magnet. I'm not sure where it came from but I like it.
1953 Kabriolet
1954 Sunroof
Skim Rants Master
Posted: Sat Aug 12, 2017 12:47 am Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 |
So I got the front floor ready to weld in. Be good to finally get a floor in this thing.
1953 Kabriolet
1954 Sunroof
Skim Rants Master
Posted: Sat Aug 12, 2017 12:52 am Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 |
I still have to contour the edge to tuck to the nose prior to welding. Seemed to fit nice and tight so that a plus. In the morning I'll have it all welded in. It's going on 3 am here.
1953 Kabriolet
1954 Sunroof
Skim Rants Master
Posted: Sat Aug 12, 2017 3:39 pm Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 |
Floor is officially in. I'll knock down some plug welds then I can mount my safaris since there won't be any sparks flying around up here.
1953 Kabriolet
1954 Sunroof
Skim Rants Master
Posted: Sat Aug 12, 2017 8:58 pm Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 |
So I began cleaning up my windshield channels and so far I only found one small pin hole that I welded shut. This week I plan on using ospho to neutralize any rust then I'll paint the areas as well as the safari window frames the correct Blau Weis.
Other side wasn't so bad.
1953 Kabriolet
1954 Sunroof
oakman Samba Member
Joined: February 05, 2014 Posts: 1715 Location: Edge of the Desert, Ca
Posted: Sat Aug 12, 2017 10:33 pm Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 |
Windshield channels look good! Keep up the good work Tony. _________________ Brandon |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7551 Location: Santa Cruz
Posted: Sun Aug 13, 2017 12:41 pm Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 |
Skim wrote: |
Bet that came from Texas..
_________________ Bus Motor Build
What’s That Noise?!? |
Clara Samba Member
Posted: Sun Aug 13, 2017 1:44 pm Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 |
Skim wrote: |
I put it on that dogleg we shipped you. Ted in Seattle gave it to me, he made a bunch of cool magnets at his work. I thought you might like it. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Sun Aug 13, 2017 6:54 pm Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 |
Skim wrote: |
Found this magnet. I'm not sure where it came from but I like it. |
T'sooo rad...what were the chances. |
Skim Rants Master
Posted: Sun Aug 13, 2017 7:00 pm Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 |
Clatter wrote: |
Clara wrote: |
Skim wrote: |
I love it it's awesome!! Thanks Clara!
BarryL wrote: |
Skim wrote: |
I really dig it! _________________ GFK
1953 Kabriolet
1954 Sunroof
Skim Rants Master
Posted: Sun Aug 13, 2017 7:19 pm Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 |
Been meaning to get the safaris mounted so this week I plan to ospho prep and paint my windshield channels and frames. For now thanks to help from Ryan (55bundt) for stopping by to help me install the safaris and front beam.
Ryan welding in the safari slider brackets. Was good to finally have some help. It's not easy doing everything all alone. Some stuff definitely takes two people.
1953 Kabriolet
1954 Sunroof
Skim Rants Master
Posted: Sun Aug 13, 2017 7:25 pm Post subject: Re: OG Paint Turkis 15 Window Deluxe. El Pavo 15 |
1953 Kabriolet
1954 Sunroof
