ROCKOROD71 Samba Member
Joined: January 18, 2012 Posts: 2770 Location: Boston, MA
Posted: Sat Jun 24, 2017 7:32 am Post subject: Re: Just how slow is an early bay? |
What exhaust are you running? Only a stock or properly modified aftermarket exhaust will have the proper plumbing to feed the manifold preheat pipes. You may not be getting any hot air through the preheat. Many aftermarket setups actually have those ports plugged requiring you to drill them out. _________________ 1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
1977 WESTY "KrustyKamper" 2L FI
79SuperVert wrote: |
30 years from now, the next guy may not want your girlfriend, but he may want your classic car, depending on how nice you were to it. |
asiab3 wrote: |
Careful guys, a petulant child can grow up to be president these days. |
**winter drivers: no survivors!**rust warrior**#keepbodyshopsbusy** |
VW Man 53 Samba Member
Joined: November 12, 2011 Posts: 588 Location: Scotia, New York
Posted: Sat Jun 24, 2017 7:45 pm Post subject: Re: Just how slow is an early bay? |
ROCKOROD71 wrote: |
What exhaust are you running? Only a stock or properly modified aftermarket exhaust will have the proper plumbing to feed the manifold preheat pipes. You may not be getting any hot air through the preheat. Many aftermarket setups actually have those ports plugged requiring you to drill them out. |
it's the empi single tip "econo exhaust" it has the plumbing for the heat risers, plenty large enough holes all the way through, i have the manifold back on the car, no vacuum leaks, no blockage, cylinders 2 and 4 are literally just not firing at full capacity, the exhaust is only getting warm, not hot, i've checked everything and it has to be a carburetor issue, there is nothing left. _________________ You CAN save them all. |
kokanee Samba Member
Joined: April 15, 2007 Posts: 329 Location: Washougal WA
Posted: Sun Jun 25, 2017 1:33 pm Post subject: Re: Just how slow is an early bay? |
Have you checked for compression on those two cylinders and check for tight valves. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22665 Location: NYC/Upstate/ROW
Posted: Mon Jun 26, 2017 6:07 am Post subject: Re: Just how slow is an early bay? |
22manybugs wrote: |
From what I remember on a DVDA, #1 cylinder was the wire toward the back right on the distributor ( because it was always a pain to hook up the timing light). Looks like #1 is hooked up in the front right here. Since you say cylinder 2 and 4 don't change sound, check that all the spark plug wires go to the correct cylinders. |
Lon gets the Samba medal for the month of June.
_________________ .ssS! |
Posted: Mon Jun 26, 2017 7:15 pm Post subject: Re: Just how slow is an early bay? |
Abscate wrote: |
22manybugs wrote: |
Big shout out to Steve (Abscate) for checking out the bus in person and finding my ridiculously embarrassing mistake. This just goes to show you really need to walk away from a problem when you're bashing your head against the wall, i'll start over with the basics next time. A set of fresh eyes always helps. Somewhere down the line the #2 and #4 plug wires got switched. Thanks Steve!
Also just to say, the bus is far from slow, i'm impressed, it shits and gets for a bus with a 57 horse 4 cylinder. Thanks everybody for your time, the samba community never lets me down. _________________ You CAN save them all. |
Posted: Tue Jun 27, 2017 12:02 am Post subject: Re: Just how slow is an early bay? |
I was amazed at how smoothly it idled and how well it revved. I've worked in lines so long I had forgotten how forgiving a flat four is on firing order mistakes. After I talked with vman on the phone I was at a loss and was thinking very esoteric. Once the Bus saw my Haynes polo undershirt , though, I could smell the fear...,, _________________ .ssS! |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Tue Jun 27, 2017 4:36 am Post subject: Re: Just how slow is an early bay? |
Of course now that it's been pointed out, it's easy to see in the picture that the firing order is set to 1234 instead of 1432.... Good job guys! _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Posted: Fri Jun 30, 2017 6:31 pm Post subject: Re: Just how slow is an early bay? |
Once a Bus sees someone wearing a Charles Bronson undershirt...it knows it's over....
Xevin Samba Member
Posted: Fri Jun 30, 2017 6:57 pm Post subject: Re: Just how slow is an early bay? |
Pretty nice to have that guy in your back yard. Just make sure he cuts his toenails _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Posted: Sat Jul 01, 2017 4:29 am Post subject: Re: Just how slow is an early bay? |
Xevin wrote: |
Pretty nice to have that guy in your back yard. Just make sure he cuts his toenails |
Heh heh heh... _________________ .ssS! |
Posted: Tue Jul 11, 2017 5:21 pm Post subject: Re: Just how slow is an early bay? |
such a great picture, thanks again man! i owe you one. _________________ You CAN save them all. |
